Sponsored by:
Sponsored by: CARiD
Building custom intake manifold
Old Apr 5, 2005 | 10:20 AM
allen222's Avatar
Hello,
I'm currently building a custom intake manifold for my VQ30 and was looking for input on what might work best for a quick turbocharged street car. It looks like the runners will be about 5-6" max from the top of the lower intake manifold. The plenum will be about 4-5" in diameter (the runners will go into the plenum probably a couple of inches and will have some trumpets if possible). Hood clearance will be the main issue on runner length unfortunately.
Any thoughts?
allen
Old Apr 5, 2005 | 10:31 AM
plurco's Avatar
Man I would have to guess that there is so much physics at play here that nobody will be able to say, “Here is what you need to do”
Old Apr 5, 2005 | 10:34 AM
Jeff92se's Avatar
I'm needing a caw
Sounds like a BMW M5 intake manifold.
Old Apr 5, 2005 | 10:48 AM
allen222's Avatar
http://www.cardomain.com/memberpage/787911
That's an M5 IM, very different from the one I'm trying to build actually but VERY nice!
allen
Old Apr 5, 2005 | 11:38 AM
allen222's Avatar
True, I'm just trying to copy what I've seen done on race cars and hoping it won't kill too much torque.
The aluminum for the runners should be here tomorrow and I'm starting on the base plate tonight, should be fun! Won't be running for quite some time though
allen
Old Apr 5, 2005 | 04:38 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
http://www.ssr-engineering.com/produ...intakemani.php
Old Apr 6, 2005 | 06:33 AM
sean05's Avatar
looks everything interesting. Cant wait to see the finished result! good luck and keep us posted!
Old Apr 6, 2005 | 11:07 AM
allen222's Avatar
Here's a couple of pics of the progress so far. The flange is getting milled flat today if all goes well, then I'll grind the runner holes slightly larger so the runners will slide down into them to be welded on the inside.
The SSR IM is pretty ugly, I'd like to know how much HP it actually made compared to the stock one, and how much torque it lost. Anyone heard? I guess it's about the height I'll have to make mine though to clear the hood.
I'm looking for some intake velocity stacks or "trumpets". The problem is the runners are so close together that the sides of the trumpets will have to be cut and kind of siamesed together on the 1-2, 3-4 and 5-6 cylinders.
I guess I never said it but this is going into a 95 240sx w/ Z33 6speed tranny
later
allen
Old Apr 7, 2005 | 06:34 AM
allen222's Avatar
Oops, here they are:
allen
Old Apr 7, 2005 | 06:50 AM
plurco's Avatar
Good luck man. I hope it works out for you. Nothing ventured nothing gained.
Old Apr 7, 2005 | 10:15 AM
stephenlc's Avatar
where did you get that oval tubing??
Old Apr 7, 2005 | 10:46 AM
plurco's Avatar
It looks like round tubing he bent at the end.
Old Apr 7, 2005 | 03:28 PM
SR20DEN's Avatar
VQ Wizard
Looks somewhat familiar.
Old Apr 7, 2005 | 03:50 PM
NmexMAX's Avatar
dot dot dot ...
Old Apr 7, 2005 | 06:22 PM
JClaw's Avatar
I guess that's why we haven't seen any under-the-hood pictures of SR's car yet...
Old Apr 7, 2005 | 06:37 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
i will take some spy shots if the money is good.
Old Apr 7, 2005 | 06:39 PM
SR20DEN's Avatar
VQ Wizard
Thats funny. Do you honestly think I would only be making 263whp SAE if I was using somehting like that?
Old Apr 7, 2005 | 06:53 PM
Kevlo911's Avatar
Kevlo for President
You can only make that power using 00vi
Old Apr 7, 2005 | 07:45 PM
SR20DEN's Avatar
VQ Wizard
Then how do you explain that I am still using the 2k2 intake manifold?
But to get into the 280+whp SAE will require somehting different.
But still be an unopened VQ35 aside from the ARP rod bolts.
Old Apr 7, 2005 | 08:03 PM
JClaw's Avatar
So when are you scheduled to hit 11s
Old Apr 7, 2005 | 08:15 PM
NmexMAX's Avatar
dot dot dot ...
When the org community stops asking ...
Old Apr 7, 2005 | 08:26 PM
vsamoylov
that will never happen.
Old Apr 7, 2005 | 08:31 PM
SR20DEN's Avatar
VQ Wizard
That's not going to happen NA unless I win the lottery.
Old Apr 7, 2005 | 08:34 PM
JClaw's Avatar
You sure? With your current setup I am sure you can pull a 12.5 with a low 1.8/high 1.7.
Of course, a ****ty track doesn't help...
Old Apr 7, 2005 | 08:41 PM
SR20DEN's Avatar
VQ Wizard
a 12.5 is a long way from a 11.99
Old Apr 7, 2005 | 09:21 PM
NmexMAX's Avatar
dot dot dot ...
12.8 is still amazing as hell ... freakin insane, who cares about 11's ...
Old Apr 8, 2005 | 09:12 AM
allen222's Avatar
It's just round tubing that I bent with a BFH and a 2x4. The intake manifold part of this project is now on hold, unfortunately, due to hood clearance (or lack there of)
allen
Old Apr 8, 2005 | 11:01 AM
Broaner's Avatar
2060lbs and falling...
Hood clearance is the problem. I was thinking of doing something like this except having the TB on the timing chain side. There is no way it would work with a hood or some massive hump similar to the Talons.
Old Apr 11, 2005 | 06:03 PM
IceY2K1's Avatar
I think these guys have parts you'll be looking for:
http://www.rossmachineracing.com/billetintakes.html
http://www.rossmachineracing.com/uni_intakeparts.html
Old Apr 11, 2005 | 08:37 PM
subs1000w's Avatar
Originally Posted by IceY2K1
good find but when i saw those prices for the 4x4 box $29.95/ft i checked my local metal suply place that ive bought varouis metal for projects and they have the EXACT same 4x4 .250 wall stuff for $11.50/ft
you see it on this page under "ALUMINUM TUBE 6061-T6 SQUARE"
http://www.shapirosupply.com/catalog/Page3.html
talk about profit
Old Apr 12, 2005 | 04:44 AM
stephenlc's Avatar
still not that bad anyway.
aw11power
Oct 10, 2021 04:57 AM
JonBlz
Oct 5, 2015 06:02 PM
09maxshawn11
Sep 30, 2015 10:28 AM
MichMaxFan
Sep 30, 2015 09:18 AM
dshinn
Sep 26, 2015 08:07 PM
