Sponsored by:
Sponsored by: CARiD
Timing advance
Old Nov 21, 2006 | 09:29 PM
  #201
streetzlegend's Avatar
Originally Posted by speed racer
What I'm saying is if you did a base line dyno before you changed your setup. So that you can see if the new results are higher than before. This will give you an idea if timing was advanced.
Well I checked my timing today. I am at 31 Degrees at WOT. I think thats about 8 degrees more advanced than stock... so it worked
Old Nov 21, 2006 | 09:41 PM
  #202
speed racer's Avatar
Nice. Isn't that more than JWT or Technesquare. Get some 3.5 cams in there. Than your good to go.
Old Nov 21, 2006 | 09:47 PM
  #203
3.5 cams?!?!? hmmmmmm.
Old Nov 22, 2006 | 12:41 AM
  #204
SonicDust187's Avatar
Didn't you say 24 is stock, thus thats 7 degree advance. Just busting your b*lls. Good job man. I wonder how much timing advance we can run to gain most power without knock?
Old Nov 22, 2006 | 02:22 AM
  #205
goldtooth's Avatar
how did u check it?
Old Nov 22, 2006 | 06:00 AM
  #206
Originally Posted by goldtooth
how did u check it?
not sure of the name of the device, but it was large with a big LCD screen like 7" and looks very expensive. i was told bout $5k. its not the Nissan consult but does almost everything. check all sensors, shows u graphs, logs, etc...
Old Nov 22, 2006 | 08:03 AM
  #207
goldtooth's Avatar
did u go to the dealer or something? where did u borrow it from? would the dealer be able to check and tell me what my timing is?
Old Nov 22, 2006 | 10:48 AM
  #208
friend of mine borrowed it from his shop. Im sure the dealer will charge you to do that, but yes they can.
Old Nov 22, 2006 | 11:20 AM
  #209
RA030726's Avatar
I'm nutty for Nissans
You can get a obd2 scanner/logger with pda if all you plan on just monitoring the ecu. You can get a Pocketlogger, obdscan, ect. for about $150-200. Im going with a Pocketlogger ($125) and ZT softwear ($40), PDA (price varies on model), and Zeitronix Zt-2 WBO2 ($280). A total of $445 + your choice of PDA. I already have the SAFC 2 and AFPR, so I'll have everything but an extended rev limit.
Old Nov 22, 2006 | 12:22 PM
  #210
You know if Pocketlogger or any of them scanners/loggers work with an Axim x50?
Old Nov 22, 2006 | 01:45 PM
  #211
RA030726's Avatar
I dont see any Dells on pocketloggers list, but these are the requirements:
http://www.pocketlogger.com/index.php?pid=faq_pda_comp
No dell on Harrison (obdscan) either.
Pocket codes has dell: http://microsoft.handango.com/Platfo...oductId=199881
Some more Dell OBD info: http://www.aximsite.com/boards/showthread.php?t=122971
Old Nov 22, 2006 | 02:37 PM
  #212
jmeister's Avatar
I use the serial consult cable $90, OBDscantech software $25 and a laptop (already had).
Old Nov 22, 2006 | 02:42 PM
  #213
thanx alot dude, i went thru the aximsite as well and found another thread, but this one u found seems to be more informative.
Old Nov 22, 2006 | 02:45 PM
  #214
Jime's Avatar
Thats the best route to go. I have both and the consult clone is better than the OBDII readers imho. Although the obdscan I have does work with my Palm which is easier than hauling a laptop around, but I always have the laptopfor the Emanage Ultimate anyway and the obdscan works with both.
Old Nov 22, 2006 | 02:59 PM
  #215
RA030726's Avatar
I dont want a laptop so anything PDA is fine. But the pocketlogger software for the Zeitronix is the piece I really need. I may as well get the rest of the Pocketlogger software to read the timming and such. Im not going for the best stuff, obviously.
Unless I can use both the ZT software and the clone on the same PDA with no other parts and its truely better I'll stick with the pocketlogger. It owuld be nice to connect it to my SER though.
Old Nov 22, 2006 | 03:12 PM
  #216
jime and jmeister where did u guys get the serial consult cable and OBDscantech?
Old Nov 22, 2006 | 04:40 PM
  #217
Jime's Avatar
Got mine here. http://www.plmsdevelopments.com/consult_if.shtml
Old Nov 23, 2006 | 06:44 AM
  #218
jmeister's Avatar
Got mine here http://www.blazt.biz/
Old Nov 23, 2006 | 11:22 AM
  #219
thnx..... i shall be purchasing one soon
Old Nov 24, 2006 | 01:11 AM
  #220
shyestsparks's Avatar
VQ35DE-T
Do you think it will work on a VQ35?
