Can wheel bearings cause a rumbling noise?
Old Nov 6, 2023 | 12:06 PM
stodge's Avatar
I know it's probably impossible to answer, but there's a rumbling sound, possibly from the front of my 17 Maxima SL. It has about 33000km on the clock. I don't think it's the tyres, as it happens on both winters and all seasons. The sound varies slightly with vehicle speed and it's always there. I think it sounds like I'm constantly driving on a rumble strip. Could it be the wheel bearings, and if so, how many hours labour does it take to fix for one wheel? Thanks
Old Nov 7, 2023 | 06:11 AM
robtroxel's Avatar
Possible but also check CV Joints.
Old Nov 7, 2023 | 02:54 PM
Maxgig's Avatar
You might want to check the wheel studs as well. I had a broken stud on my passenger side rear wheel that was only noticeable when I drove past a solid object or a jersey barrier. Inexpensive to fix but tricky to diagnose.
Old Nov 7, 2023 | 06:07 PM
Polarisdb's Avatar
I had a bad front passenger side ball joint in my Hyundai that sounded like a bad bearing.
Old Nov 7, 2023 | 08:24 PM
chrome91's Avatar
if you make a sudden turn one direction does the sound get quieter? Wheel bearing growling usually gets louder with speed and if you make a sudden turn and it gets quieter its usually wheel bearing. But hoisting it with a mechanic stethoscope is safest bet
vvslavavv
Jul 12, 2008 04:09 PM
werdna58
Jan 22, 2008 09:11 AM
SMX95
Mar 28, 2005 10:01 AM
markargente
May 30, 2004 06:06 PM
darrelfsu
Oct 16, 2003 09:29 PM
