Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Setting A32 rear beam.
Old May 13, 2007 | 09:45 AM
Fr33way™'s Avatar
Wild for Width
When the rear end of the car is in the air, one side of the beam appears lower than the other. Is there a way to adjust/fix this? Thanks for any advice.
Old May 13, 2007 | 10:28 AM
Kevlo911's Avatar
Kevlo for President
Nope I am pretty sure they are all like that(on unlevel ground IIRC), do you have an RSB?
Old May 13, 2007 | 02:13 PM
98SEBlackMax's Avatar
Maxima.org Insomniac
http://forums.maxima.org/showpost.ph...2&postcount=18
Old May 13, 2007 | 02:43 PM
LA02MAX's Avatar
Originally Posted by 98SEBlackMax
That's a good thing to do, but I think what the OP is describing is perfectly normal.
If you notice, the trailing arm is off center toward the right. The uneven weight distribution of the rear beam (and all the other unsprung mass involved) causes the left to be a bit lower than the right when it's in the air...
Old May 13, 2007 | 05:17 PM
Fr33way™'s Avatar
Wild for Width
Any other opinions? If it's normal I feel no need to adjust it, but the car has been on D2's and S-Techs so the bushings could be binding as Larrio mentioned.
Matt93SE
May 24, 2019 02:58 PM
Matt93SE
Apr 8, 2018 09:23 AM
schmellyfart
Sep 25, 2015 04:47 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
