Sponsored by:
Sponsored by: CARiD
VQ35DE: Question about fuel rail
Old Apr 6, 2005 | 09:45 AM
JClaw's Avatar
I was wondering how you other guys doing this swap like Tilley had the 3.5 fuel rail converted to return-style? That's one part of the swap I hadn't given much thought to until now...
Also what happens with the fuel filter? Same? Should I change for 1995-1996 300zx filter?
Old Apr 6, 2005 | 10:32 AM
Quicksilver's Avatar
OT n00bs FTMFCSL
Do you need a return style fuel system? If not, I say keep the returnless...
Old Apr 6, 2005 | 03:10 PM
JClaw's Avatar
Well I'm running the 1995 ECU so I don't think I can run a returnless...
Old Apr 6, 2005 | 04:39 PM
SR20DEN's Avatar
VQ Wizard
Why would the ECU care?
Old Apr 6, 2005 | 04:58 PM
JClaw's Avatar
Ah I see...
I know what your thoughts are on the return vs returnless, but I did some research and it seems the maintenance would be more complicated/expensive on a Returnless...
Old Apr 6, 2005 | 05:52 PM
SR20DEN's Avatar
VQ Wizard
Explain .
Old Apr 6, 2005 | 06:02 PM
JClaw's Avatar
I'll try to find that article again and get back to you.
Old Apr 6, 2005 | 06:34 PM
SR20DEN's Avatar
VQ Wizard
Difficulty is in the eye of the beholder. Returnless is every bit as simple as return and more productive.
Old Apr 6, 2005 | 07:23 PM
Nismo3112's Avatar
Custom User Title
So let me get this straight. On a return system, the rail sees whatever pressure the pump runs at right? But on a returnless system, the pressure the rail sees is already regulated? Using a DE-K FPR (opposed to using an aftermarket) would not work on a returnless system correct?
Old Apr 6, 2005 | 07:35 PM
SR20DEN's Avatar
VQ Wizard
On a return system the FPR dead ends the feed pressure like a Dam at the end of a river. On a returnless system the fuel is pre-regulated like a spilloff Dam somewhere in the middle of a river.
Old Apr 6, 2005 | 10:26 PM
JClaw's Avatar
And even by 2001 it was still return-style, right? God, nissan changed a hell of alot of things for 2002... So the returnless 02's do have a FPR. You mentionned that the 02's are still at 3.0 BAR, just like the 95. So why couldn't we use: 3.5 rail, De-K injectors, and 3.5 FPR, no need for an aftermarket?
Old Apr 6, 2005 | 10:28 PM
Nismo3112's Avatar
Custom User Title
The 3.5 FPR is somewhere in the tank... I will post some pics tomorrow of how I connected the DE-K FPR to the 3.5 rail.
Old Apr 6, 2005 | 10:31 PM
JClaw's Avatar
Thanks man. I remember Tilley mentioning he was running lean after he posted his 233whp/230wtq figure. I guess a SAFC won't hurt either when this is done, they're so cheap.
Old Apr 8, 2005 | 03:28 PM
JClaw's Avatar
Any pics yet?
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
bumpypickle
Sep 20, 2015 08:22 AM
conansriver
Sep 11, 2015 10:26 AM
Hdnseek
Sep 9, 2015 05:55 AM
