3.5 swap IM question, won't bolt up
I have a quick question regarding the 3.5 swap. The Intake manifold from the vq35 won't bolt up, so I'm using the 3.0's intake manifold. The vq35 I'm using is a 2004.. would a 2002/2003's intake manifold bolt up, or do I just stick with the 3.0 IM ?
Also, I've read that one should use the 3.5 fuel rail/injectors, whats the advantage over using the 3.0?
When you do the swap, you're replacing the entire engine, not just the manifold, it's not an 00vi.
I am very well aware that I am replacing the entire engine. I'm not entirely sure what the mechanic said, but he indicated he could not use the 3.5's IM for some reason.. I'll stop by and get the exact reason and take pictures and post a better worded question. I should be able to use the 3.5 IM with no problems, correct?
I'm not sure, I'll find out in an hour or so after I leave work and post up. Has anyone who swapped in a 2004 3.5 had an issue with the IM?
Hmm, I'm getting more and more nervous.. can't concentrate on work worth a damn, lol Please god, tell me the mechanic isn't trying to use the 3.0 engine with parts and pieces from the 3.5
I'm almost 100% sure he's not.... time to see if I can sneak out early...
![chairshot](https://maxima.org/forums/images/smilies/chairshot.gif)
Ok, I went to see him, and now apparently there is no problem with using the 3.5 IM
I think he was just feeling lazy last time and wanted to do less work, so he was using the 3.0 fuel rail and injectors etc to avoid any rewiring on the harness, replacing connecters, etc. it was towards the end of the day. Well, at least now things are looking as they should, using the 3.5 IM and the 3.5 injectors and fuel rail.
He did ask me the following questions though
1)Why do I need to enlarge that hole in the timing case mentioned in the sticky. It seems like everything fits without him enlarging it, and its not interfering with the timing chain or anything, so he basically wants to know why this step is necessary before he does it..
2) Where are you drilling the intake cams? Is it the hole right opposite from the dowel pin?
Thanks for everyone's help
![got me](https://maxima.org/forums/images/smilies/ne_nau.gif)
the first question is common sense, its cause the holes for the timing cover bolts dont line up with the vq35, and you have to enlarge 2 holes to make them fit. Just physically line everything up and you'll see what I mean.
Contact StephenMax, he's the man when it comes to these type of things.
Cool, thanks for the help.. that leaves the question of where to drill the intake cams.. i've pm'd Stephen, but it seems he must be busy these days.. can anyone else help out?
Originally Posted by Nismo3112
Everything will fit and nothing will interefere, but that bolt that goes there will not go in unless you enlarge that hole. As Tavarish mentioned, line everything up and you will see.
Ah, so with the adapters/spacers I don't need to drill the cams. I thought the spacers were refering to the cam spacers like the JWT ones, which I had also needed to get.. I am assuming these are different? I'll pm stephenmax and hope he has some on him.
Thanks for clearing it up.
Originally Posted by 95BLKMAX
The point is, dont drill the cams. get the adapters/spacers from stephenmax. If you do not have a degree wheel like mentioned earlier, dont dare drill those cams. Because there is a common misconception that you drill it 180* off the current dowel pin... its NOT.
So I'm going to get the spacers/adapters from StephenMax and avoid drilling.
As for the issue with drilling the hole, I found out why everything was lining up as is, with the bolt in no problems. The mechanic had switched out the very top part (which has the hole that needs to be enlarged) out with the same part from the 3.0 engine, as the 3.5 had a sensor that was not there on the 3.0, so everything lines up and the bolt goes right in. Not sure if the extra step of switching that part was necessary, but I did ask the guy to try to avoid any check engine lights to make sure the car passes inspection, so he's paying extra attention to sensors and whatnot, also hooked up the egr. For now, I wait till friday to get the spacers/adapters. Thanks for everyones help.
So we went back to the 3.5 piece and left the sensor unplugged. Engine is almost all back together, transmission was put back on today. I should have her back by Thursday
Now to decide weahter I get an EU or an SAFCII... decisions, decisions...
![naughty](https://maxima.org/forums/images/smilies/naughty.gif)
Originally Posted by 96sleeper
yeah, I would be careful about that. Not only will the 3.5 valve covers not fit, but that is also the front cam bearings, which might not work correctly.
Originally Posted by scrhale
EU hands down ... don't think twice.
![Oh noes](https://maxima.org/forums/images/smilies/ohnoes.gif)
![](https://maxima.org/forums/images/smilies/support.gif)
Aparently using some resistors can take care of that, but I'm not the electrically inclined to open it up and solder in resisters and I'd probably end up shorting the whole thing! ![Oh noes](https://maxima.org/forums/images/smilies/ohnoes.gif)
-matt
That's what I'm leaning towards.. I used to have a 2002 eclipse GT, and its ecu tended to 'learn' the altered readings from the SAFCII after a while, so I'm hoping to avoid that. However, the only reason I'm hesitant about the EU is that it seems people are having issues with a misfire code being thrown when using it. Aparently using some resistors can take care of that, but I'm not the electrically inclined to open it up and solder in resisters and I'd probably end up shorting the whole thing! ![Oh noes](https://maxima.org/forums/images/smilies/ohnoes.gif)
It's not a misfire code. It's because the ECU thinks the coil circuits are open (no load). The car will run just fine, except the light will be on.
As matty said the resistors are no big deal. Get someone to do it in your area who can do electrical work/soldering, or as a last resort send it to me and I'll do it for a small fee.
Cool, thanks for the info. I feel more comfortable going with Emanage Ultimate now, so thats probably what I will do. One clarification though, with the resistors in place, will the light still be on, or does using the resistors solve that issue?
Yes the resistors get rid of the CEL.
Matty I wouldn't charge anything other than to cover shipping and parts costs, which would be like what, $10-$20 or even less? Do you seriously think I'm trying to turn a profit on this? Geez if I wanted to make money wiring in a couple of resistors is not the most efficient way to do it. It's easier for me to not even have to bother, I'm just trying to be helpful and say I'd do it if it was a last resort for someone, and the difference between them getting an EU and not getting it. It's far better for him to find a competent person locally.
I'm sure he was just joking sarcasticly about you chargin too much.. and taking the chance to offer his help as well.
And both of your comments did make the difference in my decision to go with an EU rather than something else, y'all rock
![leap frog](https://maxima.org/forums/images/smilies/leapfrog.gif)
![headbang](https://maxima.org/forums/images/smilies/headbang.gif)
You're probably right. At first glance I thought with the icon he meant it was lame to charge anything.
It's been a long, stressful week, and I'm a bit wound tight at the moment.![Tard](https://maxima.org/forums/images/smilies/tard.gif)
Nevertheless it was probably good for me to clarify so no one gets the wrong impression when I say "fee." It's just to cover costs, nothing more.
Originally Posted by matty
Dandy...you took me seriously.?? I was seriously just kiddin around
-matt
-matt
Turned the car on today, she's running great
The hose on the intake box is a bit short though, so its not fitting properly,I'll have to see if I can get an extension or something. Anyone else run into this before? Once that is taken care of, my swap will finally be done.. Oh, I'm using everything stock as far as the intake is concerened (air filter, box etc.) Car is revving a bit high on idle, but I'll worry about that after everything is fitting properly.
![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
FlaMark
25
08-28-2015 10:15 AM
BobMax
08-15-2015 12:35 PM
