Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
6 Gen Calipers/Rotors bolt on for 4th gen?
Old Jul 27, 2006 | 05:55 PM
Zack342's Avatar
If i use Both the 6 gen rotor and caliper will this bolt up on a 4th gen?
Old Jul 27, 2006 | 05:59 PM
Kevlo911's Avatar
Kevlo for President
Different bolts. Search Matt has posted what needs to be done.
Old Jul 27, 2006 | 06:02 PM
michaelnyden's Avatar
zack I thought you were using the cobra 13" rotors and Q45 calipers...?
Old Jul 27, 2006 | 06:13 PM
Matt93SE's Avatar
STFU n00b!
get out the 14mm drill bit and it's a bolt on.
Old Jul 28, 2006 | 07:48 AM
Zack342's Avatar
i do have the Q45 calipers and Cobra rotors. I don't wanna use them. i am selling the rotors/brackets.
I want a simpler setup
Old Jul 28, 2006 | 07:51 AM
Zack342's Avatar
What exactly am I enlarging with the 14mm bit?
Old Jul 28, 2006 | 08:03 AM
GoalieKeg's Avatar
Probably the holes that the caliper bolts to.
Old Aug 7, 2006 | 05:53 PM
Cdg2125's Avatar
Thats all thats needed to use the 6th gen stuff?
Old Aug 8, 2006 | 05:32 AM
liqidvenom's Avatar
brotherhood of tq
its a very easy install once u get all your old stuff off the car.
1. remove stock stuff
2. enlarge tq member bolts from 12mm to 14mm
3. remove or cut down dust shield
4. install everything from the 6th gen
thats basically what needs to be done to make it work.
i have that setup and i love everything about it
Old Aug 8, 2006 | 05:51 AM
Cdg2125's Avatar
Wow thats awesome. Couple questions tho...
1.Which holes need to be drilled? Any pics? I dont want to f that up haha.
2. 6th gen stuff is farely cheap correct?
3. What size wheels are needed?
Old Aug 24, 2006 | 08:33 AM
sdoow's Avatar
I'd recommend going with our Front OE caliper big brake kit. The kit comes with new caliper brackets to fit larger rotors. It is bolt-on and does not require any drilling or modifing the OE setup.
For 89-99 Maxima's we have a 332x24mm kit, and for the 00-03 Maxima's we have a 324x24mm kit.
Check out more info here:
http://forums.maxima.org/showthread.php?t=488329
Old Aug 24, 2006 | 10:43 AM
irish44j's Avatar
retired moderator
hmmm....
I've had good dealings with racingbrake in the past (and GRM talks you up), but....
For less money than that kit you can just get 6th gen calipers ($150/pair) and 6th gen rotors ($150/pair) and they bolt DIRECTLY to our spindles and are a perfect fit (with more pad contact area than the 4th/5th gen calipers, I might add.
Hell, it's costing me about the same to do my 300ZX brake conversion as your 1-piece rotor/bracket kit costs by itself....
Old Aug 24, 2006 | 11:12 AM
Cdg2125's Avatar
Are there any pics for which holes need to be drilled? Or am I going to know right after I take things apart?
Old Aug 24, 2006 | 11:33 AM
irish44j's Avatar
retired moderator
the only holes you will be dealing with are the holes where the caliper attaches to the spindle assembly.
Old Aug 24, 2006 | 08:29 PM
Chefasaurus's Avatar
Fire in the hole!
I also would like a pictogram, if possible.
Old Aug 26, 2006 | 08:03 AM
Cdg2125's Avatar
Sounds good. I also need to know if the setup will clear stock 98 se rims? I'm not getting rims for a little while but I need desperate work on my brakes.
Old Aug 26, 2006 | 02:47 PM
JeremysBlkMax97's Avatar
I am assuming that the 6th gen calipers will bolt up to our stock lines? I have Goodridge SS brake lines and would not want to change them.
Old Aug 26, 2006 | 05:16 PM
irish44j's Avatar
retired moderator
yes
12345678
Old Sep 12, 2006 | 08:47 AM
DaEnigma's Avatar
I am also wondering if the 6th gen calipers and roters will clear 16" wheels?? I have Kosei K-1's and my rotors/calipers are needing replacement soon...
