Sponsored by:
Sponsored by: CARiD
new update on 3.5 swap (leak down test results)
Old Jun 14, 2006 | 05:25 PM
chris'smax's Avatar
Well i finally got them to finish the leak down test and the results were good. The cylinders ranged from 2.5-9%. The higher numbers don't bother me since the engine hasn't run hardly at all in along time and the rings probably need to build up pressure and get oiled up.
This kinda crazy that the leak down test showed up ok but i got compression test results that are f'd up. The front bank was 140-150 and the rear was 180-190. Anyone ever seen anything like this?
Old Jun 14, 2006 | 05:30 PM
Kevlo911's Avatar
Kevlo for President
Stuck/bent vavles? Bad engine?
Old Jun 14, 2006 | 05:59 PM
nismology's Avatar
Improper cam timing.
A leakdown test is to determine whether or not there is good static compression, but a compression test determines if there's good dynamic compression. Your motor is fine, but the cam timing is off.
Old Jun 14, 2006 | 06:03 PM
mforrest100's Avatar
Nismo.... you didn't waste anytime changing the picture under your name....(LOL) Out of all people GP...... Back on topic.
So does this really point back to the timing which points back to the drilling of the cams? I hope not.
Old Jun 14, 2006 | 06:33 PM
chris'smax's Avatar
i don't know but i sure as hell hope not. I don't want to think that the cam drilling is off because if it was then both banks would be f'd up(i would assume). Stephenmax isn't your normal joe blow and i know he is a very maticulous(sp) person.
Old Jun 14, 2006 | 06:47 PM
nismology's Avatar
There's no way around it. The only way you can fail a compression test but pass a leak down test is if the valves aren't opening and closing at the proper times when the motor is in motion.
Old Jun 14, 2006 | 06:57 PM
chris'smax's Avatar
I understand that but i guess i am just wishful thinking it wasn't the cams.
Old Jun 19, 2006 | 03:12 AM
SEmy2K2go's Avatar
Go BUCKS!!!
Now get us some updates!
Old Jun 19, 2006 | 04:45 AM
Jime's Avatar
Hope you didn't crank the engine over with timing gears removed because you can bend valves pretty easily.
Old Jun 19, 2006 | 10:12 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Jime,
Didn't Stephen drill your knock-off cams?
Old Jun 19, 2006 | 10:24 AM
Kevlo911's Avatar
Kevlo for President
I thought he had the REAL Nismo cams??
Old Jun 19, 2006 | 10:39 AM
IceY2K1's Avatar
Jime doesn't, Chris does.
Old Jun 19, 2006 | 10:42 AM
New question.... if cams were supposedly drilled wrong but you had Tilley's new cam adpaters/cam spacers could you use the incorrectly drilled cams since adpaters will move the hole to where it should have been drilled for the dowel pins???
Old Jun 19, 2006 | 10:46 AM
tavarish's Avatar
fwd gone rwd cr00
yes, the stock holes should be there.
by the way, the adapters tilley makes need modification to fit properly. I had to dremel some material off to make them work. Just an FYI for anyone doing the swap.
Old Jun 19, 2006 | 10:48 AM
OK. I will keep the info in mind.
Mike
Old Jun 19, 2006 | 01:21 PM
chris'smax's Avatar
I decided to use JWT 3.0 cams for right now and i will dyno to see where i am at. They should commplement the setup pretty good since they have similar specs to that of the tomei cams. I guess we will wait and see.
Car should be back on the road no later than wednesday, but i have been saying that $hit for the past 4 months
All i want for my birthday is my car back!!
Old Jun 19, 2006 | 01:22 PM
chris'smax's Avatar
thanks buddy
Old Jun 19, 2006 | 02:20 PM
Originally Posted by chris'smax
thanks buddy
Chris clear your PM box. I sent you an e-mail.
Mike
Old Jun 19, 2006 | 03:05 PM
nismology's Avatar
Almost positive your car will be working perfectly with 3.0 cams in it. Congrats in advance.
Old Jun 19, 2006 | 04:15 PM
IceY2K1's Avatar
Good luck Chris.....
Old Jun 19, 2006 | 06:27 PM
bluestreakgts's Avatar
How much time did it take you?
Old Jun 21, 2006 | 07:27 AM
chris'smax's Avatar
i noticed something when aligning the jwt cams yesterday. First i lubed the cams up w/ lucas oil then tightened down the cam caps and torqued to spec. Well when i went to align the cams i found the REAR INTAKE cams to be very hard to get it turn as opposed to the others. I took out that cam and re-installed it according to spec and it was still hard to turn. Could this be a result of the valves sticking causing resistance on the cam? Note i made sure that crank was turned to where the valves wouldn't hit the pistons.
Also is there anyway that a stuck valve(or valves) cause a difference in compression like i was seeing.
