Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Can't Budge Torque Member Bolts
Old Mar 10, 2007 | 02:29 PM
clayman88's Avatar
Hey Guys,
I need some help and suggestions. I'm installing new Brembo blanks & Hawk HPS' right now. I've got the caliper off the front no problem, but for the life of me I can't budge the two torque member bolts. I've tugged as hard as I can & they won't budge. I don't have access to an impact wrench & even if I did I don't know that there would be room to use one.
Any suggestions? Thanks!
Old Mar 10, 2007 | 03:26 PM
RA030726's Avatar
I'm nutty for Nissans
The long pipe over the ratchet trick to gain leverage. Hit them with a penetrator like PB blaster and let them soak. Last ditch effort is heat.
Old Mar 10, 2007 | 03:29 PM
clayman88's Avatar
I got some PB Blaster & hit it with that a few times, but still no luck. If I can find a pipe or a breaker bar, I'll give that a try too. I'm not too sure how I can fit a breaker bar or pipe into that spot though. It doesn't look like theres gonna be room.
Old Mar 10, 2007 | 03:31 PM
michaelnyden's Avatar
what you can do is heat the torque member around the bolts so they expand more than the bolts...exhaust shops do it when you have a rusted stuck bolt....the other option is if you can't fit a breaker bar in there, you put the wrench on there and hit the wrench with a mallet.
Old Mar 11, 2007 | 10:21 AM
NisMoN00B's Avatar
+Cru OG
This is what I did yesterday after spraying/soaking the bolts with WD40 for 20 mins.
Old Mar 11, 2007 | 01:28 PM
clayman88's Avatar
Success!! After eltting 'em sit over night, I hit them again with a few more shots of PB Blaster and was able to finally bust them lose. I feel stupid, but while I was laying in bed this morning I realized it would be a whole lot easier if I turned the wheel all the way towards me. Made a big difference in getting more leverage. Thanks for the advice, guys!
I'll let you know how it all goes once i'm done.
Old Mar 11, 2007 | 02:08 PM
Kevlo911's Avatar
Kevlo for President
I think you need to hit up the gym
Old Mar 11, 2007 | 03:25 PM
clayman88's Avatar
Another question, is it a problem that the Hawk pads only have wear indicators on two of them? The oem pads had wear indicator clips on all four.
Old Mar 11, 2007 | 03:26 PM
clayman88's Avatar
Probably true.
Old Mar 11, 2007 | 05:22 PM
clayman88's Avatar
Well, I got them on finally. I used one of the pads with the wear indicator on either side. I just took my first test drive & I was going to do the hard stops per the bed-in procedures, but I'm getting a really strange noise that has me worried. I pulled over because it didn't sound good at all.
Its hard to describe, but sometimes I hear a grinding noise about every half second. I start hearing it when I get over 15 mph, but other times when I was driving through my neighborhood I couldn't really hear it. I'm pretty sure that I torqued all the bolts down properly.
Any ideas??
Old Mar 11, 2007 | 08:00 PM
Nealoc187's Avatar
SLOW
Well obviously you figured out the "turn the wheel" trick... so that's good I guess lol
As for the noise maybe you bumped the dust shields so they are just barely scraping against the rotor?
Old Mar 11, 2007 | 08:25 PM
clayman88's Avatar
It's possible. I'll have to take a look at that.
Old Mar 12, 2007 | 07:49 AM
clayman88's Avatar
Alright, this morning the noise seemed to go away within 20 seconds of driving it. From that point on, everything was fine. The stopping power with the Brembo blanks & Hawk's is definitely stronger than the OEM. Most importantly, my irritating shimmy in the wheel is gone!!
Thanks for the advice. This was my first break job so it was a good learning experience for me. I'm pretty sure if I had to do it again, I could get it done in half the time.
Old Mar 15, 2007 | 07:52 PM
Matt93SE's Avatar
STFU n00b!
Last time I did a set of pads on stock calipers, it took me 6 min from start to finish. both sides. started w/ car on ground.... and it was raining....
litch
123
Jan 4, 2024 07:01 PM
mclasser
22
Nov 12, 2020 01:58 PM
Apr 16, 2020 05:15 AM
RealityCheck
Oct 2, 2015 06:34 PM
