Sponsored by:
Sponsored by: CARiD
How does this sound.
Old Apr 8, 2005 | 04:46 PM
MyownNismo's Avatar
Future Camaro SS owner
3.5 block
Tomei 256 cams
VQ30det heads.
Would it work out
Old Apr 8, 2005 | 06:59 PM
JClaw's Avatar
Yes it would, but there is NO reason to use the inferior 3.0 heads.
Full VQ35DE/Tomei cams would be much better.
Old Apr 9, 2005 | 12:36 PM
nismology's Avatar
Ok SR20.
Ease of installation comes to mind.
Old Apr 9, 2005 | 01:14 PM
Kevlo911's Avatar
Kevlo for President
Why the DET heads? Do you know for a fact that they have different vavletrain?
Old Apr 9, 2005 | 04:03 PM
JClaw's Avatar
Originally Posted by nismology
Ok SR20.
I really don't see why he'd go through the trouble of buying the det heads when he could just use the 3.5 heads. I think Tilley's before/after results are enough to convince anyone.
Why would it be easier to install? If he doesn't want to drill the 3.5 cams he can just use his 3.0 cams, and then it wouldn't really be longer than tearing down both motors.
And besides, I think the Tomei cams have the holes already drilled for both 3.0 and 3.5 (not sure, it might be JWT's).
Old Apr 11, 2005 | 03:21 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Can you show me those before/after results? I must have missed that.
Supposedly, the HKS cams do, however supposedly the VQ30DET/VQ35 version don't exist at least from what I've read/found.
Old Apr 11, 2005 | 04:57 PM
JClaw's Avatar
Check the dyno forum, it can't be too far back. He dynoed 205wtq and 226whp with 3.0 heads, JWT cams and a 00-01 VI, which flows MUCH better than the 4th gen manifold. So with the 4th gen maxima, he was probably in the low 200whp area.
He dynoed 233whp and 230wtq with the full 3.5, and 238whp/223wtq with the butterflies removed (or something like that) on the 2k2 manifold/2k2 heads.
Old Apr 11, 2005 | 05:36 PM
IceY2K1's Avatar
He dyno'd:
226hp/205.4tq(PEAK hp 6400rpm)
1)3.5 block, 3.0 heads, JWT cams, headers, 00VI WIRED COMPLETELY OPEN
232.79hp/230.9tq(PEAK hp ~5500rpm)
2)Full VQ35 including heads AND IM
238.46hp/222.84tq
3)Same as 2), but modded 2K2 IM.
1) vs. 2)
He gained ~7whp/26wtq with VQ35 heads and stock VQ35 IM over the 3L heads/00VI, however the 00VI was HELD open which sacrificed torque. So, how does ~7whp show the VQ30 heads are inferior? Could it have been the difference between the IMs? BOTH heads and IM played a role. Also, look at where the PEAK whp was located, ie VQ30 heads/DEK IM at 6400rpm vs. VQ35 heads/IM at 5500rpm. Right there you see the INTAKE MANIFOLD is making a difference and if you continued further with a higher redline, the whopping ~7whp "inferior" VQ30 heads/DEK would continue to pull a ways. On top of that, his AFR was pretty bad...at least on the 3L heads/DEK dyno.
1) vs. 3)
He gained ~12.5whp, but a lower 17.5wtq. So, AGAIN if the DEK manifold was able to use the longer runners, who knows how close torque could have been. Mod the DEK and we'd see that hp gap even smaller, so where's the BEEF, aka superior VQ35 heads now?
In short, YES the VQ35 heads are superior due to their larger valves/high port angle, however Tilleys' dynos have NOT shown how much the heads add exclusively. As for VQ30/VQ35 hybrid compression ratio of 11.5 vs. stock VQ35 10.3, you can assume whatever you want, but unless there was better fuel tuning and especially timing tuning, you can't ASSume how much that contributed. Plus, with only PEAK numbers to go off of, you/we can't really assume too much.
If Tilley had both setups tuned to a decent AFR and timing advance as far as possible for the fuel octane he uses, we know the VQ35 heads/IM would be superior. However, with the ONE dyno I have seen and the other two dyno peak values, you can't assume whether the torque gain or horsepower gain came from the heads, IM, heads+IM, better tuning, or non-working DEK vs. working VQ35 IM.
Old Apr 11, 2005 | 07:06 PM
JClaw's Avatar
The 00-01 VI is said to flow better than the 2k2 manifold, at least that's what he and Krismax said. So, the full 3.5 dynoed more even with the 2k2 manifold.
Old Apr 11, 2005 | 08:36 PM
krismax's Avatar
Father of the 00 VI
lets think about this 00vi on 3.0 heads 6400rpm peak ,and 2k2 manifold on better heads 5500rpm peak. what im saying is the 2k2 IM is crap and the 00vi the best of the bunch. the real test would be 00 vi on both dynoed. that will show what heads are diff.
Tilley gained over 3 1/2 mph in trap over 2k2 manifold modded with the 00vi (power rod was removed thats all)
Old Apr 11, 2005 | 08:58 PM
JClaw's Avatar
No. Tilley did 99.9 mph back when he had the hybrid (3.0 heads and 4th gen manifold). He never ran with the full 3.5/2k2 manifold.
