Sponsored by:
Sponsored by: CARiD
DE-K Engine Swap?
Old Sep 16, 2005 | 01:19 PM
maximamaybe74's Avatar
DE-K Engine Swap?
Ok i just purchased a DE-k with 25k on it and i was wondering what i would need to do to get it to function right in my 4th gen. I am also boosted and have the 370cc injectors and pathfinder tb. Will my injectors fit into the fuel rail? I did some research and could only come up with a couple things like the tps wire has to be extended and the u have to plug up the extra coolant lines in the TB. If anyone can help please respond.
Old Sep 16, 2005 | 08:55 PM
Stephen Max's Avatar
If you have Z32 injectors, then they will not fit in the 5th gen fuel rail. What you need to do is modify a 4th gen lower intake manifold and use it instead.
(PS - This is a shameless plug, but I can make you a modified 4th gen LIM ready to bolt to the engine and 5th gen upper intake manifold.)
Old Sep 17, 2005 | 05:55 AM
Thanks man, the injectors that come stock with the DE-K are 240cc right? I have a jim wolf ecu set for 370 cc, if i jsut turn up the presseure on the fuel pressure regulator a bit, will i be able to run it safely at 11PSI before i get new injectors. So if this would work, what would would i have to raise my base fuel pressure to?
Old Sep 17, 2005 | 07:55 AM
JeEvE's Avatar
I explained all the things you need to do in my thread here:
http://forums.maxima.org/showthread.php?t=422573
Old Sep 26, 2005 | 04:35 PM
Playboycutie69
Excuse me for my ignorance but wtf is a DE-K? Power gains/price where can I buy one?
Old Sep 26, 2005 | 04:39 PM
SonicDust187's Avatar
DE-K are 2000-2001 engine.
Old Sep 26, 2005 | 04:44 PM
Kevlo911's Avatar
Kevlo for President
00-01 Engine.
derekinthez
Nov 13, 2022 04:00 PM
fastcarny
Oct 6, 2015 10:42 AM
seesole
Sep 14, 2015 12:38 PM
I<3 A32's
Sep 10, 2015 11:07 AM
