Sponsored by:
Sponsored by: CARiD
AFR changes according to temperature?
Old Mar 12, 2006 | 11:43 PM
steven88's Avatar
Need A Light?
Just like the title says, Does your AFR change according to outside temperatures? I ask becuz I might hit the dyno during the summer...and it gets pretty hot in so cal...sometimes 95 degrees...
Also does the AFR change from repeated dyno runs? I know whp and wtq get affected if you go back to back runs...since the engine gets heat soaked...but what about AFR? Thanks!
Old Mar 14, 2006 | 09:12 AM
steven88's Avatar
Need A Light?
anybody know?
Old Mar 14, 2006 | 12:01 PM
MardiGrasMax's Avatar
AFR should stay the same regardless of ambient air temp.
AFR on back to back dyno pulls should stay very very close.
Old Mar 14, 2006 | 12:05 PM
steven88's Avatar
Need A Light?
nice!! thanks for the tip!
Old Mar 14, 2006 | 04:00 PM
Stephen Max's Avatar
AFR won't change with air temperature, but power will.
Old Mar 14, 2006 | 11:29 PM
Spanners's Avatar
AFR WILL and DOES change based on humidity and airtemp.
On a hotter day, your MAF reads a lower voltage, therefore lower portion on the map.
Old Mar 14, 2006 | 11:38 PM
steven88's Avatar
Need A Light?
oh okay...thanks for the tip...anyone else wanna comment?
Old Mar 15, 2006 | 04:59 AM
The MAF reads a lower voltage because the air is less dense on a hot day.
The MAF sensor measures the mass fowrate directly, and therefore takes air density into account. In closed loop operation, fuel will be delivered based primarily on MAF voltage and trimmed using O2 sensor information. In open loop, fuel will be delivered based on MAF voltage alone. In either case, since fuel delivery is based on the mass flowrate of air entering the engine, the afr will be independent of air temperature.
Old Mar 15, 2006 | 05:00 AM
The MAP the ECU is using may change but the target AFR is still the same or very very close for a stock Maxima I bet. I see 14.7 in 30f-70f when crusing of idling. When I bost up my target AFR is stll the same too.
Old Mar 15, 2006 | 05:24 AM
Same experience here.
Old Mar 15, 2006 | 09:08 AM
DandyMax's Avatar
3.5 in the works
The AFR is just a ratio.. so when using a MAF the ratio can be maintained easily since it's based on mass, which the MAF calculates directly without needing to know humidity or temperature. MAP is a different story of course.
Now on another note would the ECU perhaps enrichen AFR's under very high (and unusual) coolant temps (and likely retard timing also)? But I don't think the air temp is used even in that case. I'd have to check the FSM to see if it confirms those points. Can't remember off the top of my head.
Old Mar 15, 2006 | 09:25 AM
Larrio's Avatar
The Definitive AE Master
no changes from my AFR datalogging in the winter and summer. I'd imagine if there was any, it would be a very marginal change
Old Mar 15, 2006 | 09:35 AM
SPiG's Avatar
SomePsychoGuy
If you were running a MAP based AFR control without a Air Temp sensor or it was not properly tuned then it would.
Stock it shouldn't at all.
Old Mar 15, 2006 | 09:50 AM
steven88's Avatar
Need A Light?
Nice...hey guys, quick question...what exactly is an air fuel ratio? Like, I know it's 13.5 to 1 ratio etc....but 13.5 what?
I also see this ratio for compression ratio...VQ35s are 10.3 to 1...what is that 10.3?
Sorry if it sounds super noobish...but the only thing I know is gear ratios....like if your 1st gear is 3.15 to 1...it means the input shaft will spin 3.15 times before the output shaft spins once
Old Mar 15, 2006 | 11:02 AM
tavarish's Avatar
fwd gone rwd cr00
14.7 is the stoichiometric A/F Ratio, which is ideal.
That means 14.7 parts air to 1 part fuel. Any less air, and you're running rich, and any more air, and you'll run lean. When tuning, you'll try to get the flattest possible line, no peaks in your A/F ratio, and try to keep it the same ratio throughout the RPM range.
compression ratio is how much the air is compressed in the cylinder. When the engine goes into the compression stroke (in the 4 stroke engine cycle), the air gets compressed 10.3:1.
Old Mar 15, 2006 | 12:10 PM
Spanners's Avatar
14.7:1 is stoichiometric.. yes... creates the best bang, but is far from ideal to run in a car.
Try not to get into a mind set of X.XX AFR is the best, or we need to take XX timing out.. they are nothing but numbers for easy reference.
You will find that your engine will WANT more fuel at peak torque and less in the top end.
Heaps less when the cams change over (on a variable motor)
Forget about hp, tune for TORQUE at the wheels or tractive effort if you are on a Dyno Dynamics machine.
Do short runs to say 4000rpm first.. or even deadhead static rpms to tune there... get that sorted and work on the top end. No point in pulling the car to 7k rpm if you're working at 4krpm.
BTW, o2 sensors do nothing at full throttle.. on the dyno or when tuning they should be unplugged.
Regardless fo what anyone says, mixtures will and do change with temp.. both airtemp AND water temp.
This isn't heresay, its proven facts and experience from 100's of turbocharged Nissans on the dyno ranging from 150hp atw, up to 600hp atw daily drivers. Nissans is all we do
Old Mar 15, 2006 | 02:30 PM
steven88's Avatar
Need A Light?
can anybody vouch for Spanners? I mean, hes only got 4 posts and he just registered this month....is he legit with his sayings?
Old Mar 15, 2006 | 05:01 PM
We not talking ideal, were talking an off the shelf nissan ecu in a basically stock car. The AFR target and result will be the same regardless of ambient air temp.
And why would I want to unplug my wideband 02 on the dyno?
Old Mar 18, 2006 | 12:23 AM
Spanners's Avatar
I've got nothign to prove...
If you want to listen to my option based on experience and hands on then thats great.. if not, no probs.
I'm only here for more info on the VQ which we're going to use in our drag car.
Old Mar 18, 2006 | 12:30 AM
Spanners's Avatar
In theory yes, but in practice no.
And also far from Ideal.
We typically make 20% on turbo Nissans with just an ECU change and tune.
If you're tuning a vehicle, you want the tune to as close as possible with no external influences, hence why you unplug it.
doctorpullit
Oct 28, 2019 10:58 PM
Smackasmith
Feb 1, 2016 12:40 AM
msellas
Sep 23, 2015 09:16 PM
RWCreative
Sep 21, 2015 11:01 AM
flu2000
Sep 8, 2015 02:23 PM
