bose speaker replacement
Old Mar 29, 2020 | 01:47 PM
zakary_ingram's Avatar
I am trying to install aftermarket speakers on my 2016 maxima. Is there a post on this website with someone who has previously done so. This would be very helpful. Thanks.
Old Mar 30, 2020 | 07:46 AM
robtroxel's Avatar
Before you do this, check the speaker impedance ratings for the new speakers. As I recall the Bose units are different from most other speakers. I want to say the difference is substantial enough to blow the Bose amps. Perhaps an expert will chime in though I recall this being discussed on the site some years ago.
Old Mar 30, 2020 | 09:35 AM
wild willy2's Avatar
Yeah, he is right..not just a simple swap. Same goes when installing a Sub
Old Apr 4, 2020 | 06:45 PM
JimmyK's Avatar
Factory speakers are 2 Ohm, which helps the weak Bose amp produce enough volume. To continue using the factory amp you need to replace the bad speaker with a 2 Ohm speaker.
Old Apr 5, 2020 | 03:59 AM
I remember when I added a sub to Bose in my Altima back in 02 I had to do some research...I really had no Idea what I was doing, but got it done. I believe something called a High-Low converter was something I used to make it all work with the Bose amp
SkoorbMax
Dec 30, 2010 07:54 AM
blkhawk500
Jan 1, 2004 08:44 AM
Flutie7NFL
Dec 29, 2003 09:39 AM
yu241229
Apr 10, 2002 07:24 PM
