Sponsored by:
Sponsored by: CARiD
00vi help!
Old Jun 19, 2005 | 11:08 PM
eckohb's Avatar
00vi help!
so me and Dave Sz got the vi installed, but my car wont start. it turns over, but it wont run. we tried giving it some gas, and it would sorta stay running and immediately die. we're too tired to keep messing with it now, but tomorrow morning we're back at it. any thoughts or suggestions would be great. we've decided TPS, misrouted vacuum line, or bad grounds. we'll be trying them all out tomorrow. anything anybody else could help with would be great.
Old Jun 20, 2005 | 05:39 AM
Stephen Max's Avatar
It's probably those budget adapter plates you bought ...
Just kidding. It sounds like a massive vacuum leak, which is very possible if you don't have the coil mount bosses ground down enough, of if the 00vi is contacting the egr bracket down underneath the throttle body.
Old Jun 20, 2005 | 06:22 AM
nismology's Avatar
My friend had the same problem after we installed his 00VI. He used the 4th gen TPS on the 5th gen throttle body so it was out of adjustment. After i adjusted it to spec the car started up. Adjusting the TPS would be my first suggestion.
Old Jun 20, 2005 | 06:54 AM
To test if it is the TPS or not, just disconnect the TPS harness from the TPS. If there is no change, then the problem is not the TPS.
Old Jun 20, 2005 | 06:55 AM
eckohb's Avatar
its not the coil mount bosses, or the egr pipe. lol, the adapter plates were fine. we're going to try the tps, or re routing some hoses to see what is going to get this bad boy up and running.
Old Jun 20, 2005 | 06:56 AM
eckohb's Avatar
once the TPS harness is disconnected, then what?
Old Jun 20, 2005 | 07:01 AM
If the car now runs okay, then the problem is with TPS adjustment. If no change, then the problem was not the TPS.
Other things to consider are torn injector o-rings and improperly seated injectors.
Old Jun 20, 2005 | 07:02 AM
eckohb's Avatar
there is a little nipple on the VI coming out on the thing where the butterflies above the plug you use open the VI. does that need to be hooked up to anything? i've seen peoples' cars with vacuum lines to it, and people without vacuum lines. btw, we're using all 4th gen parts, only 5th gen VI
Old Jun 20, 2005 | 07:05 AM
eckohb's Avatar
do the injectors sit the same way once the fuel rail is rotated 180 degrees? I guess thats something we didnt think about. also, there is one lonely nipple coming off the left side of the VI by itself, what does that get connected with? we're just trying to see if all our vacuum lines are correct. it doesnt sound like we have a leak, but ya never know
Old Jun 20, 2005 | 07:14 AM
Nothing changes with the way the injectors sit, even when rotating the lower IM.
A nipple by itself won't create enough of a vacuum leak to cause poor running, unless maybe one of the large nipples like what the brake booster hose connects to.
I take back the suggestion about the torn injector o-ring, since you didn't have to remove the injectors from the fuel rail. It is possible that one of the large o-rings that seat the fuel rail into the lower IM may be out of place, allowing an air leak.
Other than an air leak, the only other possibility is an electrical problem (since you didn't change anything with the fuel system). Do you have all your ignition coils connected properly? Are the coils seated on the plugs properly?
Old Jun 20, 2005 | 07:17 AM
eckohb's Avatar
we thought the coils were on the plugs, but we're going to try the TPS harness first, and if thats not it, go back to square one, and check everything out. we thought the coils were in right, but at this point, who knows? could bad grounds cause this? once we flipped the lower IM, we grounded the two wires to the fuel injectors. are those not good grounds?
Old Jun 20, 2005 | 07:41 AM
eckohb's Avatar
after trying to start the car again, gas fumes were coming out of the intake resonator...dont think thats supposed to be happening. what would be causing this?
Old Jun 20, 2005 | 07:45 AM
I highly doubt the fuel rail is a good ground path, but you can check with a multimeter. It would be better to run a jumper from the grounding eyelets to the engine block.
Old Jun 20, 2005 | 07:46 AM
You're getting fuel but inadequate spark, it sounds like.
