Sponsored by:
Sponsored by: CARiD
01 motor in a 98 with 6 speed
Old Apr 2, 2005 | 06:03 PM
Nissan Shift
a friend of mine is thinkin of doin an 01 motor in a 98 with a 02 03 6 speed trany
the 01 motor has everything oovi etc
its a complete motor minus trany
can he use everyting that comes with the 01 motor on his 98 and slap his sc 3.12 on?
Old Apr 2, 2005 | 06:13 PM
plurco's Avatar
IIRC the 6 speed can be done, but it has something to do with useing a 4th gen case.
Old Apr 2, 2005 | 06:15 PM
Kevlo911's Avatar
Kevlo for President
6speed not worth the troubles. 5speed is better.
Old Apr 2, 2005 | 09:31 PM
JClaw's Avatar
Less drivetrain loss, rod driven, and seems more reliable than 6sp. Not to mention the stock flywheel weights 18 pounds versus 31.
Old Apr 3, 2005 | 09:39 AM
Nissan Shift
ok so what about a 01 motor with 01 5 speed droped in with oovi as is or do we have to take the vi out and stuff?
Old Apr 3, 2005 | 09:45 AM
Pimpmobile's Avatar
You can get the VI to work, just rig up a rpm switch. Why not just drop in a VQ35DE with the 5spd.
Old Apr 3, 2005 | 11:48 AM
JClaw's Avatar
Yeah just drop a 3.5 with a 5-speed. Everyone and their grandmother is doing it (including me).
The 01 5-speed LSD tranny is the best maxima transmission ever. Like our 4th gen 5-speed, but a few of the gears are reinforced, and it has a limited slip differencial. The split is better than the I30/Canadian maxima LSD, too. If I ever get my hands on one it's a keeper. Until then I'll fight with the steering.
Old Apr 4, 2005 | 06:43 AM
Nissan Shift
then what about my v2 supercharger lol
Old Apr 4, 2005 | 08:23 AM
Pimpmobile's Avatar
should bolt up?? the vq35de block is the same as the vq30de the outside ??
Old Apr 5, 2005 | 07:59 AM
Nissan Shift
so then i coulddo a vq35de supercharged?????
Old Apr 5, 2005 | 09:05 AM
allen222's Avatar
That would certainly make for one quick beast!
allen
Old Apr 27, 2005 | 08:37 AM
Jar's Avatar
Jar
what issues would be involved with using a 00 engine in a 98, what wiring would I have to mess with? would everything still work?
Old Apr 27, 2005 | 07:10 PM
JClaw's Avatar
If you use the 3.0 timing chain, gears and timing cover, yes it would. Judging by the 350z SC... with headers and a good exhaust system, it would put down about 400whp at base boost (7 psi I think). Now that's just ridiculous.
Old Apr 28, 2005 | 07:21 AM
Quicksilver's Avatar
OT n00bs FTMFCSL
That would be a great combo. Manual LSD tranny, VQ35, + S/C, in a 4th Gen...
Hello 12 second car (with some weight reduction).
Old Apr 28, 2005 | 09:43 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
It will happen soon...I though babyblu was going to be the first, but it looks like StephenMax will be someday soon.
Minus the LSD though, however at the track on slicks it doesn't make as much of a difference, correct?
Old Apr 28, 2005 | 10:07 AM
venommaxr33's Avatar
Don't do the 3.5 engine. If you go to the 350z forum their engines are blowing after 6lbs of boost. My suggestion would be to do the VQ33. Its a VQ30 with the bottom of the VQ35. I'm not sure what nissan did but they messed up somewhere with the VQ35 engine. In the 800hp G35 that Top Secrect built they used the internals of the VQ30 on the VK45 V8.
Old Apr 28, 2005 | 10:25 AM
IceY2K1's Avatar
First, VQ35s are blowing because of MANY reasons such as torquey TT kits that put out torque VQ30s never see, working quirks out of returnless fuel setup, weak rod bolts, crank wire signal integrity, etc.. It is NOT because the VQ35 is weaker then the VQ30, that is just dumb.
Second, the VQ35 crank and rods will not fit in a VQ30.
Third, the VK45 was a modular extension of the VQ30, ie it's basically a VQ30 with two more cylinders, so that's why they'd chose the internals. Plus, knowing TopSecret, they wanted the shorter stroke for high top speeds.
Old Apr 28, 2005 | 10:27 AM
JClaw's Avatar
I think 400fwhp in a 4th gen 5-speed with slicks and no suspension travel is possible 11-second territory. N/A 3.5s in lightweight 4th gens pushing more or less 250fwhp will most likely begin dipping in the 12s soon.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Andy29
Sep 29, 2015 05:32 AM
