Sponsored by:
Sponsored by: CARiD
3.5 Swap done but cant start (no spark)
Old Jul 22, 2006 | 02:18 PM
urmab's Avatar
Well i hocked everyhing up im getting fuel and everything but im not getting no spak. ECU codes EVAP control system and EGR Temp sensor thats it. I checked the cam sensors nothing please let me know what else can it be thx
Old Jul 22, 2006 | 02:21 PM
GoalieKeg's Avatar
Check to make sure everything is grounded, alternator positive is put on correctly and nothing is arcing. Check starter, etc. It's probably a wiring issue.
Old Jul 22, 2006 | 02:31 PM
urmab's Avatar
Alright I just checked all ground i still get no spark. anything else that it could be.
Old Jul 22, 2006 | 02:35 PM
Kevlo911's Avatar
Kevlo for President
Double check everything is plugged in. Especially the crank sensors. So the starter is turning just fine?
Old Jul 22, 2006 | 04:42 PM
Nismo3112's Avatar
Custom User Title
What oil pan did you use? What crank pulley?
Old Jul 22, 2006 | 06:38 PM
urmab's Avatar
Im using 3.0 oil pan and im using the 3.0 crank pulley
i checked to see the crank sensors the apear to be pluged in fine and the starter is just turning i am getting fuel
Old Jul 22, 2006 | 07:03 PM
Nismo3112's Avatar
Custom User Title
check with page EC-336 of the FSM.
Old Jul 24, 2006 | 11:42 AM
vipervadim's Avatar
I like Maximas
is the main harness ground connected? make sure one of the vacuum hoses aren't disconnected.
make sure the cam/phase/pos are all pluged in and wires/harnesses aren't cut/damaged. make sure they are correctly plugged in, i.e. the 95 ecu has a switched Cam+phase in the ecu pin outs.
Make sure the 5th gen injector plugs have been spliced correctly to the 4th gen wires
good luck, maybe post a pic or two of the harness?
Old Aug 19, 2006 | 01:44 AM
Albi860's Avatar
what was the reason urmad engine wasn't sparking
Old Aug 19, 2006 | 01:45 AM
Albi860's Avatar
I meant urmab
Old Aug 19, 2006 | 06:14 AM
csb's Avatar
csb
Did you replace the flywheel or use the original? I'm asking this because, if you don't already know, I used a Fidanza and the guy who installed it for me forgot to transfer the timing ring over. No spark was my problem as well as the crank sensor had nothing to read.
Old Aug 19, 2006 | 08:40 AM
Albi860's Avatar
I used the original 3.0 flywheel
Old Aug 19, 2006 | 08:50 AM
GodFather's Avatar
Made in Taiwan
Is it no spark for all six cylinders?
Old Aug 20, 2006 | 02:38 PM
Nismo3112's Avatar
Custom User Title
^^ I think so.. Since the timing ring wasnt installed there was no signal.
schmellyfart
Sep 25, 2015 04:47 PM
Slamrod
Sep 3, 2015 07:38 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
cmpowell86
Aug 10, 2015 12:35 AM
Blackwind
Aug 5, 2015 06:35 PM
