Sponsored by:
Sponsored by: CARiD
3" PVC MAF Project. Works fine.
Old Jun 27, 2006 | 06:11 PM
  #41
96sleeper's Avatar
Originally Posted by Kevlo911
Why wont it work? As long as the sensor or "wire" isnt cut he should be fine.
it is a wire that was cut, been there done that, mine didn't work.
Old Jun 28, 2006 | 04:19 AM
  #42
RA030726's Avatar
I'm nutty for Nissans
Originally Posted by nismology
I wouldn't use the hot-wire without that little "housing" it has. I'm sure it's there to smooth out the airflow entering the MAF or something else that's purposeful.
True and that explains the rough idle I get only with that MAF. But if you look at other MAF's some do have an exposed hot wire. I looked at a bunch of MAFs before doing this. If I did it again I would leave some of the plastic in the center covering the brown part and some for the hot wire.
Old Jun 28, 2006 | 05:26 AM
  #43
96sleeper's Avatar
like this?
http://members.verizon.net/~vze4yqyk/PortedMAF.jpg
Old Jun 28, 2006 | 09:14 AM
  #44
RA030726's Avatar
Hey yea thats pretty nice! Is it yours?
Old Jun 28, 2006 | 09:50 AM
  #45
96sleeper's Avatar
similar to mine, but the picture is mardigrasmax's from a long time ago.
Old Jun 28, 2006 | 11:33 AM
  #46
krismax's Avatar
Father of the 00 VI
well i bored the stock tube out to 2.85-2.90 inch i can easily get the stock maf to 3 inch iam gonna try to find some spare mafs to play with . maybe i can resin that plastic section back in after i bore it?! Id like to bore it to 3 inch
any one have any broken mafs they want to sell me so i can play
Old Jun 28, 2006 | 11:51 AM
  #47
RA030726's Avatar
May as well put the hot wire in a 3" tube like Jime, unless you are trying to appear stock.
Old Jun 28, 2006 | 12:05 PM
  #48
Glude's Avatar
So from what ive read it seems that you need a good source of engine management to even attempt to run a larger MAF or benefit from one?
Old Jun 28, 2006 | 12:20 PM
  #49
NmexMAX's Avatar
dot dot dot ...
SR20DEN bumped these threads for a reason.... So YES
Old Jun 28, 2006 | 12:39 PM
  #50
RA030726's Avatar
Yea if you tweek the injectors, FP, ignition, MAF, or any combo you will need to make adjustments to the ECU. Sometimes you can get a fairly decent tune with matched parts ie: 300zx MAF and injectors without touching the computer. But even from the factory there is power to make with real tuning.
Old Jun 28, 2006 | 12:47 PM
  #51
Glude's Avatar
Cool, seems a little extreme for me at this point. Good to know though, maybe I will attempt this in the distant future once I know a good bit more about tuning. Id hate to get in over my head at this point in time.
Old Jun 28, 2006 | 07:38 PM
  #52
MrGone's Avatar
bah, who needs a MAF anyway
Old Jun 29, 2006 | 07:18 AM
  #53
Jay_pee99's Avatar
Man, I got so many ideas from this thread!! Looks like i'l be experimenting on my car when i get off. Weird thing is most of these mods are simple things that i would have never thought of.
Old Jun 29, 2006 | 07:24 AM
  #54
Jay_pee99's Avatar
I guess my question would be, could you do these mods [bigger MAF, TB porting +tunning] without killing the stock injectors? I know upgrading would be best. Just trying to see what i can get away with!
Old Jun 29, 2006 | 12:32 PM
  #55
NmexMAX's Avatar
dot dot dot ...
No, the stock injectors will be fine, but you need to add fuel in there so you can pull more V from the MAF resulting in added timing via the ECU so it (ECU) goes into a different timing cell.
The amount of fuel taken out (MAF V) seems to be proportional to the timing added.
Old Jun 29, 2006 | 12:44 PM
  #56
nismology's Avatar
You don't add fuel to indirectly add more timing. The added timing is just a side effect of the lower MAF voltage. You add fuel so you don't run lean.
Old Feb 23, 2007 | 03:10 PM
  #57
NmexMAX's Avatar
dot dot dot ...
Bump . . .
http://forums.maxima.org/showthread....af#post5503194
95Maxi
Aug 29, 2015 09:38 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
KGMtech
Aug 18, 2015 09:21 AM
kenc15
Aug 5, 2015 08:29 AM
kjm900r
Aug 5, 2015 07:14 AM
