Sponsored by:
Sponsored by: CARiD
Compression Results
Old Dec 12, 2005 | 09:39 AM
streetzlegend's Avatar
Compression Results
I tested my compression today and it was as follows.
1..205-210
3..205-210
5..205-210
2..190-195
4..190-195
6..190-195
You guys know why front cylinders read different from the rears? each side individually is consistant. but dont kno if its ok for one side to have higher than the other?
Old Dec 12, 2005 | 10:18 AM
Stephen Max's Avatar
Maybe a slight difference in valve overlap between the two banks. Or perhaps carbon buildup is greater in the rear bank. Not enough difference to worry about, though.
Old Dec 12, 2005 | 10:27 AM
NmexMAX's Avatar
dot dot dot ...
And that's still a strong engine you got there.
Old Dec 12, 2005 | 10:32 AM
I have heard that one side runs a lil richer than the other. therefore carbon buildup?
Old Dec 12, 2005 | 10:41 AM
NmexMAX's Avatar
dot dot dot ...
Why would that be? Where did you hear this..,,
Old Dec 12, 2005 | 10:49 AM
JClaw's Avatar
His engine talks to him
Old Dec 12, 2005 | 11:01 AM
well to me i dont kno how one side would run differnt from the other. thats y i am a lil confused about my results.
Old Dec 12, 2005 | 11:04 AM
It would be pretty amazing if every cylinder got exactly the same amount of air as the others.
Old Dec 12, 2005 | 03:16 PM
Stillen Maxima's Avatar
Pay to Play
LOL
Old Dec 12, 2005 | 05:03 PM
GodFather's Avatar
Made in Taiwan
great compression results; i do envy you. i hope mine gets close to that result after my motor gets a full rebuild.
Old Dec 12, 2005 | 05:25 PM
s0ber's Avatar
isnt that high of a compression an indicator of alot of carbon buildup on the piston top causing the compression to rise?
what is spec according to the FSM? 170psi?
Old Dec 12, 2005 | 07:43 PM
f550maranello2's Avatar
wait hold on... when you check the compression do you crank the motor till the gauage stops moving or do you just crank it for a couple of turns... cuz the standard pressure is 185 psi... i just checked mine on a warmed up engine and they all were 185....
Old Dec 12, 2005 | 08:13 PM
s0ber's Avatar
Crank about 3-4 seconds. The gauge should have stopped moving by then
Old Dec 13, 2005 | 05:15 AM
yea as you crank, it goes higher and higher till it does not pass certain point, that should be the reading ur looking for. at least thats how me and s0ber did it.
TallTom
57
Oct 14, 2025 05:16 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
mkaresh
Mar 12, 2018 06:48 PM
Sep 27, 2015 08:37 AM
