Sponsored by:
Sponsored by: CARiD
Used Engine Break In?
Old Nov 24, 2004 | 10:49 PM
Nismo3112's Avatar
Custom User Title
I will be installing a newer engine over Christmas break w/ 32k on it. The thing is that I will not know how long this engine has been sitting in the salvage yard.
After installation, what sort of precautions should I take? Like flushing the motor oil? Any special procedures to start it up for the first time?
Old Nov 25, 2004 | 11:27 AM
SR20DEN's Avatar
VQ Wizard
Refill it with 5w-30 Castrol GTX and install a new oil filter. Put about 100-250 miles on it and change the oil and filter again.
Old Nov 25, 2004 | 12:50 PM
goodhead's Avatar
is it smart to do an engine flush or seafoam the enigne during the 250 miles first oil change or shoudl it be doen at a later time?
Old Nov 25, 2004 | 12:57 PM
SR20DEN's Avatar
VQ Wizard
I am still not convinced of the whole seafoam ordeal. You can clean an engine just fine with a premature oil change interval.
Old Nov 25, 2004 | 03:53 PM
DAVE Sz's Avatar
Hooooooonda.....
Seafoam is ****. I said a while back that it was great when I first used it. I don't know why I said it, it makes no difference whatsoever. I do like the ATF in the spark plug holes though. Nasty black smoke came out the first time I did it.
Old Nov 25, 2004 | 09:08 PM
Maxtank's Avatar
Can you elaborate on the ATF in the spark plugs holes?
Old Nov 26, 2004 | 03:07 PM
Ninos_Maxima's Avatar
be the change u want2C
Yeah Id like to hear this spark plug ordieal thingy to, sounds cool!
Old Nov 26, 2004 | 06:40 PM
95BLKMAX's Avatar
I know some people use ATF instad of motor flush. Since ATF has so many detergents it's like a mild motor flush. You'd use it the same way as a motor flush. The other thing is using deisel as motor flush, but unlike running the motor for 5mins, you shouldn't use it for no more than 1 minute, cus that's some strong stuff.
I too like the idea of pouring a little ATF down the spark plug tubes.
Old Nov 29, 2004 | 05:49 AM
Ok how much atf do you poor down though, can someone give us an All Mighty Write Up pleeeeeeeeeeeeeeease
Old Nov 29, 2004 | 08:47 AM
SR20DEN's Avatar
VQ Wizard
A writeup on that? omg...
shilov
Feb 19, 2024 09:40 PM
jchronis2552
Sep 21, 2015 05:52 AM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
lowpost99
Sep 8, 2015 05:06 AM
