Only 1 of 2 fog lights working each side? Opt7
Old Mar 22, 2016 | 05:48 PM
Publixman99's Avatar
Help!! Just installed opt7 hit H11 fog lights and when on only one of the 2 lights on each side turn on? Both sides the inside bulbs don't fire up? Can't be fuse because the outside LEDs work and only one fuse 15amp under hood. Ordered 2 kits and installed one per side. What gives?
Old Mar 22, 2016 | 06:37 PM
Issue was measure twice cut once........ Turned out bulbs were not making contact from harness. Tore apart again and troubleshooted... Pressed harder and here we are!!! Great match to factory LED's. No need to put bigger fuse In either....:.so far😄😄
Old Mar 23, 2016 | 06:18 AM
BlakMaxiJoey's Avatar
.... No need to put bigger fuse In either....:.so far😄😄
I was told that installing higher fuse rating may potentially melt the harness due to higher current - hotter. no?
Old Mar 26, 2016 | 07:37 PM
TonyMaximaSR's Avatar
off topic...OP, r you in Lakeland??
Prophecy99
27
Feb 10, 2017 09:44 AM
manilakid3
Mar 4, 2016 09:09 PM
maximafan2016
Mar 3, 2016 01:05 PM
Alipsettphoto
Feb 29, 2016 03:15 PM
sebastian2041
Feb 26, 2016 07:40 PM
