Sponsored by:
Sponsored by: CARiD
00VI w/ stock intake
Old Jun 4, 2006 | 07:20 PM
speed racer's Avatar
Well after 20 hours I got everything put in and the car started up no problem. I had a little trouble get the EGR Guide Pipe to sit properly, so I had to cut of the small round piece to get the plate to fit snug underneath the intake manifold.
Just so people will know if you want to keep your stock intake especially if your automatic you will need to purchase the Duct-Air 16578-31U00, Clamp-Hose 16439-31U00, and Clamp-Air Clean 14464-W1500. Than simple connect both air hoses and clamp the middle down. I cut a 1" wide Goyo Can to provide some reinforcement for the clamp.
This was my ghetto fabrication for the IACV. Two 1/4" plates.
The car has alot of pick up and the much needed top speed that the VQ30-DE lacked. I would say one of the best mods you can do.
Old Jun 4, 2006 | 07:31 PM
gtr_rider's Avatar
192.168.1.1
How does it idle the way you connected the IACV adapter?
Old Jun 4, 2006 | 07:54 PM
Its idling descent. Under no load the car idles around 850 to 875 rpm and under load the car would idle at 650 rpm. The only strange thing I'm getting is when I come to a stop the rpm will drop to about 825 than drop again. Almost feels like its surging. I"m going to keep playing around with the idle and see how it works. The hose I'm using is 3/8" ID and I'm not even sure if that's big enough. I'm thinking I might try 5/8" if I can't get the idle to where I want it.
Old Jun 4, 2006 | 08:03 PM
gtr_rider's Avatar
192.168.1.1
I used a 9/16" hose because the 5/16" wasnt big enough. I am still trying to find a way to reroute some things and put it in a responsible sized port on the IM.
Old Jun 4, 2006 | 08:07 PM
MorpheusZero's Avatar
I was wondering about intake relocation--is the intake setup actually different in autos and manuals?
Old Jun 4, 2006 | 08:13 PM
gtr_rider's Avatar
192.168.1.1
Not that I know of, other than the TPS
Old Jun 5, 2006 | 04:02 AM
How's the idle with the bigger hose? The intake set up should be the same.
Old Jun 5, 2006 | 05:16 PM
I got a question. When people used the 4th gen TPS on the 5 gen TB, were you able to get throttle response reading right away from looking at the VAFC. It seems like I have to push the pedal a little ways down before the throttle % on the VAFC actually starts to move.
Old Jun 5, 2006 | 05:52 PM
gtr_rider's Avatar
192.168.1.1
I just did it today and I got an idle but it was around <700 and I cant seem to adjust idle with my IACV.. Anyway, I left the IACV in place and opened the TB plate just a little bit to compensate for the retardation..
Old Jun 5, 2006 | 07:35 PM
aznsap's Avatar
speed racer, where did you get your adapter plate from? did you use one for the TB as well? it looks like you used a 5th gen TB and i'm guessing you just blocked off the IACV on that?
would you be willing to make me some plates?
Old Jun 5, 2006 | 07:50 PM
gtr_rider's Avatar
192.168.1.1
You can get the plate from StephenMax
Old Jun 6, 2006 | 04:09 AM
I made everything myself. Its not really quality either. The block off plate for the bottom of the TB is fairly simple to make but the IACV is a little harder if you don't have the right cutting tool. I don't know how I was able to cut the aluminum using a dremel, but I swear I went through 10 cutting discs before I was done. Try StephenMax b/c you might get a quick turn around.
Old Jun 6, 2006 | 07:22 AM
nismology's Avatar
Has ANYONE ever gotten the 4th gen IACV to actually control the idle?? From all accounts it doesn't do shiet unless it's on the USIM in the stock location.
Old Jun 6, 2006 | 07:23 AM
Kevlo911's Avatar
Kevlo for President
Mine does
Cold starts 1500ish. Warm to 600-700. My IACV is in a stockish location tho
Base Idle adjusting is in the howto's
Old Jun 6, 2006 | 08:03 AM
gtr_rider's Avatar
192.168.1.1
Originally Posted by Kevlo911
Mine does
No pics no care,,,
Old Jun 6, 2006 | 09:03 AM
Kevlo911's Avatar
Kevlo for President
No pics no care,,,
Old Jun 6, 2006 | 09:17 AM
gtr_rider's Avatar
192.168.1.1
gtfo 4G TB...
Old Jun 6, 2006 | 09:20 AM
But your using the 4th gen TB. doesn't that have an adverse affect on the IACV when it pertains to the Fast Cam.
By the way I have a air leak by my PCV so I will be taking car of that problem and than try to get the idle down b/c under no load its at 950 rpm. I also need to adjust the TPS on the TB. I think its not aligned correctly b/c the VAFC isn't reading a response until I push hard on the pedal.
Old Jun 6, 2006 | 09:56 AM
Kevlo911's Avatar
Kevlo for President
Yes, all air leaks and TPS issues should be fixed before you target the IACV.
Old Jun 7, 2006 | 07:15 PM
aznsap's Avatar
where do you ground the wire for the VIAS activation? did you run both the power and ground inside your car to an rpm switch?
and does your strut bar hit anything? i can't bolt mine in all the way b/c the bar hits the two bolts that hold in the hose bracket on top of the 00vi
Old Jun 7, 2006 | 07:28 PM
I haven't grounded it yet. I'm thinking of extending the ground wire and put an eyelet on so I can ground it to the manifold. A good spot is right next to the FPR where the vacuum tube rail bracket bolts to the manifold.
I'm using the VAFC to work as a switch. You can drill a hole from the engine bay to inside the car from underneath the steering column. There is a rubber pannel that can be removed on the firewall. Just drill into there. It will come out on the side, next to the Master Cylinder.
My strut bar is hitting the top of the 5th gen TB, but I just bent the rod to make it fit. Hopefully nothing happenes.
lrb6805
Sep 30, 2015 08:12 AM
bumpypickle
Sep 20, 2015 08:22 AM
220k+ A32
Sep 11, 2015 02:18 AM
Maxboy23
Sep 9, 2015 10:37 AM
Maxboy23
Sep 4, 2015 06:04 PM
