Say it isn't so cabin air leak
Old Apr 2, 2016 | 08:18 AM
JSROOKS's Avatar
Well ladies and gentlemen for what I put off for a while I have finally accepted and come to terms with. My car isn't perfect. So as most of us do we drive with the music on and rarely with it silent. Well I finally did that a couple times on the freeway. And I notice that air whistle sound really pick up inside between 60-80 mph. At slower speeds you can't hear it. And from my vantage point it's all coming from either the front or rear passenger side or both. So I had my dad drive and I sit on th passenger side and sure enough it's pretty noticeable. The hard part is where is it coming from exactly. So I took a couple pictures of what I think may cause it. I took two of the inside and outside of the car. And the same for the passenger side. And from what I can tell on the passenger side the lining of part of the rubber bulges out and doesn't seem flat like on the driver side. Also on the outside of the passenger door if you look close that corner doesn't seem to sit flush either. So I made an appointment for Tuesday to drive with a master tech. Anyone else having this issue or maybe ha not tried it yet?
Attached Thumbnails Say it isn't so cabin air leak-20160402_075825.jpg   Say it isn't so cabin air leak-20160402_075855.jpg   Say it isn't so cabin air leak-20160402_075919.jpg   Say it isn't so cabin air leak-20160402_075957.jpg
Old Apr 2, 2016 | 08:36 AM
TonyMaximaSR's Avatar
That bites, my only suggestion would be to go on another ride with someone driving and take video proof of the noise. My luck has always been when someone from the dealership gets in the car it never wants to reproduce whatever it was that I brought it in for.
Old Apr 2, 2016 | 08:39 AM
JSROOKS's Avatar
Yeah I don't think video would really pick up the sound it's not like it's drowning out the cabin kind if a subtle but there sound.
Old Apr 2, 2016 | 01:58 PM
A36-SR's Avatar
I will take it to the dealership, i got my up to 145 with no noise or issues by i have a bad power steering pump i juts have not taking it to the dealer
Old Apr 2, 2016 | 02:18 PM
urdunfer's Avatar
I would check all the black trim panels around the windows. Those are all heat wrapped vinyl and sometimes the vinyl peels up at the upper corners. That could cause a noise between the trim and door gaskets. Good luck
Old Apr 2, 2016 | 05:57 PM
mrgooch's Avatar
Get it up to 200 mph and you won't ever have to worry again.
Old Apr 3, 2016 | 08:07 AM
robtroxel's Avatar
Aaahh! Mine cuts out @ 195 so I am jealous! Some fun to be had dropping the hammer out of the many toll booths around here
Old Apr 4, 2016 | 09:31 AM
JSROOKS's Avatar
Yeah I am going to have the tech listen and really give me an honest opinion. To what the dealership said is that Nissan really wants quality on these cars and wants to fix everything. Lol I don't think these can get that high. Don't they cut out at 140 or something?
Old Apr 4, 2016 | 12:15 PM
A36-SR's Avatar
Is 130 but if you have tune it will not LOl.
Old Apr 5, 2016 | 05:38 AM
tc8510's Avatar
Who provides the tune for it?
Old Apr 5, 2016 | 05:41 AM
A36-SR's Avatar
UP REV or bullydog but if you want best results Up Rev is the best but the software is 950 Plus dino time here in az they charge 300 for that
Old Apr 5, 2016 | 05:59 AM
JSROOKS's Avatar
Oh awesome dude I didn't know you were from AZ too if you don't mind me asking what part?
Old Apr 5, 2016 | 06:00 AM
tc8510's Avatar
Well damn that's a pretty penny... thanks for the info!
Old Apr 5, 2016 | 02:47 PM
A36-SR's Avatar
I live in glendale😀
Old Apr 6, 2016 | 07:04 AM
JSROOKS's Avatar
Not far at all I live on the Peoria/Glendale boarder around 75th ave and Greenway.
