Accessories installation: Diffuser and Rocker Panel Molding
Old Jun 1, 2016 | 02:11 PM
16Max's Avatar
Hi all,
I'm planning to add the diffuser and rocker panel molding to my Storm Blue SR. Before I order them from Nissan's estore, I would like to see if any one of the members here had installed these two items. How difficult is the installation: is it a job that requires a shop mechanic or can an owner with a simple wrench handle it?
Have anyone seen any installation walkthrough out there?
Thanks.
Old Jun 1, 2016 | 05:47 PM
Stlbluzoo11's Avatar
You should be able to install those parts yourself. If you're handy with tools and have a good eye to line it up, you'll do fine. They come with instructions and it's nice to have a friend with you for help to hold things in place. I have not installed the factory parts, but I have installed the splitter and diffuser from stillen. I had zero issues with stillens full kit for the 7gen on install. A factory part will be a 100% fit and go on perfect. Give it a try and see how it comes out. You may save yourself money and be happy with the outcome. You can always take the parts to an installer if you have trouble. Make sure to use blankets or cardboard to lay the parts on. You do not want to scratch the surfaces of your new accessories. Clean your surfaces very thoroughly. You will need to prep the surface for proper adhesion. If there is double sided tape adhesion promoter will hold the parts in place with a better bond. Good luck!!
Old Jun 1, 2016 | 07:41 PM
16Max's Avatar
Thanks for the info. I will give it a shot.
Old Jun 1, 2016 | 08:58 PM
A36-SR's Avatar
I have a oem use rear diffuser for sale 100 plus shipping am in az please let me know .
Old Jun 2, 2016 | 04:33 AM
Lilvanmuzz's Avatar
Do you still have this available? Pics?
Old Jun 2, 2016 | 09:24 AM
mikeq00's Avatar
Is the diffuser still available? I'm interested !
mqueue@comcast.net
Old Jun 2, 2016 | 05:04 PM
doctorpullit's Avatar
Originally Posted by 16Max
Hi all,
Thanks.
I installed the rocker panels myself. It's pretty straight forward and not very difficult. It will probably take you about half an hour. If you don't have a way to lift your car, you will need a right angle drill due to limited ground clearance to screw in the panels.
Old Jun 2, 2016 | 05:52 PM
PhillyPhreak's Avatar
I just purchased a "4DSC" shift **** and want to install it. Has anyone changed one on their 8th gen Maxima?
Old Jun 2, 2016 | 08:32 PM
A36-SR's Avatar
Simple pull the chrome ring down then pull the clip out and pup the shift up
Old Jun 3, 2016 | 11:09 AM
16Max's Avatar
Does the installation of the rocker panel required to drill holes or screw through metal?
Old Jun 4, 2016 | 05:42 AM
wyobbagy's Avatar
no just through the rocker panel plastic so the push pin can be installed...the holes are marked but painted over I used a step drill cut in 2 secs....double side foam tape hold them in place pretty easy install...did by myself rear diffusser I needed a helper to line it up didnt want to take a chance of getting it off the marks
Old Jun 15, 2016 | 02:03 AM
deerram's Avatar
I have found that Quirkparts.com have the cheapest prices on these parts. It is easier to look them up if you have the parts numbers.
Old Jun 20, 2017 | 08:50 AM
ccwasson's Avatar
Rocker panel molding is rattling. The Nissan Service Dept. installed them but now I have a rattle on the passenger side. It's worse when it's windy outdoors. I took it in once to but they said it wasn't the molding but the lower shield under the motor being loose. Now the rattle is back.
chriscummings83
Mar 30, 2020 08:38 AM
Kevin Chang
May 26, 2016 07:59 PM
LG Done Son
May 12, 2016 09:02 AM
TBad2002
May 6, 2016 08:22 AM
AkkiDonz
May 5, 2016 02:33 PM