Old Jun 20, 2005 | 08:02 AM
eckohb's Avatar
We dumped a bit of TB cleaner into the cylinders while the manifolds were off. They may be flooded but I think it all burned off already. The car started and ran for a few seconds last night but now nothing. Weak spark is what I'm thinking as well, although I'm not sure why that would be except that it's flooded?
Old Jun 20, 2005 | 09:03 AM
nismology's Avatar
Dude, check the TPS adjustment. You ask for help but don't follow through on the suggestions. The haynes manual states that an improperly adjusted TPS will cause intermittent bursts of fuel from the injectors because the ECU thinks the throttle is moving. This can cause either flooding or intake backfires (since fuel may be fired when the intake valve is closed). BTW, small vacuum leaks won't keep the car from starting.
If you don't have a haynes manual i'll post the instructions on how to set the resistance values for the TPS and WOT/closed throttle position sensors to spec.
Old Jun 20, 2005 | 09:13 AM
DandyMax's Avatar
3.5 in the works
He said he used 4th gen everything though... so he shouldn't have touched the adjustment on the TPS, there would have been no need to... (I know I didn't need to anyways.. but maybe they messed with it)
But aside from that, I wouldn't use the fuel rails/injectors for grounds. Take the two ground connections on the front harness and run them over to a proper grounding point, such as the block ground to the right of the front bank. If you have a grounding kit this is a cinch. Otherwise, make your own leads.
BTW, the VIAS soleniod port on the front does not get a vacuum connection unless you want the power valve open all the time. It normally sees atmosphere (intake air). The power valve opens when the solenoid is switched electrically cutting off the air path and allowing vacuum from an internal tank to pass to the power valve actuator.
Old Jun 20, 2005 | 09:21 AM
Nismo3112's Avatar
Custom User Title
Would it be a possibility that the plugs got fouled out when you sprayed the cleaner in? Another possibility is that the FPR vac source is inadequate (my souce was directly connected to the mani), and it's dumping too much fuel in at idle, causing the plugs to be fouled. So for sure check the plugs.
I agree with nismology, even with a vac leak, the car will still start. Did you attempt to start the car before the rpm switch install? But the symptoms point out a fuel/spark issue.
Old Jun 20, 2005 | 09:26 AM
eckohb's Avatar
we tried the TPS that stephen max suggested, and it still had the same symptoms. we are looking to adjust it to spec according to the Haynes manual right now. And it didnt work either. It was set to spec. We are going to try some new spark plugs and see what happens
Kevlo911's Avatar
Kevlo for President
On the IACV, the dark red connector. I thought mine was plugged in, but it was not so car would not stay on. Make sure it is snapped in.
Old Jun 20, 2005 | 09:29 AM
eckohb's Avatar
the fpr vac we're using is the same one that was used while the car had the stock manifold.
Old Jun 20, 2005 | 09:30 AM
MAXC's Avatar
I had the same problem after installing my 02 motor in my 97. it took me a little over 3 days to find out that grounds for the fuel injectors were not grounded correctly. I had them grounded to the valve cover, where in theroy if you think about this, sit on a rubber gasket. neve completly touching the motor itself. So I moved the grounds to the timming chain cover, turned the key once & it fired up. so I would check your fuel injector grounds too.
Old Jun 20, 2005 | 09:36 AM
Nismo3112's Avatar
Custom User Title
But did your engine turn over? When I installed my VI, I complete forgot to connect those grounds, and the starter wouldnt even engage.
Old Jun 20, 2005 | 09:39 AM
Nismo3112's Avatar
Custom User Title
You mean the stock source? I remember on my car, since I didn't have the EGR hooked up, that source was now open to free air. I will check my car again to see where that hose leads to.
Old Jun 20, 2005 | 09:44 AM
gabex's Avatar
I may have missed over some info in the thread..but
Did you end up keeping your EGR, or did you close it off?
When I pulled my IM, TB, EGR, etc.. after putting it back together, a tiny EGR gasket fell underneath the car..