Old Apr 6, 2016 | 07:08 AM
JSROOKS's Avatar
UPDATE: So I went to the dealership yesterday and took a test drive with a Master Tech and head foreman of the whole service department. I drove first then he did so we could have two perspectives. He told me I can make a couple adjustments, but these cars are designed pretty quiet and of course really aerodynamic. So anything above 80 all bets are off. I have test driven a couple Maximas previously before buying my car, but when you drive them with a Salesman there is usually constant talking and or music playing so you hardly get to test out the dead air of the highway. Long story short he adjusted what he could and it does seem to help. But I think my ears just aren't used to what a Maxima sounds like vs what I had before an Altima.
Old Apr 6, 2016 | 05:06 PM
MONTE 01&97 SE's Avatar
That's not normal even above 80, the 16 Maxima rentals that I get and I have them often when I go out of town for work are very quiet above 80. The one I have currently a brand new 16 with 384 miles on it, took it to 94 mph on a stretch of I5 in Northern California and it was very quiet. No unusual wind/whistle noises at all!
Old Apr 6, 2016 | 05:11 PM
JSROOKS's Avatar
Yeah that's why I took mine in just seemed like too much off and on whistling of wind that a new car should have.
Old Apr 6, 2016 | 05:14 PM
That would drive me nuts, especially as much as I am on the highway at higher speeds often these days !
Old Apr 6, 2016 | 05:46 PM
lightonthehill's Avatar
My first guess would be that somewhere one of the doors has insulation that is not in full contact with the door opening when the door is closed, leaving a crack where the sound of outside air gets in. If the sound is worse on one side, the problem is probably on one of the two doors on that side.
I created a similar problem when I put rain guards at the top of all four side windows on my 2009 7th gen, and it took me weeks of trying different shape deflection molding on the side of the car near the base of the windshield before I found a shape that nullified the whoosh caused by the rain guards.
Finding an air leak around a door can be difficult. Maybe having someone else drive while you take turns in each seat with all air circulation (AC, heater, etc) off and try holding a single sheet of something very thin (toilet tissue?) right at every spot along the inside edges of every door, and it you see the tissue move at all, there is probably a tad of air getting in at that spot.
If you find nothing wrong with the doors, you might try the thin tissue thingie under the dash and around the edges of the sunroof (if you have one).
Old Apr 7, 2016 | 08:43 AM
JSROOKS's Avatar
Yeah i am going to have to try different methods and see. Because I am sure they were trying to do everything but replace all the weather striping. So if I do find it then they damn sure will replace it.
A36-SR I know we don't know one another but since you are close would you mind driving my car and I can sit in yours while you drive to see if there is a difference?
Old Apr 7, 2016 | 12:14 PM
Pressurize the cabin by turning the air conditioner on high with the windows closed and outside vents open so it's drawing air from the outside. Have to wait for a not so windy day and try to have someone with a vape go around the whole vehicle. Any disturbance is where your leak will be. And this way you are able to narrow down better. Maybe do this in a garage with the garage door open. And when whomever is blowing the smoke, make sure that person blows it out slowly so there's not much movement.
Old Apr 7, 2016 | 12:19 PM
JSROOKS's Avatar
Damn that is a genius idea. I have have a bunch of people that vape with heavy clouds. I will do that. So while they do this should it be blowing in a general direction so the whole car fills up? Also at this point do I turn the air off after the cabin is pressurized?
Old Apr 7, 2016 | 12:21 PM
No you blow the vape smoke from the outside and blow against the doors and window area, the air from inside the vehicle will be pressurized and try to equalize by exiting the vehicle. The air that's disturbing the vape smoke from the outside will point where you have to carefully inspect.
Old Apr 7, 2016 | 12:24 PM
JSROOKS's Avatar
Oh ok I get what you mean now. Yeah that would have to be a thick cloud and slow like you stated to get a good visual.
Old Apr 7, 2016 | 12:25 PM
Yes, it will not tell you what is wrong, but it will pinpoint where to focus on.
Old Apr 7, 2016 | 12:46 PM
JSROOKS's Avatar
Yeah it least it will give me some direction if it is just me or not.
oldpuck81
Feb 15, 2020 09:01 PM
josh_pagdilao
Feb 7, 2016 10:46 AM
Will92
Feb 2, 2016 09:11 AM
Roy2882
Jan 25, 2016 04:05 AM
Jaxmax2016
Jan 22, 2016 02:20 PM
