Sponsored by:
Sponsored by: CARiD
Sizes of Various Throttle Bodies
Old Feb 6, 2005 | 11:48 PM
VQuick's Avatar
Chassis Freak
Help me fill in the blanks:
Throttle Body . . . . . . . . Diameter (mm)
VQ30DE
VQ30DE-K
VQ35DE
Pathfinder (VG or VQ?)
Which TBs will fit on a VQ30DE without too much trouble? How about the DE-K intake manifold (I plan to do the 2KVI mod)? How much bigger of a TB do you need for a N/A 4th gen? Is the Pathfinder TB overkill? Are there other factors?
Old Feb 7, 2005 | 05:09 AM
Stephen Max's Avatar
VQ30DE
VQ30DE-K
VQ35DE
The ones I know for sure are VQ30DE and DE-K = 60mm, Pathfinder VQ35 = 70mm.
For a NA VQ30 engine, a Pathfinder TB is overkill, unless maybe you had a variable intake and extended redline.
Old Feb 7, 2005 | 10:00 AM
VQuick's Avatar
Chassis Freak
Thanks. Is the Maxima VQ35 TB the same? I think Tilley said it was 75mm. I wonder how big the 350Z TB is.
Old Feb 7, 2005 | 12:34 PM
Kevlo911's Avatar
Kevlo for President
It is Drive By Wire, so no point of using...
Old Feb 7, 2005 | 03:17 PM
VQuick's Avatar
Chassis Freak
Ah yes. But the 2001 Pathfinder TB has a mechanical linkage?
Old Feb 7, 2005 | 05:39 PM
Yes. Here are some pix: http://forums.maxima.org/showthread.php?t=376130
Old Feb 8, 2005 | 09:20 PM
Broaner's Avatar
2060lbs and falling...
Thanks for posting this Tom. I always had the misconception that the 30DE TB was 63mm.
We'll see how the porting of my TB goes. I think there is a lot to be gained from reducing flow hindrances such as screw threads and rod size. I betcha its good for slight power. But hey, its free.
Old Nov 6, 2005 | 05:04 PM
japmaxSE's Avatar
Go Get a Life!
Ok this is what we have so far.
TB Sizes
95-99 VQ30DE: 60mm
00-01 VQ30DE-K: ??
02-03 VQ35DE: ??
04-06 VQ35DE: ??
00-01 Pathfinder VQ35DE 70mm? or 75mm?
02-06 350Z: ??
I know some have Drive by wire but it's interesting to know the sizes per app.
Old Nov 6, 2005 | 07:26 PM
VQuick's Avatar
Chassis Freak
You forgot the DE-K, which is also 60mm per StephenMax.
TB Sizes
95-99 VQ30DE: 60mm
00-01 VQ30DE-K: 60mm
02-03 VQ35DE: ??
04-06 VQ35DE: ??
00-01 Pathfinder VQ35DE: 70mm
02-06 350Z: ??
Old Nov 7, 2005 | 04:52 AM
95-99 VQ30DE: 60mm
02-03 VQ35DE: 70mm
04-06 VQ35DE: 70mm
02-06 350Z: Probably 70mm as well.
Old Nov 7, 2005 | 07:25 AM
95BLKMAX's Avatar
Originally Posted by Stephen Max
95-99 VQ30DE: 60mm
02-03 VQ35DE: 70mm
04-06 VQ35DE: 70mm
Good deal, soon as the 02-06 350Z TB size is comfirmed, this should be added to the stickies. Pretty useful info
Old Nov 7, 2005 | 08:31 AM
Nismo3112's Avatar
Custom User Title
What about the DBW TB on the Titan?
Old Nov 7, 2005 | 08:40 AM
vipervadim's Avatar
I like Maximas
The Q45 TB is 90mm with drive-by-cable but it's definitely overkill, unless maybe you're MardiGrasMax
but to add to the stickies
Old Nov 7, 2005 | 01:46 PM
JClaw's Avatar
It can be converted to cable using VQ30 brackets quite easily.
Old Nov 7, 2005 | 02:11 PM
Kevlo911's Avatar
Kevlo for President
Look at the date of my post
Old Nov 7, 2005 | 03:54 PM
Nismo3112's Avatar
Custom User Title
Wow, didn't know this thread was that old.
Old Nov 7, 2005 | 03:58 PM
RockfordMax's Avatar
Back from the dead
funny what can be done in 8 months!
Old Nov 7, 2005 | 06:29 PM
japmaxSE's Avatar
Go Get a Life!
Sweet How big is to big, I've been looking at several different Pathy's and 02'-06 VQ35DE'sTB's
Do you think I'll see any gains with the 70mm TB NA on race gas. I went back with the original MEVI.
Now thinking about it Jcalw might be right you can convert the DW. Has anyone done this?
Old Nov 7, 2005 | 08:29 PM
Nismo3112's Avatar
Custom User Title
Yeah, me and JClaw.
check the 3.5 FAQ
Old Nov 7, 2005 | 09:08 PM
vipervadim's Avatar
I like Maximas
you need the 70mm when you're putting much more air into the engine.. it is also great for top end, and responce is better..
if i recall you have the 3.5L cams, and with the MEVI so you would benefit from a larger TB.
my .02
Old Nov 8, 2005 | 05:46 AM
VQuick's Avatar
Chassis Freak
Just for comparison, since area = πr², the ratio of the areas is the ratio of the squares of their radii.
60mm = 900π mm²
70mm = 1225π mm²
So the 70 mm TB has 36% more capacity than the 60mm TB.
Old Nov 12, 2005 | 07:47 PM
ColdSHO's Avatar
ive got a q45 tb just laying around, but my cars mainly stock right now, so i think it would be useless, any of u guys want it, ill sell it really cheap.
Old Nov 13, 2005 | 02:37 PM
Broaner's Avatar
90mm is way too big for any of us as the IM couldn't be bored out enough to accept it. Custom IM would be required to utilize it.
Old Jan 4, 2007 | 05:42 AM
TDotMax's Avatar
Bumping this back up from the past. Has anyone camethrough and tried a different throttle body on their vq30de-k?
Old Jan 4, 2007 | 07:33 AM
grey99max's Avatar
LandShark has Cosworth
And has anyone measured any of the Xterra and Frontier TBs? I know they have dual cable attachments on the 2001 Xterra and 2003 Frontier, but they seem to be 60 mms....... They sure look like the Maxima TB..
REDinLV
Aug 15, 2024 12:30 AM
Miket2006
Mar 1, 2021 03:55 AM
knight_yyz
Nov 1, 2015 01:34 PM
