Sponsored by:
Sponsored by: CARiD
Fuel going to be ok?
Old Feb 21, 2005 | 07:52 PM
HarrisH's Avatar
I'm going with a full 3.5 soon, '00 VI, PF TB, and stock ECU, the OO VI has 290CC injectors, will the fuel pressure be ok? Will my ECU work fine with the full 3.5?
Old Feb 22, 2005 | 02:39 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
How are you planning to mate the VQ35 heads to the VQ30 DEK manifold?
What year car do you have?
Old Feb 22, 2005 | 06:28 PM
HarrisH's Avatar
'97 Rob Tilley (TILLEYS99) is going to do it, anyone have any answers to my questions... I know KRISMAX also mated the DEK manifold with full 3.5 on a '96.
Old Feb 22, 2005 | 06:35 PM
Kevlo911's Avatar
Kevlo for President
Chris had to do alot of modification to make it work...
You will be fine withhte larger injectors on 4th gen ECU. Mine is perfect, not running rich at all.
Old Feb 22, 2005 | 10:40 PM
SPiG's Avatar
SomePsychoGuy
why wouldn't you just use the VQ35 VIM?
Old Feb 23, 2005 | 01:48 PM
vsamoylov
that is my exact question. they say it flows better. maybe because they aren not using a full vq35 swap?
Old Mar 5, 2005 | 09:19 AM
Nismo3112's Avatar
Custom User Title
Is it true that the 3.5 injectors are smaller than the DE-K injectors, and with the 3.5 injectors, and rail, it will run lean on a 4th gen ECU?
IceY2K1? ( of injectors)
Old Mar 5, 2005 | 10:03 AM
Kevlo911's Avatar
Kevlo for President
270cc vs 290cc, I don't know if that 20cc will make a difference. They have the same part number, so if you buy new ones, they are prob 270cc.
Old Mar 5, 2005 | 01:57 PM
nismology's Avatar
3.5 injectors = DE-K injectors. The 3.5's just run at a higher fuel pressure.
Old Mar 5, 2005 | 03:42 PM
krismax's Avatar
Father of the 00 VI
wrong,the dek's are 350z injectors and on 3.5 are 315cc's
Actually whats funny is the 350z is using dek injstors because dek's used them first
Old Mar 5, 2005 | 05:20 PM
SR20DEN's Avatar
VQ Wizard
For the umteenth time
FBJC100 (VQ30DE-K and 350Z VQ35)
290cc/min @ 3.0 BAR (VQ30DE-K)
335cc/min @ 3.5 BAR (350Z, G35)
FBJC101 (FWD VQ35s)
270cc/min @ 3.0 BAR (No known application)
315cc/min @ 3.5 BAR (FWD VQ35s)
Old Mar 20, 2005 | 03:29 PM
JClaw's Avatar
What will the BAR be if we use all those parts off the 4th gen? Wouldn't it stay at 3.0 unless we used a fuel regulator? Wouldn't that be cheaper than buying 00-01 injectors, for what little difference it makes?
Old Mar 22, 2005 | 02:33 PM
IceY2K1's Avatar
3bar...if you have a Walbro, it would be higher/better. Just run the VQ35 Altima injectors you have with a Walbro and you'll be fine.
Running stock VQ30 3bar fuel pressure supports...
270cc@80% DC ~210whp
270cc@100%DC ~262whp
Running a Walbro 255lph HP at ~3.5bar fuel pressure supports...
315cc@80% DC ~245whp
315cc@100%DC ~306whp
Old Mar 22, 2005 | 02:46 PM
Nismo3112's Avatar
Custom User Title
Hi noobie here again, So you can change from 3.0 (44psi) bar to 3.5 bar (52psi) via an adjustable FPR, and an engine bay mounted fuel psi guage correct? Are these numbers at idle, or WOT?
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
msellas
Sep 23, 2015 09:16 PM
