Sponsored by:
Sponsored by: CARiD
00vi help!
Old Jun 21, 2005 | 05:06 PM
  #81
eckohb's Avatar
The coil mounts were too tall.
Where did you run your positive source for the VI solenoid from?
Old Jun 21, 2005 | 05:08 PM
  #82
DandyMax's Avatar
3.5 in the works
Ah.. so the manifold wasn't seated right then? That would do it...
I used the same place I hooked up the positive for the switch. I just tapped into the closest connector right after the ignition switch. I tapped 3 lines there... one for the switch, one for an LED I wired on my dash, and one for the VIAS solenoid. But it can be anywhere as long as it's a switched +12v source.
Old Jun 21, 2005 | 06:44 PM
  #83
THT's Avatar
THT
Throbbing member
Nope, it's bare.
Old Jun 21, 2005 | 08:37 PM
  #84
eckohb's Avatar
everything works fine and this thing pulls like crazy up top. i chirp second with my 17s on with the drop resistor. never did that before. a few idle issues with the TPS that can be worked out, but other than that, everything is ok. we hooked up the VI to the pos. battery terminal and it opened right up. Thank you everyone who helped out with the install, DandyMax, Stephen Max, Kevlo911, THT, Nismo3112, s0ber, jmeister, and anyone else.
Old Jun 21, 2005 | 08:39 PM
  #85
Nismo3112's Avatar
Custom User Title
I'm glad you got everything sorted out, and i'm sorry about the lack of picking up the phone, I was busy all day today. And i'm glad you like the power output
Old Jun 21, 2005 | 08:42 PM
  #86
s0ber's Avatar
That's awesome man, what are your other mods?
Old Jun 21, 2005 | 08:45 PM
  #87
eckohb's Avatar
CAI, Y pipe, custom cat back, and thats it i believe. my CAI it so much quieter with the VI on, its crazy. i have the VI opening at around 4800-4900 rpm with the summit switch. im sure dave is just glad to get me out of his house. all that time without a shower started to take a toll on us today when it was really warm.
Old Jun 21, 2005 | 08:56 PM
  #88
s0ber's Avatar
You are using a 4th gen TB? How far back did your TB get pushed with the VI? I cant connect my CAI because it doesnt reach anymore ;[
Old Jun 21, 2005 | 09:02 PM
  #89
eckohb's Avatar
yes, im using everything 4th gen minus the VI itself. youll probably have to redrill the hole. im using the stock resonator, so maybe that gives it some extra length. you could try flipping the CAI part of the CAI around and drill the hole according to that. Youll get much more reach that way. If im not mistaken
Old Jun 21, 2005 | 09:04 PM
  #90
DandyMax's Avatar
3.5 in the works
Glad you got it up and running man. It does feel so much better doesn't it!
Now start thinking about rev limit.
Old Jun 21, 2005 | 09:05 PM
  #91
s0ber's Avatar
I wouldnt wanna re-drill that thing, lol enough holes in there as it is, its short by about an inch, if i had a longer coupler it would work perfect.
Old Jun 21, 2005 | 09:06 PM
  #92
eckohb's Avatar
or you could try a longer coupler i do suppose. re-drilling would suck, but its always an option. or you could take a dremel for that extra inch you need. try the stock mid pipe and see if that would give you the extension you need.
Old Jun 21, 2005 | 09:12 PM
  #93
DandyMax's Avatar
3.5 in the works
Maybe go to Home Depot and get some 3" PVC piping and couplers and make an extension. It may not be the most elegant solution but it might work until you find a better one (and it would be cheap)...
EDIT: oh.. only short an inch you say... that's a bit trickier then. I'd like to redo my intake too but haven't given it much serious thought yet as to what the best way would be...
Old Jun 21, 2005 | 09:18 PM
  #94
eckohb's Avatar
We're getting a 1002, left bank lean fuel mixture. I'm guessing this is the front bank and there is still a small leak between the manifolds. The manifold is only being held in with 2 bolts anyway so that's my reasoning.
Old Jun 21, 2005 | 09:25 PM
  #95
DandyMax's Avatar
3.5 in the works
Yes the left bank is the front and you'll definitely want to get more bolts on there eventually. It's possible it's not making an even seal across all runners. I also picked up one of the back support brackets from Nissan (for some reason they could only get the right one)
Old Jun 22, 2005 | 12:36 AM
  #96
eckohb's Avatar
i made it home from chicago, 2.5 hour drive, and the code hasnt came back. no problems. this thing is fun on the highway. i was playing around with a 350z up til 120 and was back by a car or so. he waved and left the freeway. it still idles a little rough, and the idle will jump from between 500 and 1100 RPMs. Is this the ECU relearning that more air is coming in, or is it something i need to adjust?
Old Jun 22, 2005 | 02:47 AM
  #97
THT's Avatar
THT
Throbbing member
I had that problem and solved it by changing the FPR vaccum source.
Old Jun 22, 2005 | 04:21 AM
  #98
jmeister's Avatar
That was one of the 1st codes I got too but that one hasn't come back. My idle is still bad too but I need to play w/ the TPS some more. Has hard cold starts...
Congrats on getting it running.
Old Jun 22, 2005 | 10:08 AM
  #99
SDot82's Avatar
Congrates on getting it installed.
Old Jun 22, 2005 | 10:16 AM
  #100
eckohb's Avatar
thanks. the code came back today, so ill look at getting at least two more bolts onto the VI. Ill mess around with some vacuum hoses and the TPS to try and get all of the kinks out. But its not having any problems starting, and the high idle happens while in park, in Drive, it's ok, at about 600 rpm. So I'll try working on that later
t6378tp
Sep 29, 2018 04:27 PM
lrb6805
Sep 30, 2015 08:12 AM
Finkle
Sep 27, 2015 09:53 PM
Maximeltman
Aug 31, 2015 01:01 PM
skinnypimp
Aug 28, 2015 11:45 AM