Here on September 26th he ran 14.06 and then 13.87 in October with the 3.0 heads/US 4th gen manifold, all at 99 mph:
http://forums.maxima.org/showthread.php?t=340606
EDIT:Here on November 6th he ran a 13.92 with 3.0 heads and MEVI (But no extended rev-limiter):
http://forums.maxima.org/showthread.php?t=352156
But no track times with 3.0 heads + 00-01 VI, and no track times for 3.5 heads + 3.5 manifold.
Old Apr 12, 2005 | 08:48 AM
IceY2K1's Avatar
I got off on a tangent, however my point WAS that the one dyno chart and the other two dyno peak values is NOT enough data to conclude how much better the VQ35 heads are then the VQ30 heads or how much better the DEK is then a stock 2K2 or modified 2K2.
Tuning ESPECIALLY the timing with a 11.5 CR motor is crucial for the octane/gas used.
The VQ35 heads/manifold are what the factory designed for the 10.3:1 CR, so I'd assume out of the box it would perform better then the DEK stuff at 11.5:1 with no tuning. Also, Tilley could really pump out more power with the full VQ35 by advancing timing considerably, since from the factory VQ35s run far more advance then his 4th gen ECU provides.
In short, neither of Tilleys 3 or 4 setups have been OPTIMIZED to see what the full potential could be, so I'd hold off until others follow his lead and start tuning/tweaking to see what they are really capable of. Then after we have a few dynos from different people, we can start declaring "Combo X" is inferior/superior to "Combo Y". Just my .02, but we know from SR20DENs dynos that if you can help the full, ECU included, VQ35 breath and fine tune just the AFR, it will be the winner.
Old Apr 12, 2005 | 10:46 AM
JClaw's Avatar
Yes, 3.5 ecu/full 3.5 is better as it is, but if you advance the crap out of the timing and put SR20's manifold on a full 3.5 with 3.0, it would probably put down similar numbers.
Old Apr 12, 2005 | 11:01 AM
Quicksilver's Avatar
OT n00bs FTMFCSL
Except that the valves on the 3.0L heads are smaller. It might have similar numbers at relatively stock tuning, but your overall ability to gain more power is reduced (IMHO) when you try advanced tuning...
Old Apr 12, 2005 | 11:35 AM
NmexMAX's Avatar
dot dot dot ...
Yes, 3.5 ecu/full 3.5 is better as it is, but if you advance the crap out of the timing and put SR20's manifold on a full 3.5 with 3.0, .
what was that?
Old Apr 12, 2005 | 12:02 PM
IceY2K1's Avatar
He means using the VQ30DE ECU.
Originally Posted by NmexMAX
what was that?
Old Apr 12, 2005 | 01:09 PM
JClaw's Avatar
I was talking about a full 3.5 with 3.0 ECU. Same as what SR has, except no VTCs (which increase power at lower RPMs).
Old Apr 12, 2005 | 01:19 PM
OT n00bs FTMFCSL
Ahhh...my bad. I thought you just left out the word "heads" in your description...
Old Apr 12, 2005 | 05:21 PM
TILLEYS99's Avatar
Lives in a 11sec maxima
New track time at poor track 13.89 @103.65.....with vq35 heads/bottomend/00vi/vq30 JWT cams/obx headers/and a UDP. Friday comes the new 00VI im workin on in action at a good track.
Old Apr 12, 2005 | 05:46 PM
jblinga's Avatar
Tilley fill up your PS fluid!! J/K I'm sure you've already filled up that almost empty reservoir. You're getting another 00VI? Did you have probs w/your last one?
Old Apr 12, 2005 | 05:54 PM
JClaw's Avatar
It's the same. He just emptied its insides.
Old Apr 12, 2005 | 07:07 PM
IceY2K1's Avatar
Working DEK manifold or just zip tied?
Which ECU, stock or JWT?
Old Apr 12, 2005 | 07:11 PM
JClaw's Avatar
His rev-limiter is 7300 so I assume he has JWT.
Old Apr 12, 2005 | 08:09 PM
IceY2K1's Avatar
You're probably right, but he swaps back-n-forth with krismaxs' ECU unless he's got his own or is using it until krismaxs' car is running.
Old Apr 13, 2005 | 06:04 AM
TILLEYS99's Avatar
With JWT ECU/00vi with no divider
Old Apr 13, 2005 | 10:31 AM
IceY2K1's Avatar
No power valve?
Old Apr 13, 2005 | 11:36 AM
stephenlc's Avatar
No power valve?
http://forums.maxima.org/showthread.php?t=395063
Old Apr 13, 2005 | 11:50 AM
IceY2K1's Avatar
This run was before that.....
Old Apr 13, 2005 | 03:25 PM
MyownNismo's Avatar
How about this then
3.5
3.0 timing
tomei 256 w/spacers
TB convert to cable
2k1 ECU to remove EGR.
Old Apr 17, 2005 | 08:39 AM
MyownNismo's Avatar
Originally Posted by MyownNismo
How about this then
3.5
3.0 timing
tomei 256 w/spacers
TB convert to cable
So will this work. This project something I am very interested in. Another question, since you are using the 3.0 timing and cover couldn't you use the 2k-2k1 supercharger if you wanted to go boost.
Old Apr 17, 2005 | 09:52 AM
stephenlc's Avatar
i heard the tomeis are like a 3-4 month wait.
user 11122324
42
Jul 18, 2022 03:35 PM
DJLAX152
May 4, 2021 11:46 AM
TheMafia
Sep 4, 2015 08:26 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
tomI30
Mar 30, 2001 10:17 AM
