Sponsored by:
Sponsored by: CARiD
Its Alive!!!!
Old Dec 24, 2004 | 01:32 PM
  #41
SR20DEN's Avatar
VQ Wizard
If only I had cams........... and 7500rpm.
Old Dec 24, 2004 | 02:05 PM
  #42
Kevlo911's Avatar
Kevlo for President
Nice IACV piping
Old Dec 24, 2004 | 04:23 PM
  #43
NISMOPower's Avatar
Can you list your setup or is there a thread that has been started on it already???
Old Dec 24, 2004 | 06:15 PM
  #44
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
that is awesome!
Old Dec 24, 2004 | 06:29 PM
  #45
2 Da Max's Avatar
wow now thats an achievement
Old Dec 24, 2004 | 07:12 PM
  #46
95maxrider's Avatar
Lightly modded
Congrats on the swap and getting it to work with the 95 ECU. Are you gonna send it to JWT or tune it with something else? What plans are in store for this car? NA build or FI?
I don't understand why some people have such bad traction issues. Granted, right now my car is pretty close to stock (no nitrous yet), but I've driven a SC'ed 96 5 speed that traps as like 111 mph, and I didn't really have any tractions issues, even in first gear. All my traction issues went away with the PR motor mounts. Might want to look into fabbing up some poly mounts for your cars. They made a huge difference in my boring car.
And BTW, why dyno? It will just look like a normal 2k2 dyno (aside from differences from the ECU/furl rail etc).
Old Dec 24, 2004 | 07:18 PM
  #47
Nismo3112's Avatar
Custom User Title
I have a 95 GLE 5spd, 180k miles, I/Y/E/P, and even with heavy 18's I can't seem to get traction in 1st either. I can't imagine a 3.5 liter. Maybe its time for an LSD.
OT: I just noticed that my sig pic goes well with my status under my username. Pretty wierd!!!
Old Dec 24, 2004 | 10:24 PM
  #48
rubicinc's Avatar
I have some questions:
Why did you use 95 ECU? Would it work with 97 or 2002 ECU?
Did you have to splice harness?
Old Dec 25, 2004 | 11:59 AM
  #49
krismax's Avatar
Father of the 00 VI
You'll need them
Old Dec 25, 2004 | 12:58 PM
  #50
SR20DEN's Avatar
VQ Wizard
Originally Posted by krismax
You'll need them
Old Dec 25, 2004 | 01:03 PM
  #51
Ninos_Maxima's Avatar
be the change u want2C
would the 2k1 manifold fit on that 3.5top? would that make any gains,
But yeah I hate your creation, cause its simply beautiful
Old Dec 25, 2004 | 01:08 PM
  #52
Nismo3112's Avatar
Custom User Title
I think the 00VI would be more restrictive than the stock 3.5 IM
Old Dec 25, 2004 | 01:28 PM
  #53
TILLEYS99's Avatar
Lives in a 11sec maxima
Well its still running good and i spanked a new mustang bad
Old Dec 25, 2004 | 02:01 PM
  #54
japmaxSE's Avatar
Go Get a Life!
Honostly Rob how would you compare the Hybrid to full 3.5 swap as far as butt dyno..???
Old Dec 25, 2004 | 02:03 PM
  #55
chuckie311's Avatar
when you pluged in the ecu did you have to swap any pins to get it to work or was it just plug and play..
Old Dec 25, 2004 | 02:27 PM
  #56
TILLEYS99's Avatar
I would say either way is good but full 3.5 is the way to go but you need to do twice as much to make it happen.
Old Dec 25, 2004 | 02:33 PM
  #57
japmaxSE's Avatar
Go Get a Life!
I knew you were going to say that.
Old Dec 25, 2004 | 08:42 PM
  #58
JClaw's Avatar
Tilley, do you think the difference is pretty steady along the powerband or is more low end than top or vise versa?
As for traction, would you consider PR motor mounts? I'm thinking about ordering 'em.
