Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Why I Do Not Like KYG
Old Mar 12, 2007 | 08:24 PM
knapp9's Avatar
I guess it's true...to do a job right, do it yourself!
For 3 years & 30K miles now I've been suffering a stiff, noisy ride in my '01 Maxima with "new" KYB GR2's (mistake #1). So I finally bit the bullet and went back to Nissan oem (Tokico made) struts and springs this week. While I was at it, I replaced the KYB mounts I originally bought (mistake #2) for the KYB struts .
While I was messing around with the install job, I compared the pressure it took to compress the KYB's vs the Nissan oem struts. Wish I had a video instead of the photos that follow. Many have posted that the KYB's are @15%, or so, stiffer than oem. I believe it. These 2 photos show an equal amount of pressure...as best I could apply...to both the Nissan struts (black colored below) and KYB struts. The Nissan compressed much easier and retracted sooner than the stiffer KYB's.
Before...
After...
I kept hearing a knocking noise ever since the KYB's were installed that I've never been able to fix. When I pulled the old KYB mount I'm pretty sure I saw the reason for all that noise. The KYB mount (left side) did not have the gray colored shank like is attached to the bottom of the Nissan oem mount (right side). That shank seats the mount to the top of the strut rod. The shop that installed (mistake #3) my KYB's simply put in 3-4 washer shims under the top strut bolts and never said a word that the mounts were different. Arrgh!
Oh well, live and learn.
Old Mar 12, 2007 | 08:40 PM
Kevlo911's Avatar
Kevlo for President
What springs did you have with the GR2's?
I agree that the KYB mounts suck tho.
Old Mar 12, 2007 | 08:46 PM
knapp9's Avatar
The original factory installed springs were on with the KYB's. The car has 105K miles on it now, so I replaced the springs with the new struts. I guess there was a TSB on the rear springs for bottoming out, and I got the "approved" rear replacement springs. Raised the car an inch in the rear after I put them on. Tomorrow night I'll put the last front strut in and take it for a spin.
Old Mar 12, 2007 | 08:53 PM
Kevlo911's Avatar
Kevlo for President
Wow that sucks for real. The KYB's have a lifetime warranty if you wanna get a spare set to sell to make up for the cost.
Old Mar 13, 2007 | 06:57 PM
knapp9's Avatar
Finished the job tonight and took the car for a test ride. I thought the ride was much nicer and more comfortable. Less jittery. But after 100K, it could be to the new springs as much as the struts for all I know. Anyway, very glad I went to all that work and changed out the set up.
Old Mar 13, 2007 | 08:13 PM
OOmaxSE's Avatar
WOW, I had the EXACT same problem. I bought the car used with KYB GR2's and they had these stupid mounts. Had them on the car and replaced every single part and finally found that this was the issue. I had a rough and rattling front end. I guess my previous owner went all out on the KYB front suspension "upgrade." It sucks for sure. You'll enjoy your new mounts!!!
These mounts are probably for the 4g because you can notice the difference in the strut rod slot. KYB is round and OE is "cut off" a bit.
Old Mar 21, 2007 | 07:09 PM
young1976's Avatar
I guess this is good info to know. Avoid the KYB strut mounts, what about Tokico mounts and the Monroe mounts you can get at say Pep Boys? Any idea what the oem mounts cost?
Old Mar 21, 2007 | 07:19 PM
knapp9's Avatar
The Nissan mount insulators cost $29 plus shipping from DaveB. I believe the KYB mounts were @ $36-38, plus shipping from TireRack three years ago. I think any brand of insulator would do as long as it matches the oem design....which the KYB's clearly did not in this application.
colombianmaxima
Jan 4, 2012 03:58 AM
colombianmaxima
Oct 1, 2011 12:29 PM
sleepermaxima
51
May 16, 2009 06:49 PM
Pri63
Jul 5, 2006 12:25 PM
Pappa Grande
Apr 23, 2002 08:41 PM