Old Sep 12, 2006 | 11:18 AM
liqidvenom's Avatar
brotherhood of tq
i dont think that would clear 16" due to the height of the caliper...but dont take my word on it.
Old Sep 12, 2006 | 11:37 AM
Zack342's Avatar
any pics from when you did this?
Old Sep 12, 2006 | 06:27 PM
liqidvenom's Avatar
brotherhood of tq
you want pics of my 6th gen set up? ill get them to you by email tomorrow if u want
Old Sep 13, 2006 | 05:20 PM
Cdg2125's Avatar
What rims do you have on the car with your 6th gen work? Maybe post those pics on here
Old Oct 13, 2006 | 10:04 PM
gen4maxima536's Avatar
i'm also interested if this 6th gen set up would fit under 16" gen 5 spokes
Old Oct 15, 2006 | 12:05 AM
Duckman540i's Avatar
VE Powah!!!
Will this all be the same for a 3rd Gen SE?
Old Oct 16, 2006 | 10:51 PM
VE Powah!!!
Bump, will this work on a '92 SE with ABS?
Old Oct 17, 2006 | 10:04 AM
liqidvenom's Avatar
brotherhood of tq
i don't see how bolting on this kit will affect your abs? i know it will bolt on but i say ask someone that has abs about this since i dont have abs. and ill get the pics of my kit up later today
edit: here is a pic, my car is dirty and i dont drive it to much anymore so just pretend you dont see the dirt or rust.
but my setup is:
6th gen rotors
6th gen calipers painted black with 6th gen tq member
oem 6th gen pads
4th gen brake lines and oem bleeders
and 18" x 7.5 rims i forget the offset
i'll get better pics once i get my car washed
Old Oct 17, 2006 | 11:48 AM
liqidvenom's Avatar
brotherhood of tq
pics up.....
Old Oct 17, 2006 | 01:08 PM
oldngivout's Avatar
Willing to learn
I have the 6th Gen front brakes on my 98 I30 with ABS.
Awesome stopping power. I've used it in panic mode a lot, several times because I had to. Never a problem.
Old Oct 18, 2006 | 12:48 PM
VE Powah!!!
Anyone know for sure, if this can be used on a 3rd Gen as well?
Old Oct 18, 2006 | 01:30 PM
with the clearence liqidvenom has with his 18s looks like you'd probably need atleast 17s to clear them, cant be sure without measuring though
Old Oct 18, 2006 | 01:57 PM
liqidvenom's Avatar
brotherhood of tq
17's would be the smallest i would assume you can fit over these. as a rule of thumb....since this came off of a 6thgen wat ever wheels fit on that car over these brake will also work on our cars. and the 6th gen doesnt have a 16" rim possibility i think.
Old Jan 29, 2007 | 08:51 AM
daddymax's Avatar
I have a 2001 Maxima with the stock 17" rims. What would be the best front brake system with the least customization (like grinding 4-5 mm from rotors).
Old Jan 29, 2007 | 09:15 AM
LA02MAX's Avatar
Yes, you need at LEAST a 17" wheel to clear this...
Old Jan 29, 2007 | 09:59 AM
go to http://www.mattblehm.com/brakes.htm
there is a template somewhere on there where you can measure to see if brakes will fit...most likely though, the best and most cost effective upgrade that will fit under your wheels will be the A34 setup...but even that will be a very tight fit...
Old Feb 8, 2007 | 05:17 PM
QnzMax's Avatar
Is there any type of write up with pics for this?
Old Feb 8, 2007 | 05:59 PM
Cdg2125's Avatar
What write up do you need? Drill the hole to 14mm and bolt on the pieces.
Old Feb 9, 2007 | 07:33 AM
QnzMax's Avatar
Yea I realized that after I posted. Thanks though.
Old Feb 9, 2007 | 07:34 AM
QnzMax's Avatar
Do you have wheel spacers to clear the brakes?
Old Feb 10, 2007 | 01:31 PM
LA02MAX's Avatar
nope, the brakes fit like a freaking glove. There's probably 1 or 2 mm between the caliper and the inside of the wheel...
