THE BBK PiCTURE THREAD (Show off your BBK setup here)
Brembo BBK... same as blackbird and wizard, traded my old auto tranny for them
18x8 +41 Volk III
repainted the calipers and put new decals on. also repainted the rotor hats. this was a used set with alot of wear on it... but after a quick rebuild. i think its still the best brakes for our maximas.
future mods: stop tech rotor rings and stop tech pads.
18x8 +41 Volk III
been searching for information on installing G35 Brembo's on a 5th gen. Running Enkei G37 19" rims in the summer, but will likely want to run stock 17" AE (2001) rims in winter.
Anyone done this?
Anyone done this?
My Stillen:Brake Pros: AP Racing Set-up. 17' OZ Ultraleggera over the 13' Floating 2-piece cross-drilled/slotted Rotor set-up. Kumho Ecsta High Performance All Season Tires wrap up the package and allow traction in the worst New York City Weather/ Potholes. Hawk HPS Pads/Baer Decelarotors/Goodridge Lines are lining up the rear.Best Brake Set-up I've had yet. Serious whiplash!
may I know what is your rim's offset?
I am very interested with this BBK, but I don't know whether it can fit with my 17" 350z rims or not.
yes, no problem, 40mm offset. I had sent the template from Brake-Pro's to the guys at TireRack, and I told them which wheel I wanted. They let me know a few hours later that it would work with this specific wheel. Your best bet is to get a template from Stillen, cut out the emailed template, paste it onto a piece of cardboard, and measure it against your wheel...the clearance on my set-up is ultra close...
Dude my 8 piston bbk dude is sick. It has a little turbocharger on each caliper with a little radiator. Stays super cold and the brakes stop sooooo fast when the little turbos spool up.
thanks for your reply Sir
would contact them directly
Here is a pic of my front brake setup. Racing Brakes front BBK using stock OEM calipers. Comes with bracket and 12.8" front slotted and drilled rotors:
I have a 12" rear BBK too, just have to take pics of that one as well. Will post later.
this is a nice cost effective bbk setup... did braking improve with just the rotors?
