K-Sport Coilovers Talk
if the Noise isolator kit helps, im totally stoked..
Nah, see the preload collars are staying on the same spot on the strut. This is what allows the height adjustment. Thus, there should not be any chance in the distance from perch to perch if all that is happening is the strut is spinning. Right?
I might get what you are saying, what i don't understand is if you do that will it make for less movement in the piston of the shock, because as you raise/lower the suspension that way the piston is just moving up or down...but i cant see how the preload collars can stay in the same place.
You can tell if its blown by seeing if oil is under the dust boot on the shock. if you go over a bump the shock will be very noisy and harsh. It will almost feel like the car is dragging over the bump, instead of just hitting it. Basically KSports blow 24/7, so if you think you have a blown shock you probably do have one.
Wats the longest you've ever driven with a blown one??
Ive got 2, maybe 3 blown. Not sure, and with my luck, probably 4...haha. I can only see oil on 2, but it was rainy and wet so hard to tell. I dont think all 4 are blown though.
Been riding on them since August 22. Ill probably ride on them until after Christmas.
Dang, that sucks guys. How long is the turnaround for them when getting "rebuilt" And costs?
Well it depends, if you call them up try to get them to send you a shock and then once you get it send them the blown one. They have always done that for me, but I don't know if they regularly do it. All 5 replacement shocks I have gotten looked completely brand new. I don't think they actually rebuilt many of them because the threads are perfect on the replacements I've received.
that is a good idea. it'll just be like selling a refurbished set.
i'm just glad i still have my stockers that i can go back to for whatever reasons.
what are you thinking about upgrading to if you do sell em?
Ok, so after 30 minutes to an hour of driving, my back hurts. Is this due to my blown shocks or is this normal with the stiffness of Ksports? Im only 17, and occasionally have back pain if I ride in the van for hours.
But yeah, when I first had D2s I used to get fairly tired from driving. Mainly highway expansion joints. Around town they are no biggie and you get used to the highway dance.
LOLz@ at BlackMaxima being the strut killer.
you know man.....THE VAN.
Oh wow...no, sorry to dissapoint, the van as in the thing we take on vacation...
Im thinking that a new set of struts will help with them being so rough. Im on full stiff, it gives me the least bounce/jerking(ironically). Full soft is horrid.
Well, I know that at least 2 are blown, maybe three. I know that this would cause horrible ride, but I dont want to spend $440 on 4 new struts if I'm not going to like the outcome...and end of back at stock(and later Koni + GC)...I want to know if, when I replace all of my struts, is it going to ride just as stiff?
what is the normal spring rate for the ksport?
what softer spring rates did you switch over to?
6 in just over 2 years.
I put some Ksport coilovers in my friend maxima last night. I guess he got the new spring rates? the car rode soooo good. i might try to get the softer springs from KSport because they keep sending me shocks hahaha
mannnn i was comin home and thought i was being followed, so I did some MADMAN high speed turns tonight and that **** felt gooood. the tires were squeelin but it was all under control. i'm impressed with these cheap *** tires.
i have been very happpy with full soft in the front and full stiff in the rear btw.
