Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Progress Springs just arrived!!!
Old Feb 24, 2007 | 05:25 AM
mikey chalupa's Avatar
I finally got my Progress springs from Cattman yesterday! I can't wait to get them on. My shocks come in on Monday. I'll be doing the install next weekend if it isn't too cold.
Old Feb 24, 2007 | 11:45 AM
matts95max's Avatar
what struts did you get?
Old Feb 24, 2007 | 11:59 AM
I went with GR-2's. I was gonna go with AGX but I really don't want to adjust them once they are installed.
Old Feb 24, 2007 | 12:14 PM
Kevlo911's Avatar
Kevlo for President
Ride will be kinda rough but the handling will be NICE.
Old Feb 24, 2007 | 02:57 PM
Yeah I know the ride will be rough. I also got a set of G35 coupe 17's from eBay for $245. I will install the springs, struts/shocks, and wheels next weekend. I can't wait.
Old Feb 24, 2007 | 04:59 PM
!PrjctMax!'s Avatar
I have progress springs/KYB GR-2's and the ride isn't rough... I guess it's just personal preference and how you feel it.
Old Feb 24, 2007 | 11:03 PM
d00df00d's Avatar
Old enuf to pick his own gears
You have a 6th gen. He has a 4th gen. Different animals...
Old Feb 25, 2007 | 08:25 AM
Kevlo911's Avatar
Kevlo for President
Yes one had a 2x4 chassis and one has a 1x4 chassis if makes any sense to you
Old Feb 25, 2007 | 08:42 AM
!PrjctMax!'s Avatar
I guess it doesn't
Old Feb 25, 2007 | 09:01 AM
d00df00d's Avatar
It basically means the 6th gen has a stiffer frame, which helps ride comfort.
You also have to consider that the weights and suspension geometries are different, and that Progress and KYB will design their suspension products differently for each car. Wheels and tires will be a big factor as well. Plus, as you said, it's a personal preference thing on top of all that.
So, the fact that you are okay with Progress/GR-2 doesn't mean someone else with a 4th gen will be.
Does THAT make sense?
Old Feb 25, 2007 | 09:46 AM
Hopefully it won't be too rough. I'm also changing out both axles( I'm starting to hear the popping noises) as well as put on the g35 coupe 17's with 235/45/17. Anything is better than I have now. All of my shocks are blown right now.
Old Feb 25, 2007 | 10:22 AM
!PrjctMax!'s Avatar
yes, thank you
Old Feb 25, 2007 | 03:21 PM
GodFather's Avatar
Made in Taiwan
Of our 6 maxima's:
1) 95 manual: maxspeed w/tokico HP's, rough everywhere, performs great, very stiff. Feels every bump on the road. 2000 Millenia 16" wheel/tires.
2) 97 automatic: Stock spring w/stock struts, soft everywhere, performs like a boat, doesn't pick up much bumps from the road. Factory wheels/tires.
3) 95 5-speed converted: H&R springs w/Kyb GR2's, average softness, not too stiff at all, performs great, semi-sensitive to every bump on the road, just not as bad as the maxspeed combo above. Factory 16" SE wheels/tires.
4) 96 automatic: Tein S-tech springs w/Tokico HP's, factory like softness, but stiff against turns, performs great compromising factory feel with confort on the road. Doesn't pick up small bumps and cracks on the road as bad as any other aftermarket combo. But when it comes to big bores on the road, this thing shocks pretty hard just like the other combo's. This is by far the best combo I liked so far because of its ride comfort and aggressive stiffness when it comes to turning. Used with Factory 15" honeycomb wheels/tires.
5) 00 3.5 swapped maxima: Coilover combo, not sure what kind, very stiff and very harsh to anything on the roads. Turning was a problem due to fender grinding till we raised it back up to allow at least an 1.7" gap. We are tired of this setup, but it looks too good to be removed. Used with 04 SE 18" rims/tires, and tires wear out easily in 4 months.
6) 95 automatic: bone stock, boat, boat, boat...Nothing else, comfort w/no performance in corners.
I got a spare set of brand new H&R springs w/KYB AGX struts to be tried out, but I'm waiting for a new set of suspension assembly accessories to combo this up without breaking up the existing sets already on the cars.
Above are the setups and reviews of what we have in my family. All the combo's are still on each of the cars I just described.
-Peter-
Old Feb 25, 2007 | 03:28 PM
I think the Progress springs are comparable to the H&R or the S-techs IMO.
Old Feb 25, 2007 | 04:17 PM
GodFather's Avatar
Made in Taiwan
I'm thinking the same, but for now, I have every reason to believe that S-tech's a tad bit softer than H&R's at minor bumps, but are as stiff as H&R's when it comes to hard corners. That's just the way I feel comparing both cars we got those setups with.
-Peter-
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
MaxiNoob98
Oct 2, 2015 10:13 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
followthadollar
Sep 27, 2015 01:06 PM