Old Dec 25, 2004 | 08:55 PM
  #59
TILLEYS99's Avatar
Get the PRs i got em. it has more topend power with the full motor.
Old Dec 26, 2004 | 01:20 PM
  #60
TILLEYS99's Avatar
ARP rod bolts are going in now
Old Dec 26, 2004 | 03:02 PM
  #61
Pimpmobile's Avatar
write up time tilley, I COMMAND YOU!
Old Dec 26, 2004 | 03:06 PM
  #62
TILLEYS99's Avatar
I dont have time on a write up this extensive.
Old Dec 26, 2004 | 03:22 PM
  #63
Jason R's Avatar
aka UNCDooD
nice work tilley.
Old Dec 26, 2004 | 07:20 PM
  #64
EugThinks's Avatar
Your car makes me moist.
Old Dec 27, 2004 | 08:49 AM
  #65
95BLKMAX's Avatar
I wanna see the dyno #s on this beast
Old Dec 27, 2004 | 12:05 PM
  #66
vsamoylov
so what about
e-gas?
gauge cluster? speed sensor?
maf sensor from 4th gen?
and it pulls to 135 mph? whats so special about that?
and what other cel you got?
Old Dec 27, 2004 | 12:09 PM
  #67
Nismo3112's Avatar
Custom User Title
pulls to 135mph as in alot faster than most.
Old Dec 27, 2004 | 12:30 PM
  #68
SR20DEN's Avatar
VQ Wizard
Originally Posted by vsamoylov
so what about
e-gas?
Is English your second language? He's been over this a dozen times already.
Old Dec 27, 2004 | 03:44 PM
  #69
subs1000w's Avatar
awsome news i bet its a beast
Old Dec 27, 2004 | 05:13 PM
  #70
DAREN's Avatar
so what about
e-gas?
he is using a 4th gen ecu and wire harness to run his VQ3.5
Old Dec 27, 2004 | 08:44 PM
  #71
TILLEYS99's Avatar
one CEL is cause the egr isnt hooked up other is cause i have a 95 ecu in a 97 and its a O2 sensor cel.
Old Dec 27, 2004 | 09:31 PM
  #72
meccanoble's Avatar
Sports Button FTW
amazing tilley, congrats...if my engine issue happened only a good month later, i would have been much happier than i am now
Old Dec 27, 2004 | 10:01 PM
  #73
vsamoylov
no ****. i understood that already. but there is the engine harness which is for the engine. the engine harness directly plugs into the ecu which in his case is the 4th gen. but there is another harness for the gauge cluster and the e-gas pedal and the speed sensor which runs off the abs unit/abs sensors. what did you do about those? everything else work in the car? you still using the bcm?
Old Dec 28, 2004 | 12:26 AM
  #74
gabex's Avatar
vsamoylov-so you used the 3.5 ecu, correct? hows that goin for you? do you have the vtc? ever dyno or go to the track?
Old Dec 28, 2004 | 05:22 AM
  #75
TILLEYS99's Avatar
Everything works great i had to swap some stuff around and use a 4th gen wiring harness. If you read around the all motor forum its all explained in there.
Old Dec 28, 2004 | 11:21 AM
  #76
vsamoylov
thanks, i just thought that this was the first thread about this swap.
and yes i did use the 3.5 ecu. the vtc works. i didnt hit the track or the dyno yet but i am planning on going january 8th with a guy from the org. i just hope the weather holds up here in cali.
Old Dec 28, 2004 | 11:23 AM
  #77
dmontzsta's Avatar
Ford Only.
Do you have a cell? is the VI working? How did you get around all the accessories that the 2k2 has compared to the 97?
Old Dec 28, 2004 | 02:17 PM
  #78
VIP Maxima
thats a low 14's car n/a
Old Dec 28, 2004 | 05:33 PM
  #79
TILLEYS99's Avatar
???? i alrady ran with les power and did a 13.87
Old Dec 28, 2004 | 06:13 PM
  #80
JClaw's Avatar
Mid 13s street tires, perhaps?
