Sponsored by:
Sponsored by: CARiD
Which Piggy does it all?
Old Feb 15, 2006 | 11:48 PM
oTranscendental's Avatar
I don't want to stir up old news, but ....
Which piggyback can control BOTH VI and raise timing? Or am I screwed into buying a vafc and an smt7?
Old Feb 16, 2006 | 05:33 AM
I30tMikeD's Avatar
No, you can buy a $50 summit rpm switch instead of a VAFC
Old Feb 16, 2006 | 06:05 AM
Fred Allen Burge's Avatar
Megasquirt.
Yes it can be used as just a piggy back on top of your stock computer. But, you will have to tune the ignition timing completely, not just modify the stock timing....unless you can datalog the stock timing from your stock ECU, then you could just copy that information to the Megasquirt for a "base map" then modify only the timing ranges that you wanted to.
allen
Old Feb 16, 2006 | 06:47 AM
Oh ya, you'll also have to switch to a coil pack instead of individual coils, run regular plug wires and run a Ford EDIS 6 ignition module wired into the Megasquirt. You'll need to run a crank mounted trigger wheel and sensor too like I am here:
http://forums.freshalloy.com/ubbthre...b=5&o=&fpart=9
After you've done all this you'll have total control over your timing. Then when you want total control over your fuel for a turbo/supercharger, ect. you'll only be a half a step from it.
This would be a fairly expensive option though if ignition control is all you really want.
allen
Old Feb 16, 2006 | 11:04 AM
DandyMax's Avatar
3.5 in the works
Originally Posted by oTranscendental
Which piggyback can control BOTH VI and raise timing? ....
Emanage Ultimate
Old Feb 16, 2006 | 11:26 AM
Alex_V
Megasquirt for the win! Its alot cheaper too. check out DIYautotune.com for prices. You can build it your self and save about $60 or so. fully tune timing and fuel.
Allen, I thought you were going to use the COP setup? Im going to try thats forsure. I have some ideas. Oh well the edis-6 is a good setup.
Oh and allen I got a '90 s13 to swap mine into. Im picking up my VQ30 in april so Im going to start then. I cant wait!!
~Alex
Old Feb 16, 2006 | 11:55 AM
The software just isn't there yet for the 6 cylinder COP, I'd prefer it but I have not problems w/ the EDIS route, it's well proven.
Good luck on your project! I've got some goodies and lots o' knowledge for anyone who wants to do one of these swaps.
allen
Old Feb 16, 2006 | 01:22 PM
95maxrider's Avatar
Lightly modded
Common Darius......try reading through my old thread...
http://forums.maxima.org/showthread.php?t=446133
Like people have said, it's really the EU, or nothing. Worry about the SMT-7 later, since I think they are still working out the kinks for the VQ. You might want to consider the SMT-6 with a Summit RPM switch.
Old Feb 16, 2006 | 02:37 PM
Kevlo911's Avatar
Kevlo for President
SMT has an RPM switch in it...
Old Feb 16, 2006 | 03:01 PM
95maxrider's Avatar
Lightly modded
I guess I should have read my thread more carefully
Old Feb 17, 2006 | 03:59 PM
haha, what?
Old Feb 17, 2006 | 05:36 PM
98SEBlackMax's Avatar
Maxima.org Insomniac
Right now the ONLY piggyback that has dyno proof of timing advance is the SMT-6 (Two indepedent dynos I might add). SMT-6 also has it's own built in RPM switch and has the ability to tune A/F like a VAFC. IMO On a VQ30 you would only need a SMT-6 cause the engine is limited on it's timing advance, odds are you will detonate before a cam CEL comes up.
If the EU ever works 100% as promised it will be better, however the EU and the SMT-7 are both having programming issues. This is due to Nissan's assinine crank and cam signals that are hard for them to read, you can also blame the Maximas poor aftermarket support for the lack of VQ30 software as well.
I did my part by getting the SMT-6 to work with dyno evidence to back it up. Now im just waiting for the EU or SMT-7 to work as promised, then I will buy one of those two and sell my SMT-6.
Old Feb 20, 2006 | 04:46 PM
t6378tp's Avatar
Turbo 3.5
I am new to this is there anyway for me to tune my a/f mixture
Old Feb 20, 2006 | 06:04 PM
NmexMAX's Avatar
dot dot dot ...
..... But do you know if needs tuning?
Old Feb 20, 2006 | 07:15 PM
t6378tp's Avatar
Turbo 3.5
I am goin to take a couple of dyno runs and if the a/f mixture is alittle off I want to be able to correct it
dfownz
Aug 12, 2006 01:20 AM
tweeter007
Oct 5, 2005 01:43 PM
-shock211-
18
Aug 2, 2004 11:34 AM
