Sponsored by:
Sponsored by: CARiD
VQ35 swap q's
Old Jul 11, 2005 | 05:52 PM
RockfordMax's Avatar
Back from the dead
VQ35 swap q's
Alright got a few questions about a 35 swap. Would the engine out of an '04+ maxima thats advertised as 265 HP make that same power in my 95? Also if i am correct the engines are the same size but the 35 weighs less. any benefits to that? and finally, ECU. does it need to be changed or will the 35 run with the 95 ECU? true final question... average cost of total operation. thanks in advance to anyone who responds
Old Jul 11, 2005 | 06:18 PM
Jason R's Avatar
aka UNCDooD
read. there are soooo many threads discussing all the info you just asked about within the first few pages of this section.
Old Jul 11, 2005 | 07:20 PM
Nismo3112's Avatar
Custom User Title
Old Jul 11, 2005 | 07:37 PM
THT's Avatar
THT
Throbbing member
ROFLOL @ Nismo
1. Yes but only if you enabled CVTC which would require using the VQ35 timing equipment which would require that you use a VQ35 ECU which would require you to rewire the car...see where I'm going with this?
2. The 3.5 does weigh less. Advantages: If you can't think of why this is a good thing, you should go back to the 4th gen forum.
3. You can use a VQ30 ECU or VQ35. So far, only one 4.5 gen is using the VQ35 ECU because of the added misery of rewiring the car.
4. Cost: $3K if you have Tilley do it. ~$1K if you do it yourself.
Old Jul 11, 2005 | 07:52 PM
steven88's Avatar
Need A Light?
Can you use a vq35 and run a 3.0 ecu without messing with the cvtc? or is it mandatory to swap it to 3.0 timing equipment if u wanna run a 3.0 ecu?
Old Jul 11, 2005 | 08:01 PM
THT's Avatar
THT
Throbbing member
No.
Yes.
Any questions?
Old Jul 11, 2005 | 08:08 PM
JClaw's Avatar
The main reason a 3.5/3.0 ecu setup does not make as much power as 02+ is NOT VTC's. VTC's are used to increase power below 4k, takes nothing off peak.
The real reason is that 02+ run far more timing advance than 95-99 ECU's. That alone might rob you of 20-25whp or so (yes, those numbers were pulled out of my @ss).
Old Jul 11, 2005 | 08:13 PM
steven88's Avatar
Need A Light?
JClaw- what would be the best route to get a 95 vq35 swapped maxima to equal an 02 vq35 maxima? Hp wise that is....since u mentioned you are robbed 25whp from the ecu alone...
what about transmission? I hear people keeping their stock 5spds and mating it to the vq35...any modification necessary to make it fit? Since the original vq35 motor came with a 6spd....how about axles?
Old Jul 11, 2005 | 08:34 PM
JClaw's Avatar
I told you I pulled them out of my @ss. I have something in mind for the tuning but you're better off asking someone else about the tuning. I'm pretty inexperienced with cars in general and the swap was my first motor pull, my 5-speed trans was my first rebuild and my maxima is my first modded car.
Bolts right on, just like on the 3.0. All VQ motors use the same bellhousing, and the blocks are externally identical.
Old Jul 12, 2005 | 04:44 AM
Stephen Max's Avatar
All FWD VQ blocks, that is. The engine mount locations are different for RWD VQs.
Old Jul 12, 2005 | 08:41 AM
JClaw's Avatar
You know what I meant
Old Jul 12, 2005 | 08:55 AM
I wrote it for the benefit of others, lest anyone think they can swap in a 350Z engine. This question comes up occasionally.
Old Jul 12, 2005 | 11:32 AM
MDeezy's Avatar
there is a whole lot of help in here.
http://forums.maxima.org/showthread.php?t=345720
I am interested in the swap as well, but had a lot of reading to do before I post anything.
Old Jul 12, 2005 | 03:17 PM
Back from the dead
lol guys i went on to read the stickies about this after i posted this, and it answered it all except for wiring/ecu question. thanks for honest answers and not really flaming. as soon as i get good at racing i think this is the route im going to go. 1-2k isnt bad at all seeing as how if i go with a 6th gen engine im gaining 100ish hp.. or is that 265 crank and not wheel. whatever its a lot and would crack me up to bring that to the dealer.
Old Jul 12, 2005 | 03:19 PM
THT's Avatar
THT
Throbbing member
265hp crank...expect 220-230whp
Old Jul 12, 2005 | 04:21 PM
Back from the dead
beats 155
Old Jul 12, 2005 | 04:37 PM
THT's Avatar
THT
Throbbing member
Wait, you're an automatic...the only 3.5 auto that's dyno'ed pulled less than 200whp (untuned)
Old Jul 13, 2005 | 02:03 PM
eckohb's Avatar
he pulled 180 untuned. but that was without headers either. tilley only dyno'd at 238 with headers, flywheel, and 00vi, so to say 220-230 whp with the 3.5 motor is a stretch
Old Jul 13, 2005 | 02:39 PM
THT's Avatar
THT
Throbbing member
It is a stretch. For some reason, I thought I was on my350z.com when I posted that whp figure.
Old Jul 13, 2005 | 05:28 PM
Back from the dead
yes but if i do the 35 swap im bring a 5/6 speed over with it. why keep the auto..
Old Jul 14, 2005 | 12:52 AM
eckohb's Avatar
but if you dont bring over aftermarket headers with it, dont expect 220-230 whp. They add a dyno proven 20 whp/ 20 wtq
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
mclasser
22
Nov 12, 2020 01:58 PM
ef9
Oct 4, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
