Sponsored by:
Sponsored by: CARiD
potential and future planing
Old Dec 1, 2004 | 11:02 AM
joeyicu's Avatar
all right, well, the maxima for now is my daily driven reliable vehicle, well im curious as to what i can expect out the car for when the T-bird is done, or i get a 3rd car
i was thinking about trying to get the maximum performance out of the 3.0 all motor
what kind of work could be done to it?
im looking information on
-who makes a good tune for the car
-witch nissan 3.0 family heads are the best to put attom an n/a setup (stock ones ported, or grab heads from another 3.0 based nissan car have them ported and go with that)
-what the stock motor can rev to safely (i was figruing a 7100 rpm redline might be fine, but im not totaly sure)
-how strong the bottom end of my current engine actually is
-if you can use nissan spare parts up the compression ratio (as in head "a" has less combustion chamber area then head "b" on my car stock)
-how strong the stock 5spd is, if it would need work if i wanted to step the cars engine up
can anyone help me, or have examples of a good engine build, i would like to see this car become very quick and reliable with alot of reving capabilities
Old Dec 3, 2004 | 09:03 AM
joeyicu's Avatar
any answers? no one?
Old Dec 3, 2004 | 05:56 PM
Pimpmobile's Avatar
-tune? If you mean the ECU tune then jim wolf tech, it adds 10 ish whp and can custom map for bigger injectors and higher redline
-the only other 3L VQs are the DD and the DET, cant use the DD unless you convert your whole fule system and the DET may flow more but not sure
-7200rmp is what most people set their rev limiter at 8000rpm has been done but not sure how long that will last
-hal is putting down 600whp/610+wtq on stock internals, but he is the max trubo master
-ummm, swap the 3.5L bottom end from a newer maxima and youll have 3.5L and 12.5:1 compression other than that I dont think there is a easy swap to get higher compression, cant use the 3.5L heads due to the cariable cams
-holds well, but definatly not bulletproof, people have shredded 3rd gear with minimal bolt ons, better off with a 2000+5spd or a 2002+ 6spd and upgraded clutch
hope that helps
Old Dec 3, 2004 | 09:29 PM
joeyicu's Avatar
i have a 2000 5spd car... and the JWT chip i found only lists for 95-99 cars, so 00 isnt suported right?
Old Dec 4, 2004 | 05:08 AM
Pimpmobile's Avatar
JWT doesnt do 00 yet, but technosquare may do it
hope that helps
cariable cams=variable cams
Old Dec 4, 2004 | 05:57 AM
Nealoc187's Avatar
SLOW
3.0 heads on a 3.5 shortblock results in 11.6:1 compression
To the original guy, the only heads that will work are VQ heads. There have been some good discussions on the things you are asking about, check out some of the other threads in this section.
Old Dec 4, 2004 | 06:27 AM
TILLEYS99's Avatar
Lives in a 11sec maxima
How fast do you want your car? do you want torque? or just high rpm hp? Do you wanna change displacement ? If your not up to doing the stuff your self or have ?s feel free too call me im in PA....
Old Dec 4, 2004 | 06:38 AM
Pimpmobile's Avatar
well there ya go
Maxboy23
55
May 1, 2025 06:09 PM
user 11122324
42
Jul 18, 2022 03:35 PM
Maxboy23
Sep 9, 2015 10:37 AM
sdotcarter
Sep 2, 2015 09:53 PM
