Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
ES Bushings Install with LTB
Old Oct 15, 2007 | 03:12 PM
SilverGLE's Avatar
I'm watching you, boy...
Call me an idiot, but I suck at identifying suspension parts beyond spring-strut and sway bars-axles... Anyway, I intend to eventually install my Stage 1 LTB and am wondering exactly what bushings I should upgrade... I am assuming that it would be the LCA bushings? FWIW, 2k Max with 113.5k and no bushings or similar parts replaced or upgraded.
Old Oct 16, 2007 | 09:00 PM
Shogunsc4's Avatar
yup, the Lower Control Arm Bushing. PITA to install though. It's not necessary to replace but recommended. And be ready for them to squeak in cold weather.
Old Oct 16, 2007 | 11:35 PM
SilverGLE's Avatar
^ Thanks, that's what I thought! Sheesh, PITA is not something I want to tackle right now. And squeaking in cold weather? As if my suspension needs to make any more noise... Damn front struts and springs have been squeaking slight and getting progressively more noticeable at slow speeds.
Old Oct 17, 2007 | 09:02 AM
Puppetmaster's Avatar
Most would recommend just picking up a new/used set of LCAs, installing the bushings, then just swapping those out with your current LCAs. I guess you could then try to sell the old LCAs someplace.
Old Oct 17, 2007 | 10:37 AM
Matt93SE's Avatar
STFU n00b!
I've had the same set of ES bushings on my car for over 5 years and they don't squeak. :shrug:
for the eS bushing install, see my writeup I did a while back for the 3rd gen control arms. keep in mind the installation part will be simple- the ES bushings press in by hand or using simple hand tools.. getting the old bushings out is the PITA.
http://blehmco.com/faq/control_arm_b...placement.html
Old Oct 17, 2007 | 05:37 PM
irish44j's Avatar
retired moderator
mine have never squeaked, and I drive INTO the snow all the time
Old Oct 17, 2007 | 05:54 PM
Greeny's Avatar
¯\(°_o)/¯
No squeaking here either..
Old Oct 17, 2007 | 08:35 PM
Shogunsc4's Avatar
hmm....for some reason mine squeaks ever since the first winter it was installed. When it is warm outside...no noise. Maybe bad bushing?
Old Oct 17, 2007 | 09:55 PM
G4nismo's Avatar
i'm guessing this applies for the fourth gen as well?
Old Oct 18, 2007 | 12:27 AM
SilverGLE's Avatar
Sweet, thanks! I'll have to decide if/how I want to tackle this... Using the blowtorch to burn out the old bushings looks like fun!
Old Oct 18, 2007 | 05:28 AM
Greeny's Avatar
¯\(°_o)/¯
Whoever installed the bushings most likely didn't use enough bushing lube,you need to be very generous with the lube before installation,otherwise they will squeak.
Old Oct 18, 2007 | 06:41 AM
97SEdriver's Avatar
this place is dead
you can cheat like I did and just pay a machine shop to get the old bushings out and press the new ones in.
If you remove the LCA's yourself, call ahead to make sure they have time, shouldn't take them more than a few hours (including lunch break).
Old Oct 18, 2007 | 09:45 AM
MorpheusZero's Avatar
This also applies if you have a squeaky girlfriend
Old Oct 18, 2007 | 10:22 AM
Greeny's Avatar
¯\(°_o)/¯
I knew that one was coming.
AcuraLegend
Oct 17, 2016 08:47 PM
Starrider
Dec 18, 2015 04:43 AM
AcuraLegend
Sep 22, 2015 04:22 PM
2kmaximel
Sep 16, 2015 03:19 PM
Bonka
Sep 14, 2015 11:18 PM
