Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
K-Sport Coilovers Talk
Old Apr 12, 2006 | 09:51 AM
  #1001
d00df00d's Avatar
Old enuf to pick his own gears
Originally Posted by MidniteMaxSE
POST 1000!!!!!
Old Apr 12, 2006 | 10:04 AM
  #1002
Mr.Duck's Avatar
POST 1000!!!!!
I think 4kg would be too soft...maybe someone might want to try 6/4??
i only see you having 250 posts.. hrmm
so wait, is it not a good idea to swap the rear springs to the front? and ksport doesnt have 5kg? cuz damn i was really gonna try what midnightmax did
Old Apr 12, 2006 | 10:07 AM
  #1003
d00df00d's Avatar
Yes, but his was post #1000 in this thread.
It's okay to swap rear springs to the front unless you're super-slammed, in which case you might have to either raise your car or preload the spring to prevent contact between the lower spring perch collars and the lower mount collar.
It's not necessarily okay to swap front springs to the rear.
Old Apr 12, 2006 | 10:19 AM
  #1004
azn_s3nsation87's Avatar
Dam, i been reading about yu guys swapping high kg to low kg, i want to ride in one of those to see how much differents does it make. It is better or worse compare to the stock kg??
Old Apr 12, 2006 | 10:52 AM
  #1005
d00df00d's Avatar
Stock is something like 2.4 front, 4 rear....
Old Apr 12, 2006 | 10:55 AM
  #1006
MidniteMaxSE's Avatar
Come down to NY and ride in my car!
Somebody should get in touch with k sport about this.. all of the springs on my D2s (9kg, 7kg, 5kg) were the same diameter and length...completely interchangable! I thought it would be the same case for the K sports...
Old Apr 12, 2006 | 12:22 PM
  #1007
Black Maxima
So what's the lowest spring rate available for the KSports?
Old Apr 12, 2006 | 12:29 PM
  #1008
NOZMaximus's Avatar
I would say 4 because I highly doubt anyone would want to go softer than stock....lol
Old Apr 12, 2006 | 12:32 PM
  #1009
Black Maxima
Just a little chat I had with KSport. Thought I would share. I don't know if this information was already posted in the thread. I thought it was pretty cool.
ME: what the lowest spring rate you have for the KSports A32 Maxima?
ksportsupport: hmm, i would say 7/6
ME: oh i thought you had lower
ksportsupport: we do but the shock will blow, and it will drive like a boat
ksportsupport: a 4kg spring is not enought to hold the car up
ME: my stock is something like 2/4
ksportsupport: that is equal to 224lbs/inch
ksportsupport: stock is a progressive rate, which is totally different
ksportsupport: these are linear rate
ksportsupport: you cant compare these to a normal spring at all
ksportsupport: although yoru stock is 2kg possibly, with more pressure it increases up to 15kg
ksportsupport: so it will nto bottom out plus you can have the same amount of travel as you did with stock, otherwise when you lower it it will rub or bottom out
ksportsupport: when our spring is 224lbs/inch that means for evrery 224lbs. of weight the spring will compress one inch
ksportsupport: 9/7 is the best rate for handeling, and being able to lower the vehicle
ksportsupport: if you went with softer springs it will allow the spring to compress more, causing rubbing or bottoming out
Old Apr 12, 2006 | 12:47 PM
  #1010
d00df00d's Avatar
Oops. Stock springs are linear rate, not progressive.
But the point is a good one anyway: if you lower your spring rates to near stock, you'll have to raise your ride height to near stock as well to prevent rubbing and keep your chassis from bottoming out. Since that's possible in the rear but not in the front, you're kind of limited in what you can do. Plus, you might have to add some preload since you might not have enough suspension travel to accommodate the lower spring rate.
In the end, why have coilovers if you're just going to have near-stock ride, ride height, and handling?
Old Apr 12, 2006 | 01:03 PM
  #1011
Hah! That some good point for those who want lower springs rate.
Old Apr 13, 2006 | 04:53 AM
  #1012
NOZMaximus's Avatar
So my question still is then are the K-sport for A32 9/7 or 9/6?? It sounds like its 9/7 in that conversation posted?? No?
Old Apr 13, 2006 | 06:15 AM
  #1013
d00df00d's Avatar
AFAIK, most kits were shipped with 9/6 but some people have said that their kits came with 9/7....
I wonder if there'd be a way to find out without having the original box.
Old Apr 13, 2006 | 07:33 AM
  #1014
Mr.Duck's Avatar
so they are saying that we can lower the front springs to 7 w/ out any problems?
Old Apr 13, 2006 | 07:50 AM
  #1015
d00df00d's Avatar
Correct...
Old Apr 14, 2006 | 07:01 PM
  #1016
Mr.Duck's Avatar
so basically i can order a new set of 7kg springs for the front, and just leave the 6 in the back? will that affect anything?
Old Apr 15, 2006 | 06:27 AM
  #1017
d00df00d's Avatar
Yes it will.
You'll basically have Tein basics, only with damping adjustment, front pillow ball mounts, separate height and preload adjustment, and different shock valving.
Compared to what you have now, expect better compliance in the front, no difference in the rear, slightly lower overall grip levels, and less understeer at the limit.
Old Apr 15, 2006 | 01:59 PM
  #1018
Poowill's Avatar
Originally Posted by d00df00d
Yes it will.
That sounds ideal. Looks like i'll be buying some softer springs as soon as i can. Right now these roads are killing me w/9kg.