BTW THIS WAS A CAM IN THE REAR BANK WHICH IS WHERE I WAS GETTING 190 COMPRESSION AS OPPOSSED TO THE 150 I SAW IN THE FRONT.
Old Jun 21, 2006 | 12:24 PM
Weimar Ben's Avatar
Helicopters! Money!!!
Stuck valves will cause you to have zero compression.
Since you're putting in different cams than originally came with the engine, it's possible that the wear pattern on it where the cam caps secure the cam is different and thus causing resistance. It could also be that they're not lubed up enough.
The only possible way that you can have low compression in a single bank like that is if you have 2 cams that are out of sync with each other. Basically what's going on is that the exhaust valves remain open too long for part of the compression stroke and the piston can't build up much compression on its own as a result. When you did the leakdown test where both the intake and exhaust valves were closed, the valves and rings were able to hold the pressure just fine.
Engine rebuild lube would be better than lucas oil for lubing up the cams and caps. It has a consistancy similiar to vaseline, but thinner.
Keep working on it. You'll really be happy when it's working. I was jumping up and down yesterday when I got my 3.5 running.
Old Jun 21, 2006 | 12:29 PM
nismology's Avatar
Welcome to posts 3 and 6.
Old Jun 21, 2006 | 02:02 PM
Weimar Ben's Avatar
I saw those. I was just explaining it again in a different way.
Old Jun 21, 2006 | 02:44 PM
chris'smax's Avatar
We also rigged up something so we could push on the valve to make sure it wasn't the cam causing the issue. When the mechanic pushed on all 6 valves he could barely get them to move.
Old Jun 21, 2006 | 02:50 PM
IceY2K1's Avatar
I know you keep saying you checked clearances, but could it be bucket clearance?
Old Jun 21, 2006 | 02:51 PM
Weimar Ben's Avatar
The springs are fairly stiff and it's more difficult to apply pressure to the valves in the rear head than it would be in the front head. Did you compare the valves on one cylinder head to that of the other? They should all be equally difficult to open. You could also have a lack of lubricant between the buckets and the holes they go in.
Old Jun 21, 2006 | 03:01 PM
chris'smax's Avatar
I am pretty sure i saw him squirt oil down underneath the buckets.
Alex, yes i remeber him saying to me "man you got lucky, everything is within spec" just as he finished cheking the clearances.
Old Jun 21, 2006 | 04:12 PM
IceY2K1's Avatar
Could he have mixed up the cam caps?
I thought I remember reading you should keep them in the same place...not sure why though.
Old Jun 21, 2006 | 04:20 PM
chris'smax's Avatar
No the cam caps were not mixed up.
The reason you have to keep them in the right spot is because the are machined for each location and the tolerances are very tight.
Old Jun 21, 2006 | 04:22 PM
IceY2K1's Avatar
So in theory, if some were mixed up, the cam could bind or be loose, right?
Old Jun 21, 2006 | 04:31 PM
chris'smax's Avatar
to my knowledge yes.
Old Jun 21, 2006 | 05:42 PM
IceY2K1's Avatar
Saw you were looking for a "left" side head on the 350Z board.
What's your plan?
Old Jun 21, 2006 | 05:48 PM
chris'smax's Avatar
What's your plan?
well should the need arise, i would rather just swap on the complete head instead of tearing down what i have. But one thing i didn't think of was the fact that the 350z have stiffer valve springs than the max(according to sr20den thread). There could be other differences that i am not aware of but i am trying to educate myself on them.
I JUST WANT MY F%%%ING CAR BACK!!!!!!
sorry just having an emotional breakdown over here
Old Jun 21, 2006 | 06:01 PM
IceY2K1's Avatar
I'd have taken a gun to that b1tch by now....
Old Jun 21, 2006 | 06:53 PM
chris'smax's Avatar
Nah thats to quick. I got a sledge hammer just waiting for that damn thing. If this $hit doesn't get fixed no one is going to see a SC'd 3.5(at least from me )
Old Jun 21, 2006 | 07:19 PM
chris'smax's Avatar
Any other opinions on this?
Is there any way that maybe that one or more of the intake valves on the rear bank are screwed up causing the higher compression in the rear bank?
I noticed that virgillo7 (has a altima w/ the jwt knock off cams) said he had a compression of 130 in both rear and front banks. So if cams drop dynamic compression by that much then maybe my rear bank #'s are the ones that are off and not the front?
Front bank compression= 150
Rear bank compression= 190
MaxLife17
Sep 8, 2015 02:36 PM
Maxima30
Sep 7, 2015 06:13 PM
DrVee
Sep 4, 2015 12:18 PM
maximusrising
Sep 2, 2015 09:55 AM
iflexsteel
Sep 2, 2015 08:04 AM
