Sponsored by:
Sponsored by: CARiD
Ts Ecu
Old Jul 18, 2006 | 01:10 PM
packerZ's Avatar
Ts Ecu
I am buying a usedTechnoSquare ECU for my 96SE 5speed from a .org member with a 96 auto. He said it will throw a CEL code... is this just because I am using an auto ECU in my 5 speed? Correctable? What are the differences in actual performance mods made to an auto ECU v manual (slightly different idle speed/ maybe different advance for vacuum issues?)?? I don't mind TS not messing w/ rev limiter unless I install MEVI later (can add Harlan, I guess). Everybody raves about ECU upgrades, I hope I did right for the $$.
Old Jul 19, 2006 | 08:53 AM
915Max's Avatar
its a good investment and it makes a big difference! I bought a Technosquare ECU off a org. member too and i was impressed.... worth the cash!
Old Jul 19, 2006 | 12:47 PM
matts95max's Avatar
haha, I bought a ts ecu off an .org member as well!! its like we are in the 'I bought a used ts ecu from other .org member' club! haha, anyway its a really sweet upgrade! It makes a huge difference. I just did the dek swap..well its almost done and im going to see if they can raise the rev limiter for me. but i can wait to run the ts with my dek and full exhaust!! You will be pleased!
Old Jul 24, 2006 | 08:01 AM
packerZ's Avatar
Thanks guys!! My only real concern is the timing reprogram (1) I guess I have to run premium instead of "plus" and (2)difference in automatic program v manual... I bought an "automatic ECU" for my 5 speed. I've been told that I WILL get an error light but unsure if I can ever get rid of it after install. Is this really just "plug and play" part (ECU) board exchange next to firewall at accelerator?? Seems too easy! I appreciate your input!!! Doug (newest member of the "I bought a used ECU from a .org member" club)
Old Jul 25, 2006 | 10:05 PM
915Max's Avatar
The only problem I had was removing those four screws to remove the stock ECU-- I lost a small phillips screw bit inside my car-- it fell under the floor. It was fustrating for me.. but after that, it was easy!
Old Jul 26, 2006 | 10:35 PM
konak85's Avatar
too bad there is no extended rev limiter on the TS
Old Jul 27, 2006 | 01:13 PM
BEJAY1's Avatar
Conecarver
TS has dual maps to make use of non-premum fuel so it shouldn't be too different.
Old Jul 27, 2006 | 01:44 PM
packerZ's Avatar
I was not aware of dual mapping!!! So maybe I can just keep running "plus" grade without messing the engine up?? Actually, I used to run regular with no problems (no knocks and same gas mileage) but everyone said to use premium... I conceded to "plus" (cheap SOB that I am ) I was led to believe that I would HAVE to run premium with reprogrammed ECU. I never hit above 6200 on my shifts but I didn't want to screw things up on the way up there! Thanks for the heads up!!
I also understand that when I install the MEVI, I have sitting in the garage, it will really pull (even though I'm not going to use a rev-limiter). Any ideas on how to defeat the (probable) engine error light by my using an auto ECU v a manual in my 5 speed without sending back to TS???? Doug
Old Aug 24, 2006 | 03:21 PM
BUSi87's Avatar
Can't u call TS so they reflash ur ecu wit the manual map??
Anyone selling a TS ECU for an 02-03 maxima????
Old Aug 26, 2006 | 06:29 AM
nismology's Avatar
No. It's not that simple.
Wrong forum...
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
Dasmith
Sep 23, 2015 08:28 PM
QueensMAX
Sep 15, 2015 04:14 AM
