Sponsored by:
Sponsored by: CARiD
Emanage ultimate question
Old Jun 11, 2006 | 09:26 AM
hacim105's Avatar
I just received my Emanage Ultimate and I'm confused as to what firmware and or software I have. Can someone help me? and how do update if I'm not up to date?
Old Jun 11, 2006 | 10:01 AM
hacim105's Avatar
Nevermind I found that. Although I had another problem. When I connected the emanage to my computer with the USB cable it said that there was an error. So uninstalled everything and reinstalled and even now everytime I try and connect the EU to the computer nothing happens. It's not even recognizing that something is connected. Does anyone have any ideas as to why this is happening?
Old Jun 11, 2006 | 10:03 AM
Jime's Avatar
Go here http://www.mohdparts.com/emanage/ and get the latest software/firmware 114 right now.
Download the update, when you run the software and are connected to the EU it will automatically update the latest firmware if its on your computer.
See Page 9 of the manual.
Old Jun 11, 2006 | 10:09 AM
eng92's Avatar
Do you have the USB driver loaded?
Old Jun 11, 2006 | 10:10 AM
Jime's Avatar
The ignition has to be on.
Old Jun 11, 2006 | 10:16 AM
Kevlo911's Avatar
Kevlo for President
Jim, any details on the bigger maf housing but our element?
Old Jun 11, 2006 | 10:25 AM
hacim105's Avatar
I think that is my problem. Thanks guys. Sorry for the stupidity.
Old Jun 11, 2006 | 10:54 AM
Jime's Avatar
Not sure of your question Kev. MAF is cut out of the 4th Gen plastic housing and installed in a piece of 3.5" aluminum tubing.
Tried it out a few minutes ago. A little chugging upon startup but once I got the a/f set its fine. I had to add 35% fuel down low and 60% at WOT. Not sure yet how its going to work but it only takes 2 mins to change so I will be doing a lot of comparing ie timed runs etc.
I got the 3.5" aluminum tubing, the 3.5 filter and the 3-3.5 silicone adapter from Vibrant Performance.
Old Jun 11, 2006 | 11:01 AM
Kevlo911's Avatar
Kevlo for President
I see. Were you maxing out the maf?
Old Jun 11, 2006 | 01:17 PM
Jime's Avatar
No, just trying it to see if there is better flow as the MAF is the most restrictive part of the intake system in the 4th Gen and its just less pieces.
Basically trying to see if the CP-E setup for the Altima, which is basically the same as what I have done, helps any or just a myth to make money.
Old Jun 11, 2006 | 02:05 PM
Kevlo911's Avatar
Kevlo for President
Yeah I read a lil bit about that system. Sounds interesting.
Old Jun 11, 2006 | 02:55 PM
japmaxSE's Avatar
Go Get a Life!
Good to see your already at work with it good luck...
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
