Sponsored by:
Sponsored by: CARiD
Guys running NO Cruize ?
Old Aug 30, 2006 | 12:22 PM
matty's Avatar
Now with my pathy tb, I have no way to run the cruize control witch isnt a big deal at all.
My question is, Can I take off that big bulb thing thats attached to the fire-wall that houses the Cruize Control Cable ?? The cable has no breaks in it to take it off and I would hate to cut it. What do you guys do to elimate the cable and that bulb thing ??
-matt
Old Aug 30, 2006 | 12:24 PM
krismax's Avatar
Father of the 00 VI
-matt
iam confused i have a pathy TB and have had my cruise for 3 years same as stock it has two ears
Old Aug 30, 2006 | 12:42 PM
Nismo3112's Avatar
Custom User Title
On the other side of the bulb should just be a vacuum line.. You can take the bulb and cruise cable out.
Old Aug 30, 2006 | 12:49 PM
Biggs_02's Avatar
-matt
yeah using a pathfinder tb is what enables use to continue to use our cruise control with the 3.5 swap. using the 3.5's tb and modifying it to work with drive by cable is what cuts out the cruise control
Old Aug 30, 2006 | 01:23 PM
matty's Avatar
I had to take it off because it doesnt clear the 00 VIAS on the manifold. With the Cruize Ear on, you cant mount the Throttle body, with it off, its a perfect fit.
-matt
Old Aug 30, 2006 | 01:27 PM
RA030726's Avatar
I'm nutty for Nissans
just un bolt the actuator ball, follow the vac line to the controller on the strut tower near the master cylendar and remove what you dont want.
Old Aug 30, 2006 | 03:10 PM
tavarish's Avatar
fwd gone rwd cr00
-matt
here's an easy fix for that. physically bend it out of the way. the cruise still works, and all is well.
I eliminated my cruise a while ago. I dont use it, and it's weight reduction.
Old Aug 30, 2006 | 04:53 PM
scrhale's Avatar
Cruise is the greatest invention ever IMO ... ok that is an exageration but still. I like it for highway driving. /post lol.
Old Aug 30, 2006 | 04:56 PM
matty's Avatar
I never use it anyway.
With the 00VI/Pathfinder TB setup there is NO way to use Cruize. Its tucked way too far under the VIAS to even fit. With the Cruize ear on there, it doesnt even fit onto the adaptor plates. Just No-Go.
-matt
Old Aug 30, 2006 | 04:57 PM
matty's Avatar
So If I take the bulb fixture off of the firewall, where is the break in the Line ?? I cant see it anywhere in the firewall. Anyone ever take it completely out of the engine bay ??
Old Aug 30, 2006 | 05:00 PM
tavarish's Avatar
fwd gone rwd cr00
yup. you just yank it out, the line comes out of the bulb. then theres the solenoid, which has 1 10mm bolt on top, and 2 on bottom in the wheel well, and bam, no cruise control, and you saved a few lbs and space in your engine bay.
Old Aug 30, 2006 | 05:01 PM
tavarish's Avatar
fwd gone rwd cr00
-matt
i've seen 2 setups with the PF tb and 00vi where cruise was fully functional though.
Old Aug 30, 2006 | 05:04 PM
matty's Avatar
I have NO Idea how. I guess stephen max's plates dont allow you to use it beaucse when I bought the plates and TB from him, he told me that Cruize ear will not fit cause of the VIAS.
My Pathy TB comes Straight out, unlike other setups ive seen that have it come out on an angle. Maybe thats why ?
-matt
Old Aug 30, 2006 | 05:11 PM
tavarish's Avatar
fwd gone rwd cr00
-matt
you have to bend it out of the way (the ear). This is how it is on HarrisH's setup, and it works fine.
Old Aug 30, 2006 | 06:03 PM
krismax's Avatar
Father of the 00 VI
mine works fine i have 00 vi and pathy TB and i didnt have to bend , i made my adapter blocks so the cruise works. i cant go without cruise i wouldnt have a license , i use it even driving in citys and towns
Yes thats the key you just clock the TB on the adapter easy to do
Old Aug 30, 2006 | 06:20 PM
vsamoylov
since when removing cruise is a weight reduction?
Old Aug 30, 2006 | 06:51 PM
DandyMax's Avatar
3.5 in the works
I didn't want to give up the cruise.
I just put a PF TB on mine the other day, using a clocked adapter set I had made up and I also modified the springs and butterfly rod to shorten everything up to more easily clear the VIAS.
Old Aug 30, 2006 | 09:36 PM
tavarish's Avatar
fwd gone rwd cr00
since the cruise WEIGHS something, taking it out would be a REDUCTION in WEIGHT. Need a chart?
Old Aug 31, 2006 | 06:02 AM
vsamoylov
the keyword in that statement is "SOMETHING".
Old Aug 31, 2006 | 07:39 AM
RA030726's Avatar
5lbs is 5lbs.... if you keep removing the weight it will add up to something significant.
Old Aug 31, 2006 | 11:08 AM
tavarish's Avatar
fwd gone rwd cr00
I removed the metal brace in the glove box, weighed 1.5lbs. everything counts.
Old Aug 31, 2006 | 12:10 PM
krismax's Avatar
Father of the 00 VI
i love the cruise and cant part with it but my car weighs 2550lbs at the track for a reason i took many little things out
Old Aug 31, 2006 | 01:26 PM
vsamoylov
put the driver on a diet and it will be the same thing.
Old Aug 31, 2006 | 01:59 PM
tavarish's Avatar
fwd gone rwd cr00
why not put the driver on a diet and do weight reduction?
and when you gonna run at the track?
Old Aug 31, 2006 | 02:31 PM
vsamoylov
thats a good idea also. and about the track name a time and place and we can go to one
Old Aug 31, 2006 | 05:24 PM
krismax's Avatar
Father of the 00 VI
hes already went time in sig ,now go run your very own 18 sec 1/4.
but you might say "my cars faster than 18 seconds" . show us and the masses will believe. you can talk and talk but talking = 0 . show us your engines potential
Old Aug 31, 2006 | 06:02 PM
tavarish's Avatar
fwd gone rwd cr00
englishtown, nj. You choose the time.
Let's see what VTC's and 6spd can do.
Old Aug 31, 2006 | 06:03 PM
tavarish's Avatar
fwd gone rwd cr00
you should come too, your car was the reason i got my 3.5 swap.
LilVito
Oct 25, 2019 08:12 AM
vybz05
Dec 10, 2015 07:38 PM
max1029
Aug 26, 2015 09:51 AM
4 door GT-R
Aug 22, 2015 07:50 AM
maxipower
Aug 21, 2015 11:10 AM
