Sponsored by:
Sponsored by: CARiD
00vi installed with 1302 code
Old Jul 25, 2005 | 02:52 PM
maximazation's Avatar
I just finished up the 00VI install using the 4th gen lower plenum, 5th upper plenum, 5th gen TB, and 4th gen IACV. All hoses are hooked up. I start the car, and it idles at around 400-500 rpm, then it starts to fluctuates like crazy going up and down from 100-700 rpm, I also throw a code. I am thowring the 1302 code which is the "MAP Solenoid Valve or Circuit Fault" Any dieas on how to fix the erratic idle and the code? Maybe I should reroute some vacuum lines or there is a leak..
Old Jul 25, 2005 | 04:02 PM
THT's Avatar
THT
Throbbing member
Double check your vaccum lines. And make sure your MAP sensor has a vaccum source. Mind didn't and I threw a code.
Old Jul 25, 2005 | 11:49 PM
now i have the 0701 code to follow the 1302, so now im throwing both the 1302 and 0701 codes...any ideas on what i should look for?
Old Jul 26, 2005 | 07:03 AM
DandyMax's Avatar
3.5 in the works
Sounds like vacuum/air line routings to me too.
Old Jul 30, 2005 | 08:02 PM
sean05's Avatar
how long did it take you to install it? how hard was the total install?
Old Jul 31, 2005 | 01:26 AM
took too long because i had to keep on going to OSH to buy screws, hoses, clamps, and elbows, and it was a ***** to install....not the easiest thing to install, and after the install, it didnt run well and i had to smog within a few days, so i had to take it all off and install the stock 4th gen manifold again which probably took a good 3-4 hours, hopefully someone can help me with my problems after my smog check which i failed, which is another story
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
BkGreen97
Apr 2, 2016 05:47 AM
MaxLife17
Sep 8, 2015 02:36 PM
Johnny9595
Sep 3, 2015 05:18 AM
