Sponsored by:
Sponsored by: CARiD
Old idea, but has it been tried? 2k3 Path IM...
Old May 6, 2005 | 02:28 PM
flashover's Avatar
Except for the glaring hood clearance problems, what other conflicts with the mating surface of the Path IM to the 4th gen cylinder heads, using the Pathy Lower manifold.
Has anyone actually tested it to see if it will fit?
Old May 6, 2005 | 02:58 PM
Stephen Max's Avatar
The intake ports of the Pathfinder VQ35 are identical to the VQ30DE, so you can bolt the Pathfinder IM right on.
Old May 6, 2005 | 03:35 PM
flashover's Avatar
hmm, now we are talking about the true dual runner type right? Might just give that a try someday. Thanks
Old May 6, 2005 | 10:12 PM
BlueC's Avatar
wat
Interesting.......
Old May 9, 2005 | 03:41 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Yes....I've got $50 to anybody that pulls it off.
Old May 9, 2005 | 03:44 PM
JClaw's Avatar
I think you just pissed in the punchbowl...
NmexMAX's Avatar
dot dot dot ...
No that's a true dual runner set-up, even on the Maxima advertisment bookelts, they show a dual stage all shiny'd up in chrome, and with many details, and we all know it's really not in the Max, false ads anyone ...
Old May 9, 2005 | 03:46 PM
Kevlo911's Avatar
Kevlo for President
Pathy is TRUE dual runner setup. It has a set of long and short runner. Or atleast that is what I am told.
Old May 9, 2005 | 03:49 PM
NmexMAX's Avatar
dot dot dot ...
I've seen that drawing all over the place sucks we didn't get it... jsut wish the max had the dual runner, also the sentra SE-R has the same basic design of the true duals in that drawing too. That concept and drawing is on a few of the technical VQ35 papers.
Old May 10, 2005 | 04:27 PM
IceY2K1's Avatar
Why's that?
Old May 10, 2005 | 06:10 PM
Larrio's Avatar
The Definitive AE Master
what year pathfinder is that picture from?
i believe the new vq40 equipped ones have a different manifold, right?
Old May 10, 2005 | 06:11 PM
IceY2K1's Avatar
2001(late) to current or at least 2004 all have the same IIRC.
Old May 10, 2005 | 06:12 PM
IceY2K1's Avatar
Hey...that would be a good excuse for a CF ram-air scoop Larry.
Old May 10, 2005 | 07:16 PM
Larrio's Avatar
2005 pathfinder vq40
http://www.canadianautoreview.com/pa...-%20engine.jpg
2001 pathfinder vq35
http://www.familycar.com/RoadTests/N...ges/Engine.jpg
i have a rainy day fund that could come in good use here. Are you speculating that this manifold will flow better than the de-k?
btw, why is there a upper, center, and lower for the pathfinder IM on carpart.com
Old May 10, 2005 | 07:58 PM
SPiG's Avatar
SomePsychoGuy
It is a 3 piece IM. It should be better than the DEK. It is true dual runner. Thus for boosted people you could just run off the short runner when boosted.
Old May 10, 2005 | 09:30 PM
SR20DEN's Avatar
VQ Wizard
The VQ40 manifold is basically the same as the FWD VQ35 manifold. Definately NOT interchangeable. Unless the lower will bolt upto the VQ35 heads.
Old May 10, 2005 | 11:19 PM
Larrio's Avatar
wow, it looks de-k inspired in terms of material and color
http://www.infinitihelp.com/ownershi...es/05015-1.jpg
so i'm assuming you'd need the vq35 version lower, center (MT version), and upper to run?
Old May 11, 2005 | 06:10 AM
SR20DEN's Avatar
VQ Wizard
The VQ40 manifold is the same "split plenum" design as the VQ35 FWD manifold.
Old May 11, 2005 | 07:57 AM
NmexMAX's Avatar
dot dot dot ...
But plastic ...
Old May 11, 2005 | 09:51 AM
IceY2K1's Avatar
Why ole why did you muddy the water with the VQ40.
VQ35 Pathy uses same low angle intake port style heads as VQ30s and the VQ30 LIM was confirmed by Stephen to bolt on to the Pathy VQ35, so you'd just use the Pathy VQ35 LIM/intake manifold.
The injectors/lower gasket are identical. You could possibly need to massage the VQ30DEK fuel rail for clearance on the Pathy LIM.
Old May 11, 2005 | 05:06 PM
flashover's Avatar
Ok, what about the coil packs, wouldn't the regular VQ30 rear ignition coils be too tall?
Would the rear Pathy or VQ35 ignition coils work if to tall?
Old May 11, 2005 | 05:16 PM
Larrio's Avatar
the coils sit close to the valvecover, the IM should clear over it and you should be able to run the plugs underneath.
doesn't the 2k2's require complete removal of the IM to access the rear coils?
Old May 11, 2005 | 05:23 PM
NmexMAX's Avatar
dot dot dot ...
Old May 11, 2005 | 07:43 PM
SR20DEN's Avatar
VQ Wizard
The coil packs or more specifically the length of the 'Cigars' is relavent to the cylinder heads more so than anything else. You can put longer (VQ30) cigars on VQ35 coils to use on VQ30 heads and vise-versa but there is rarely any need to do so.
Old May 11, 2005 | 07:44 PM
SR20DEN's Avatar
VQ Wizard
Just the upper. I think mine comes off in under 5 mins.
Old May 11, 2005 | 08:31 PM
Nismo3112's Avatar
Custom User Title
What is the 3.5 Pathy rated at power wise? I think it can be done, but hood clearance could be an issue. My 2k2 IM barely fits under the hood.
Old May 11, 2005 | 10:35 PM
Larrio's Avatar
240hp/260tq
http://www.freshalloy.com/site/featu...nes/home.shtml
it will probably all come down to hood clearance.
Old May 11, 2005 | 10:55 PM
NmexMAX's Avatar
dot dot dot ...
We must have Pathy engines in our 5.5g Maximas judging from dynos (- the dual runner IM)
Old May 12, 2005 | 10:50 AM
allen222's Avatar
What are you guys doing for idle control when you put these late model intakes onto your early VQ30's? Don't they have a different type of setup for that?
thanks,
allen
Old May 12, 2005 | 12:12 PM
BlueC's Avatar
wat
So besides hood clearance, the VQ35 pathy IM should bolt upto the VQ30 without any major modifications?
If thats the case, I think this might be on the list for the summer.
Old May 12, 2005 | 02:43 PM
Nismo3112's Avatar
Custom User Title
thanks,
allen
Stock IACV...
Old May 16, 2005 | 11:06 PM
Cliff Clavin's Avatar
Way out West
If you all need any specific photos of anything on the Pathfinder VQ35, just send me a PM. I have a 2001 Infiniti QX4 (same engine).
Since I have a 3rd gen, all of this swap talk is of little use to me, but very interesting.
Old May 17, 2005 | 08:48 AM
IceY2K1's Avatar
You could always swap the high-port heads and intake manifold from a 350Z into your QX4.
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
Justin Kroll
Oct 1, 2015 07:03 PM
maxima297
Sep 30, 2015 03:32 PM
