DASH CAM Issue
Old Jan 3, 2018 | 09:10 AM
dlatlfk's Avatar
DASH CAM Issue
Hi I have 2017 MAX. I was Trying to install dash cam with fuse tap.
My problem is none of my fuses power up the cam (either engine on and off)
Power socket slot did work for the first time but does not work after I swapped to another fuse slot and come back.
Cam does work with cigarettes jack.
Any Idea?
Old Jan 4, 2018 | 05:37 AM
BlakMaxiJoey's Avatar
i’m guessing here... for the fuse tap, maybe the ground location was not good??
Old Mar 10, 2018 | 03:29 AM
pvresale's Avatar
Any Idea?
How about a mirror tap instead. I've got one for my radar detector. Turns it in and off automatically with ignition
Old Feb 5, 2023 | 06:51 PM
mustang86's Avatar
Make sure voltage and amp are sufficient and constant.
The problem with cig lighter is that you need to use 12v adaptor to get 5v to power your dash and often time the cig lighter is lose or the adaptor you are using isn't strong enough to deliver a good amount of current. Best if you can tap in a fuse in the fuse box and get constant power. This should eliminate dash cam power related issue . But since your porblem is the opposite, i would recommend choose a fuse with 15amp and make sure to properly put two 15amp fuses in the fuse extension and get a dc to dc converter with at least 5v 3A output . Try this method.
Any Idea?
Old Apr 3, 2023 | 01:45 PM
R Peezy's Avatar
you may wanna install this and to hell with running a power suplly all around your cabin, dash etc.......... mines keeps it classy looking.
Amazon Amazon
happy dash camming!
corpdecker
Dec 30, 2024 04:42 PM
sam930
Nov 14, 2021 08:24 AM
SubwayVQ
Aug 25, 2017 03:23 PM
gofastgt
May 13, 2012 03:17 PM
tunedup
Dec 24, 2000 10:19 AM
