Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
How did you remove brake sheilds when you did your BBK?
Old Aug 16, 2006 | 01:04 PM
Zack342's Avatar
Any tips on this?
Old Aug 16, 2006 | 01:18 PM
Kevlo911's Avatar
Kevlo for President
I used my bicuspids
Old Aug 16, 2006 | 02:07 PM
irish44j's Avatar
retired moderator
which BBK?
Old Aug 16, 2006 | 02:13 PM
glenmoormax's Avatar
10 psi
Im guessing the 300zx caliper+13" cobra rotors one. I cut them off with a sawzall. it worked. you could hammer the **** out of them if you wanted too... seen that too.
Old Aug 16, 2006 | 02:20 PM
Kevlo911's Avatar
Kevlo for President
I used pliers and just bent the shield flat
Old Aug 16, 2006 | 02:30 PM
Jeff92se's Avatar
I'm needing a caw
3-gens invert back so it's alot less trouble. But I used a grinder w/ a cut off wheel. You could also slice slots in there and bend it like beckem
Old Aug 16, 2006 | 06:39 PM
ColdSHO's Avatar
one unbolted, the other just kinda rusted/bent off. that and a dremel halped a bit too.
Old Aug 16, 2006 | 07:03 PM
Zack342's Avatar
they are bolted on?
Old Aug 16, 2006 | 08:55 PM
abci30's Avatar
oh noes!!!!1111
i made a cut/slit where there is an opening in the shield and then banged the shield up and down to enlarge the cut/slit until it was big enough to slide off of the hub
abci30's Avatar
oh noes!!!!1111
opps double post
Old Aug 16, 2006 | 09:17 PM
Nealoc187's Avatar
SLOW
One I cut off with tin snips... talk about annoying. Not at all easy and my hands hurt pretty badly afterwards. The other I zipped off with an air chisel the next day at the shop, took all of about 2 minutes that time.
Old Aug 17, 2006 | 07:26 AM
Larrio Motors's Avatar
Boss Chen Industries
cut into them, bent them back and completely off. good luck
Old Aug 17, 2006 | 08:09 AM
Broaner's Avatar
2060lbs and falling...
Slid them off when I had the hub off. Pretty easy that way. LOL.
Old Aug 21, 2006 | 02:42 AM
MrGone's Avatar
so you aren't running any at all?
Old Aug 21, 2006 | 07:04 AM
Not the stock ones, they wouldn't clear the AP rotors.... the clearance is too tight.
Old Aug 31, 2006 | 08:40 PM
vsamoylov
didnt have to do anything to them
Old Aug 31, 2006 | 09:31 PM
irish44j's Avatar
retired moderator
i didn't have to cut mine either...
Old Aug 31, 2006 | 10:52 PM
Nealoc187's Avatar
SLOW
I just removed my second set the other day. I removed the first set from my black NA car back years ago as stated. this time, I just took off the rotor, and pried a littled bit with a pry bar and screwdriver to deform the metal a little bit, then banged around with a hammer back towards my body, a little banging here and a little prying there and I had them knocked loose. Couple minutes at most. Then it was just a matter of cutting the thinnest part of the metal with tin snips which is easy, then using pliers or channel locks to bend the metal around to get it off the steering knuckle. Probably took 20 minutes total to complete both sides.
Old Sep 1, 2006 | 09:05 PM
95maxrider's Avatar
Lightly modded
I did the same thing as you. It was much faster than trying to use dremel all the way around.
Old Sep 2, 2006 | 10:21 PM
Zack342's Avatar
Looks like a good idea
BkGreen97
Apr 2, 2016 05:47 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Noela
Sep 26, 2015 08:22 AM
worldwiderecognized
Sep 24, 2015 06:56 PM
