Sponsored by:
Sponsored by: CARiD
She is alive!!
Old Jul 29, 2006 | 08:28 AM
Stabone's Avatar
She is alive!! Pics and a Video (56k no,no)
Got her started 30minutes ago. Turns out she needed a good tap of the throttle. Still have to adjust the TPS otherwise, shes going smoothly.
Couple notes:
3.5 plug on the Crank POS wires DID match up by color. I tried every combination after being told it was not right and as it turns matching the colors was the only one that worked. (Maybe this should be noted in the sticky)????
Still trying to figure out why I'm getting an error for the IACV. I have it hooked up to a mounting plate and tubing is done. Any ideas?
Hope to have her on the road today! But its hot as a *****!
Goodbye to old friend, so long!
This poor guy was stray maybe 5 weeks old. He ended up in his yard after being lost. My friend adopted him. We now call him "Lugnut"
The video of it running:
http://www.youtube.com/watch?v=nR-GG5TlcZk
Old Jul 29, 2006 | 08:34 AM
Kevlo911's Avatar
Kevlo for President
Where is the IACV hose ran to?
BTW, congrats.
Old Jul 29, 2006 | 09:00 AM
Stabone's Avatar
I'm still using the resonator from the 3.0 intake, so I routed it to where it was before. The other tube is hooked up in a vacuum outlet.
Old Jul 29, 2006 | 09:04 AM
GoalieKeg's Avatar
Congrats, now get it tuned.
Old Jul 29, 2006 | 10:01 AM
MDeezy's Avatar
It must be 3.5 season everyone is installing it.
enjoy the new power!
Old Jul 29, 2006 | 10:23 AM
96SEsleepa
to be fixed, put in, and driven.... ..
Old Jul 29, 2006 | 11:56 AM
tavarish's Avatar
fwd gone rwd cr00
3.5 swap is to nissan as GSR swap is to Honda. It's becoming that common.
Old Jul 29, 2006 | 04:03 PM
scrhale's Avatar
MORE INFO MORE INFO . 3.5 ECU? What was the hardest part? Are you mechanically inclined (trying to see if I should attempt this myself)? Tell us about the timing case swap. Down Time? How much did it cost roughly in the end?
Old Jul 29, 2006 | 04:21 PM
ajcool2's Avatar
Old Jul 29, 2006 | 06:55 PM
csb's Avatar
csb
If you do all the work yourself, I'm fairly certain you could git 'er done for 2K or less. In my case, I decided to replace both driveaxles with Raxles, pick up a Spec Stage 2 Plus clutch, Fidanza flywheel, new starter, water pump, all new gaskets, belts, hoses, ball joints, ES motor mounts, stabilizer links, etc., so the job will cost somewhere around 4K.
Old Jul 29, 2006 | 07:02 PM
That puppy is the most cutest thing!
Old Jul 29, 2006 | 08:09 PM
Stabone's Avatar
No 3.5 ecu, that would be a major undertaking and probably not worth it. Hardest part had to be doing it by myself in the grass! Imagine trying to move a motor in grass. I'd like to think I'm pretty mechanically inclined, I've done 5 other swaps(5 SR's) Timing case is easy, just looks difficult. $1000-1100
Old Jul 30, 2006 | 01:35 AM
Deckdout2's Avatar
Play with my balls
Damn that pup has the biggest tongue!
Old Jul 30, 2006 | 07:00 AM
Zack342's Avatar
I was thinking the same thing.
Old Jul 30, 2006 | 07:48 AM
Kevlo911's Avatar
Kevlo for President
Cool doggah tho.
Old Jul 30, 2006 | 08:42 AM
nismology's Avatar
Great job. And thanks for the info on the 3.5 CPS wiring. It will make it more straightforward when my turn comes around.
Old Jul 30, 2006 | 12:01 PM
Nismo3112's Avatar
Custom User Title
Congrats!! Take it easy the first miles.
njmaxseltd
Jan 21, 2003 11:31 AM
ny96max
Dec 28, 2001 11:46 PM
Turbo95Max
Nov 28, 2001 08:18 PM
Empz
Dec 10, 2000 12:05 AM
