2k Lower IM swirl valves
Old 11-17-2005, 05:05 PM
Hella internets
XeroX's Avatar
I am attempting to remove these, as i left them in when i did the install, i just jb welded the outer holes (2) but im noticing that without the rod (for butterfly valves) the holes between each cylinder are wide open (not sealed). When you guys sealed the outer two holes did you also seal these? im assuming air will cross between cylinders, causing a loss in efficiency....
I noticed that no one has even brought these holes up, should i just leave them open?
Thoughts?
XeroX is offline
Old 11-17-2005, 10:25 PM
SDot82's Avatar
I just sealed the outer holes and I just left the inner holes alone. But thinking back on it I should have oh well.
SDot82 is offline
Old 11-18-2005, 10:47 AM
Hella internets
XeroX's Avatar
so it would be a good idea to seal these shut correct? Although i dont think your the only one that hasnt sealed em. i dont think anyone has.....hmmm.....
XeroX is offline
MaxLvr21
10-17-2015 12:11 PM
tseng1023
10-15-2015 08:30 AM
JonBlz
10-05-2015 06:02 PM
DC_Juggernaut
09-28-2015 04:07 PM
Quick Reply: 2k Lower IM swirl valves
