Do these ever change?
Old May 15, 2016 | 09:11 PM
09Maxima_Sam's Avatar
When in sport mode on the dash display does anyone ever see the oil pressure or transmission temperature digital gauges ever fluctuate or change. Whenever I view mine they are always at the same level and seem to me to be just a fake reading display.
Attached is a pic of mine.
Old May 15, 2016 | 11:28 PM
dcpatters's Avatar
When cold, the transmission temperature reads very low. After some miles, the.temperature slowly creeps up. I'll check with Torque Pro and confirm how much the temperature fluctuates.
Old May 20, 2016 | 06:42 PM
ZroSkil's Avatar
The two readouts are Oil Pressure (left) And Gear Oil temperature (right), I hardly see any movment on mine. Will keep an eye on it and report back after my road trip in a few weeks.
Old May 23, 2016 | 07:11 AM
gizzsdad's Avatar
I am pretty sure that they are actually glorified idiot lights and not actual functional gauges.
Old May 23, 2016 | 07:54 AM
Yeah that was what I was thinking. You would think they could made them functional. Because usually that info is being supplied to the ECM anyways. All they have to do is display it on the dash.
Old May 23, 2016 | 12:37 PM
dcpatters's Avatar
Hooked up Torque Pro and configured a transmission temperature and Coolant temperature display. Unfortunately, I could not find the oil Pressure PID to add to the display. Nevertheless, on a ~20 mile trip, once up to operating temperature, there was only a minor variation of ~188 - 194F in temperature, so probably not enough to notice on the LCD display. What I found very interesting, the coolant and transmission temperature display identical temperature output. Perhaps the CVT is cooled by the same source or Torque Pro is mapping the wrong ECU PID for CVT temperature.
Old Jun 3, 2016 | 09:12 PM
Blasterguy's Avatar
Think so. Only 2 settings: Cold and "Normal" Perhaps in a worst case scenario there is a "Too Hot"
Old Jun 15, 2016 | 03:58 PM
raven69david's Avatar
The only time I see the transmission temp. change is when it's cold and then climbs in 3 to 4 increments to the "normal" level. But I do see it move. Since the cars are so new I wouldn't expect that gauge to go higher unless there's a serious malfunction in the system but only time will tell (hopefully I never get that warning).
Nismatic35
May 3, 2016 05:34 AM
SquidBeak
May 1, 2016 03:11 PM
Ricky Green
Apr 26, 2016 09:25 PM
michaelle8885
Apr 21, 2016 06:34 PM
2002GLE
Apr 18, 2016 11:50 AM