I had no idea til I put everything back together. The car would start.. but right after it turned over, as the revs droped back down to idle it would near instantly die..
Old Jun 20, 2005 | 09:50 AM
eckohb's Avatar
is it ok if we take out the spark plugs, leave them open and start firing so some of the TB cleaner evaporates? the plugs were definitely wet from whatever it was down in there. we have only taken out the front ones so far to come to that conclusion. We tested them and they are receiving spark however...so how do we solve this problem?
Old Jun 20, 2005 | 09:53 AM
nismology's Avatar
There's spark, but are you sure the spark is consistent and cyclic and not just random??
Nismo3112's Avatar
Custom User Title
Do the plugs have any distinct odor to them?
Oh yeah, I checked the stock vac line going to the stock FPR source, and it leads to underneith of the throttle body. Did you extend that and run it to the TB? If there is no vac to the FPR, you will definantly flood your plugs.
Old Jun 20, 2005 | 10:00 AM
eckohb's Avatar
the plugs smell like TB cleaner. and we took a plug from daves car and my plug, and my spark seemed stronger. plugs are only 10k old. The vac from the fpr goes to the small brass tube, goes under the TB? Is it the one that has two outlets coming from the brass tube?
Old Jun 20, 2005 | 10:04 AM
nismology's Avatar
Old Jun 20, 2005 | 10:07 AM
eckohb's Avatar
well, it's not random, it has a pattern to it. Right now the front three plugs aren't even connected and the car sounds the same as if though they were plugged in. Again, IS IT OKAY TO START THE CAR WITH THE CYLINDERS OPEN TO LET SOME OF THE CRAP EVAPORATE?
Old Jun 20, 2005 | 10:33 AM
eckohb's Avatar
ok, the fpr vac goes under the tb through the T brass pipe, then comes back towards the fpr into the small white cylinder thing and into the egr or evap solenoid valve. Could I just bypass the brass pipe alltogether and run it into the white cylinder and the solenoid?
Old Jun 20, 2005 | 10:49 AM
nismology's Avatar
Yea that's fine. Just remove the fuse for the fuel pump.
Old Jun 20, 2005 | 11:57 AM
DandyMax's Avatar
3.5 in the works
It's a little confusing trying to understand what you're proposing to do.. but if you mean take the FPR line and connect it to the one-way valve (white cylinder) and the solenoid line without connecting it to the manifold somewhere I don't think it will work. You still need to connect all those things to the manifold for a vacuum source.
Do you have a vacuum hose drawing from the FSM (near the front of the EC section)? Study that and it'll become clear what each line is/needs. That's the best way to figure out how things should be routed.
Old Jun 20, 2005 | 01:37 PM
eckohb's Avatar
the exposed nipple comes from the FPR vac line, do I connect it to the vac fitting on the bottom of the TB? There is already a vac line for the tb fitting but what if I T'ed the xposed one into it?
Old Jun 20, 2005 | 02:00 PM
http://members.dslextreme.com/users/...esm/a32-ec.pdf
Look at pages 16 and 26.
That particular tube should be connected via vacuum hose to a nipple at the IM throat. It should see manifold vacuum when the throttle is closed.
Old Jun 20, 2005 | 03:24 PM
RA030726's Avatar
I'm nutty for Nissans
which side of the throttle plate did you have the fpr connected to? there are a few different nipples to connect to and one is infront of the throttle plate. you will see little or no vac on that side.
Old Jun 20, 2005 | 06:09 PM
eckohb's Avatar
Ok, car starts, runs rough, and turns off after 10 seconds. We're getting
0205 IAC AAC Valve
1008 purge volume control valve
1302 map/baro solenoid valve
Old Jun 20, 2005 | 06:28 PM
THT's Avatar
THT
Throbbing member
Sounds to me like your vaccum sources are mixed up. Retrace them to make sure you're routing them properly.
Old Jun 20, 2005 | 06:42 PM
DandyMax's Avatar
3.5 in the works
+1. Sounds like vacuum/air supply.
BUT.. just for the sake of asking... did you do any re-wiring at all?