Is there a way to get money back for the slightly used 9kg springs? I'll have no use for them after buying 7kg.
Old Apr 16, 2006 | 01:14 PM
  #1019
d00df00d's Avatar
You'll have a hard time convincing Ksport to take their springs back.... :-p
Old Apr 16, 2006 | 04:39 PM
  #1020
Poowill's Avatar
meh, i suppose. well, i'll have track springs and driving spings...cause i get to the track sooo often
Old Apr 17, 2006 | 03:53 AM
  #1021
d00df00d's Avatar
You should move them to the back. 7/9 springs would at least start to dial out some understeer.
Old Apr 17, 2006 | 07:11 AM
  #1022
Black Maxima
Is there a big difference between the 9kg then swapping to 7kg in the front (keeping the back the same)?
Old Apr 17, 2006 | 08:11 AM
  #1023
d00df00d's Avatar
It's not exactly night-and-day, but it is definitely noticeable.
Just remember, you might have to give up either your "Lowest in CT" title or your undercarriage if you lower your spring rate(s).
Old Apr 17, 2006 | 08:51 AM
  #1024
NOZMaximus's Avatar
Hmmmm, I wonder. I shall contact k-sport to find out the spring rate my rear came with. If they are 7kg/mm, then going to 6kg/mm should make the ride in the rear a little more forgiving with the terrible roads here in Toronto.
Old Apr 17, 2006 | 02:56 PM
  #1025
rush0's Avatar
hey anyone know if the max springs and the altima springs are interchangable? Do they have spring specs listed somewhere, like length?
Old Apr 17, 2006 | 04:13 PM
  #1026
d00df00d's Avatar
AFAIK, all their springs have the same inner diameter. Dunno about length though...
Old Apr 21, 2006 | 04:51 AM
  #1027
NOZMaximus's Avatar
So after talking to ksport, I guess my set was one of the few that came 9/7 for the A32, so I grabbed a pair of 6kg/mm off them. How much of a difference in the rear do you think 1kg/mm will make? I didn't want to grab a pair of 5 and throw the 7 infront and all that cuz I am actually very satisfied with the way the 9 in front feel. I always found the rear to be a little to stiff, so hopefully this should smoothen it out a little
Old Apr 21, 2006 | 04:53 AM
  #1028
NOZMaximus's Avatar
Since I'm going with a softer spring, and that might rise the probability of bottoming out a little higher, do you think its a good idea to raise the dampening a little to compensate? Which will protect my struts better, stiffer dampening, or full soft?
Old Apr 21, 2006 | 05:53 AM
  #1029
d00df00d's Avatar
If my experience is any indication, you won't have to worry about bottoming out with 6 kg/mm springs in the rear unless you're really really slammed. Even when I was dropped 4", I never ever bottomed out unless I drove over a hump or dip in the road that was too big for my approach/breakover/departure angles. Just set the damping to whatever you're comfortable with.
Not sure on the damping question though. Let me see if I can find out...
Old Apr 21, 2006 | 11:38 AM
  #1030
jinsu's Avatar
you will not bottom out on 6kgs as that's the lowest recommended by ksport for the maxima.
Old Apr 21, 2006 | 03:01 PM
  #1031
kenji's Avatar
So has anyone ordered and then actually received a set of 8/6 springs with their Ksports? Cause I'm leaning towards that combination. A middle ground between 9/7 and 7/5.. 8/6
Old Apr 22, 2006 | 11:39 AM
  #1032
kenji's Avatar
Bumpity noone rollin on 8/6????????????????????????????????????
Old Apr 23, 2006 | 01:34 PM
  #1033
kenji's Avatar
Well it looks like I'm going to be the ksport 8/6 test mule.
Old Apr 24, 2006 | 04:49 AM
  #1034
NOZMaximus's Avatar
I find the 9 in front to be very very comfortable even with the krappy roads here in Toronto. Its the 7kg/mm for the rear of the car to be a little too harsh for a 4th GEN.
Old Apr 24, 2006 | 06:33 AM
  #1035
kenji's Avatar
I'm mostly moving down one notch to save the struts themselves.
ride comfort +1
Old Apr 24, 2006 | 02:22 PM
  #1036
Poowill's Avatar
Because of the normal crazy south dakota weather, i have been realizing how much temperature affect the ride quality. When moderate temps 50-60's degrees it takes a little for the shocks to warm up. But when the car has been sitting in 80 degree weather i take off and it rides soo much smoother.
I'm assumming its fluid inside the shock that causes it to expand contract in temp related environments has something to do with it. Part of it could be temp relation to the tire too, but i wouldn't think it would be to that big of a difference.
Anyone else exprience this? If it has been discussed before forgive me i have been trying to keep up with this thread as much as possible. Just giving a little of a review for midwestern weather. I can really see how people in hotter climates are very pleased with this setup.
Old Apr 24, 2006 | 03:30 PM
  #1037
kenji's Avatar
Yes, I think it has a lot to do with the oil warming up.
Old Apr 24, 2006 | 05:06 PM
  #1038
d00df00d's Avatar
Or the nitrogen gas (they're oil/gas shocks).
Old Apr 24, 2006 | 06:20 PM
  #1039
Poowill's Avatar
thought i they were something like that..
Old Apr 24, 2006 | 07:38 PM
  #1040
Black Maxima
Mine are real stiff when it's 30 to 40 degrees. They seem to never warm up. This summer will be good though...
