Sponsored by:
Sponsored by: CARiD
clarify please:what year headers? to go on a 3.5 IN my 4th gen..97-99, 00-01, 02-03?
Old Mar 15, 2006 | 02:01 PM
ThisMaxIsTight's Avatar
yup getting ready for the swap.... Tilley said to get the 97-99 headers for my 3.5 that will go in my 4th gen .... was just wondering what all you guys used, 97-99 headers, 02-03?? ... cattman? .. what other quality headers are there ?
Old Mar 15, 2006 | 02:22 PM
Kevlo911's Avatar
Kevlo for President
95-98 and 99-00 Fed Spec have the same stock headers.
Cattman will work if you use something to plug up egr(you will have to on stock too)
Hotshot will work, you might have to extend the o2 sensor wires.
Old Mar 16, 2006 | 10:14 AM
vipervadim's Avatar
I like Maximas
the 02-03 headers don't have an EGR bung on the REAR header, if you will be using EGR you need to get the 97-00 FED spec headers (99-00 stock headers also come in CALI spec with a HUGE precat on the front header, so don't get those, the rears do have the EGR, the 01-03 headers are all CALI spec and DO NOT have EGR bung in the rear)
I highly suggest getting aftermarket headers like the Cattman ($$$$+availability) or ebay/stone racing (not as good as Cattman but better than stock) to take advantage of better exhaust flow
however if you are going to run turbo/SC or A LOT OF NOS OFTEN, then you might want to use the stock headers because they're cast iron (exhaust gas temperatures are significantly higher when running boost) that way the headers will hold up better at higher exhaust temperatures. If you will be ALL MOTOR then go aftermarket.
Cattman makes headers with the EGR and the Ebay/Stone Racing headers have EGR bung too (the 02-03 people plug the EGR bung) however the hotshot headers for the 02-03 do not have the EGR bung, but you can weld one on for extra $$$ to make them work.
you will get CEL codes if you remove the EGR with a 96+ ECU. 95's do not have EGR codes
Old Mar 16, 2006 | 12:19 PM
Kevlo911's Avatar
Kevlo for President
Why this 97 BS? 95+ Are the same...
VQ'ed
69
Aug 27, 2020 12:29 PM
Finkle
Sep 27, 2015 09:53 PM
coasterswim
Sep 1, 2015 05:27 PM
vanebecker
Aug 23, 2015 07:40 PM
Blackwind
Aug 5, 2015 06:35 PM
