Sponsored by:
Sponsored by: CARiD
Another modified 00VI
Old Apr 19, 2005 | 06:36 AM
Stephen Max's Avatar
Here's a little project I've been working on.
The thought was to make a short runner IM out of a 2k IM, similar to what Tilley recently did (ref: http://forums.maxima.org/showthread.php?t=395063). I took a different approach:
Old Apr 19, 2005 | 06:47 AM
Results?
Like Tilley, I noticed a drop in torque, but top end felt good.
I did a 3rd gear run to 7000 rpm and logged maf voltage. Comparing to data from a recent dyno run with an unmodified 00VI, I show less airflow at low-midrange rpm, and occasional insignificantly small gains alternating with losses from 5300 rpm on up.
Based on this, I'm not going to bother to have a dyno done, although a dyno might show higher gains with the modified 00VI, since the airflow data was collected on a considerably warmer day than the dyno results I am comparing against.
Old Apr 19, 2005 | 07:09 AM
krismax's Avatar
Father of the 00 VI
wouldnt that hurt haveing the runners still behind the TB?
Old Apr 19, 2005 | 07:22 AM
I'm wondering the same thing. My next step is to cut the runners off flush with the new plenum.
Old Apr 19, 2005 | 09:40 AM
Broaner's Avatar
2060lbs and falling...
OMG! That is such a sweet way to mod that beast. Its basically an open log type manifold now.
Old Apr 19, 2005 | 09:41 AM
96sleeper's Avatar
The factory TB mount is set up to deliver the same amount of air to all cylinders by gradually decreasing the size of the main channel until the last cylinder runner. By doing what you did, I would be worried about different cylinders running lean/rich in the setup. Since the main channel is the same size, the rear cylinders may not be getting the same airflow. It also looks like the flow would be very rough the the other cylinders because of the runners sticking up in the middle of the air path.
Way to be innovative, but I would be careful.
Old Apr 19, 2005 | 09:44 AM
hacim105's Avatar
This was the exact thing I was thinking. Perhaps if he cut off the extra intake and custom mounted things needed he would see better performance.
Old Apr 19, 2005 | 09:49 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
I said the same thing to him via email.
I'd really like to see the difference in airflow with the TB in the original location and the vias box location blocked.
Any chance you could try taking airflow measurements with that setup Stephen?
Old Apr 19, 2005 | 10:40 AM
I could do that.
Old Apr 19, 2005 | 10:43 AM
Jeff92se's Avatar
I'm needing a caw
How did you manage to cut way into the manifold?
Old Apr 19, 2005 | 10:54 AM
IceY2K1's Avatar
Originally Posted by Stephen Max
I could do that.
Old Apr 19, 2005 | 10:59 AM
With a 2.75" hole saw. Wasn't easy, though.
In case you're wondering, yes, I did cut all the way through to the last runner.
Old Apr 19, 2005 | 04:45 PM
stephenlc's Avatar
wow reminds me of the ls1 composite intake manifold.
Old Apr 20, 2005 | 07:18 AM
Nealoc187's Avatar
SLOW
Can I assume you are going to try and log MAF voltage data on a similar day to your previous run to get a more accurate assessment of whether this is worthwhile? Because based solely on the chart posted, I'd question the usefulness of the mod unless that 5300+ range is all that interests you. Because the losses look to outweigh the gains according to the MAF voltage.
Old Apr 20, 2005 | 10:35 AM
That was my conclusion. Unfortunately, we are warming up fast down here in Texas, we may not get another day as cool as the one I dynoed on until next fall.
Old Apr 23, 2005 | 03:07 PM
Tyrexx's Avatar
Awesome .
Old Apr 23, 2005 | 04:32 PM
TILLEYS99's Avatar
Lives in a 11sec maxima
What MAF are you running? im running stock MAF and at 7500 im hitting 4.85v
Old Apr 23, 2005 | 09:40 PM
IceY2K1's Avatar
He's running a Z32 MAF, which peaks at 5.14v and ~420whp supposedly. So, 4.5v is ~368whp and agrees with his latest 369whp dyno.
The A32 MAF peaks at ~290whp supposedly, so that means you'd be seeing enough air for ~274whp? How are you measuring? SAFC?
Old Apr 23, 2005 | 11:45 PM
I30tMikeD's Avatar
I put down around 250-260 and get 78%-80% on my AFL reading via S-AFCII. Stock a32 MAF
Old Apr 24, 2005 | 04:33 AM
TILLEYS99's Avatar
im reading it with the techtom.
Old Apr 24, 2005 | 09:44 AM
IceY2K1's Avatar
I'd verify that with a multimeter then.
How much did you end up picking that up for?
Old Apr 24, 2005 | 09:54 AM
TILLEYS99's Avatar
Its verifyed with the AFC too.
Old Apr 24, 2005 | 09:57 AM
IceY2K1's Avatar
Just my skepticism, but I wouldn't trust either over a multimeter.
Are you adding fuel via the AFC? If so, is it showing you output voltage after the AFC or raw input?
Old Apr 24, 2005 | 10:23 AM
TILLEYS99's Avatar
im only adding a few % at that rpm
TallTom
57
Oct 14, 2025 05:16 PM
t6378tp
Sep 29, 2018 04:27 PM
lrb6805
Sep 30, 2015 08:12 AM
A32goldylocks
Sep 2, 2015 06:39 AM
Maximeltman
Aug 31, 2015 01:01 PM
