Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Could 26mm Z32 calipers work on a maxima?
Old Jul 17, 2006 | 06:53 AM
Dasyce's Avatar
Why don’t 26mm Z32 calipers work on a maxima, is it simply cause there are no relocation hardware. Or is there a more complex reason they wouldn’t fit?
Old Jul 17, 2006 | 08:53 AM
Kevlo911's Avatar
Kevlo for President
What rotors do you wanna use that won't warp?
Old Jul 17, 2006 | 08:57 AM
Jeff92se's Avatar
I'm needing a caw
If you use the 26mm rotors it might work. But for any BBK(cobra rotor kit etc..), the 26mm units wont' work. Too thin.
IMHO. Don't mess with teh 26mm units. Just get teh 30mm and be done with it.
Old Jul 19, 2006 | 05:33 PM
z32drifter's Avatar
26mm will work you are just limited to using the 26mm Z32 rotors machined to fit with out the relocation brackets. I would not suggest buying the 26mm setup. I'm running the 26mm setup due to the cost factor. One of my Z friends upgraded to the 30mm setup and gave me his 26mm calipers and new OEM 26mm rotors, so I got the Z32 setup for $50 worth of machine work
ah2002
Mar 9, 2016 01:42 PM
Costa068
Aug 17, 2015 02:13 PM
kenc15
Aug 5, 2015 08:29 AM
kjm900r
Aug 5, 2015 07:14 AM
RealityCheck
Aug 5, 2015 06:18 AM