Old Nov 26, 2006 | 04:48 PM
  #221
I would like peoples opinion on this. Would timing at 31* be too much timing advance?
Old Nov 27, 2006 | 06:47 AM
  #222
NmexMAX's Avatar
dot dot dot ...
@ what RPM?
Old Nov 27, 2006 | 07:06 AM
  #223
Originally Posted by NmexMAX
@ what RPM?
throught all rpms at WOT. i logged timing and it was 31* till 6100.
Old Dec 8, 2006 | 08:47 AM
  #224
Well after dyoning and also haveing a few weeks of fun with the timing advance, it had to come to an end. Right now my car is having problems. yesterday i start it and and shut off as usual (no iacv, cold start), but this time it didnt wanna stay on not even with lil gas. so i managed to keep it on, the car after it warms up sits in idle very low mid 500s when in gear. and it shakes like crazy. i changed fuel pump to the stock one, and same thing, i check my wideband readings, and when it does this, the a/f leans out almost off charts like if there is no fuel. this morning i checkd and cleaned, cam, and both crank pos sensor. still does it. now, it is two very possible issues. a bad vacumm leak at the EGR guide tube, or injectors.
My question is, at 65ish Fuel pressure at WOT on the stock 4th gen injectors. is there a chance that they might have been maxed out and I probably hurt them? also i sprayed starter fluid towards the egr guide tube or below the tb and idle changed a lil bit everytime i sprayed it. so it might be leak also. any input will be appreciated. thanx
Old Jan 17, 2007 | 08:39 AM
  #225
MaximaSE96's Avatar
Maxima Owner
65 psi on stock injectors.....WOW thats like 4.4 bar....IMO thats alot over the 3.0 stock...but I dunno wht the duty cycle is on stock fuel pressure...but i dunno
Old Jan 17, 2007 | 08:58 AM
  #226
nismology's Avatar
Leaking o-rings or injector isolators. Most likely the latter since he said he was running lean. The pressure was fine.
Old Mar 31, 2007 | 07:33 AM
  #227
I have a question ya'll. I know the ideal way to do this would be just logging the timing. but i dont have any tools for that. soooo, I would like to know how can we predict or guesstimate how much my timing is advanced? here is the setup, I have 370 (z32) Injectors, and I have at most -15 corrections almost across entire rpm range, with stock fuel pressure.
Old Apr 1, 2007 | 08:50 AM
  #228
95turbo gxe's Avatar
Get a Eu be done with it. Sell the safc add some money too it and bam their you go. Man it really helps out in all kind of ways. My EU has saved me about $600 now. I dont have to get z32maf because I can just clamp stock voltage. And now Im going to add injectors and not have to buy upgraded= more money saved. You would be able to see all your timming,and knock levels in your data logs and you could fine tune that beast you got their!
Old Aug 19, 2007 | 05:46 PM
  #229
Gle03Max's Avatar
Ok guys if I was planning on going with the apexi neo, would a good set up be the innovative motorsports wideband o2 with gauge and then get the cable and software from that blitz website?
From all the reading ive done that setup would do everything right? ( datalog, view timing, adjust timing/air to fuel, etc. )
Old Aug 19, 2007 | 06:47 PM
  #230
Gle03Max's Avatar
Ok just one more quick question, I am planning on purchasing Auterra for my 03 max. I checked on their website and it doesnt say any nissans have can yet. It is like $80 cheaper for model without can so I just wanted to verify we do not have can on the 03 maximas. Thanks
Old Aug 20, 2007 | 09:45 AM
  #231
DasYears
partial CAN on 5.5 gen auto's, no CAN on manuals. i believe 04+ has can on everything
Old Aug 20, 2007 | 12:10 PM
  #232
Gle03Max's Avatar
Thank you for the info.
Old May 16, 2010 | 06:11 AM
  #233
HomerMAC's Avatar
Donating i30 Owner
1st time i read every post in a thread more than 2 pages long.. and worth every second. Even though we went off track a bit..
THANKS for the info BUMP.
Ben2003GLE
31
Jul 17, 2016 08:13 AM
kmitchel
Oct 28, 2015 09:46 AM
Starrider
Sep 17, 2015 07:26 AM
rbaker100
Aug 31, 2015 11:09 AM
305head
Aug 26, 2015 09:03 PM
