Sponsored by:
Sponsored by: CARiD
Plastics back!!
Old Aug 31, 2006 | 09:29 PM
krismax's Avatar
Father of the 00 VI
Plastics back!!
found this link on my350z.com http://jimwolftechnology.com/vq35hr/index.htm
nissan gave them a g35 with vq35hr many pics and PDF
i think that engine is way underrated
Old Aug 31, 2006 | 09:39 PM
DandyMax's Avatar
3.5 in the works
Hmm.. dual plenum, dual TB... and quite the interesting runner/port design. Would be great to see a dyno...
Some interesting details in the pdf too...
Old Sep 1, 2006 | 03:39 AM
Tatanko's Avatar
Bacon Lover
Repost...
http://forums.maxima.org/showthread.php?t=489499
Old Sep 1, 2006 | 04:44 AM
krismax's Avatar
Father of the 00 VI
Originally Posted by Tatanko
my focus is on the engine not the car its in
Old Sep 1, 2006 | 06:01 AM
LA02MAX's Avatar
wtf? the title of that old thread is "Exploded view of the VQ35HR intake manifold"....in what way does that focus on the car the engine is in? It gave same link that you posted, so IMO this is a x 100000
Old Sep 1, 2006 | 06:20 AM
DandyMax's Avatar
3.5 in the works
First I'd seen those details... but then again I've been so busy I haven't really kept up with much lately
Old Sep 1, 2006 | 06:58 AM
d00df00d's Avatar
Old enuf to pick his own gears
He said the engine, NOT the car it's in.... not "the car the engine is in."
Old Sep 1, 2006 | 08:16 AM
SDot82's Avatar
He is saying the other link is not talking about the car but about the engine or at least the manifold.
Old Sep 1, 2006 | 10:41 AM
LA02MAX's Avatar
thank you.
Old Sep 1, 2006 | 11:25 AM
gtr_rider's Avatar
192.168.1.1
3.5 VI
Old Sep 1, 2006 | 02:07 PM
Nismo3112's Avatar
Custom User Title
Interesting.... Can't wait to see dynos.
Old Sep 1, 2006 | 04:15 PM
tavarish's Avatar
fwd gone rwd cr00
AWWWW MAN How TF am I supposed to fit THAT under my hood?
Old Sep 1, 2006 | 06:17 PM
Nismo3112's Avatar
Custom User Title
It would interfere with the firewall so badly you won't even get close to worrying about the hood.
Old Sep 1, 2006 | 06:52 PM
tavarish's Avatar
fwd gone rwd cr00
oh well, i'll put it in the 240 then.
Old Sep 2, 2006 | 07:32 AM
MaxBlack97's Avatar
it might b able to fit it in the fourth gen,whas the gains it will give thas another question? TBA
Old Sep 6, 2006 | 08:05 PM
hoohaa's Avatar
Huh. Well that's interesting.
Old Sep 6, 2006 | 08:19 PM
NmexMAX's Avatar
dot dot dot ...
Almost @ 15
Read this... might help you not get an early vacation...
http://forums.maxima.org/showpost.ph...&postcount=546
http://forums.maxima.org/showthread....08#post5222408
Old Sep 8, 2006 | 09:47 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
WTF is with the square ports...
Old Sep 8, 2006 | 09:51 AM
LA02MAX's Avatar
IDK, but it seems to me that the HR's powerband is going to be much higher than the older VQ35DE I like my low-end torque, so i'd prefer to keep the IM that's on my car, even if this one could be swapped (which i know it cannot)
http://www.maliburacing.com/ovalvsrect.htm
Old Sep 8, 2006 | 11:20 AM
japmaxSE's Avatar
Go Get a Life!
I disagree, I believe it will retain the low end power. Using a square intake port provides for a more even transition between the port and valve for (High Rev Efficiency). But luckily the HR engine counters the low end Tq loss with VTC's at both ends of the cam's I/E along with many other additions added to the new design. Now if you ask me I haven't seen any actual numbers that would tell me if it's swap worthy, such as upper or lower IM etc. just to early to tell. But I can only imagine the available potential this HR motor will provide.
Old Sep 8, 2006 | 11:27 AM
LA02MAX's Avatar
Originally Posted by japmaxSE
I disagree, I believe it will retain the low end power. Using a square intake port provides for a more even transition between the port and valve for (High Rev Efficiency). But luckily the HR engine counters the low end Tq loss with VTC's at both ends of the cam's I/E for the daily street use. Now if you ask me I haven't seen any actual numbers that would tell me if it's swap worthy, just to early to tell. But I can only imagine the available potential this HR motor will provide.
Ah, I see I see...I forgot about the exhaust VTCs. I'm sure that this motor is very efficient throughout the powerband, but as you said, it's very hard to tell without knowing all the details, and seeing what kind of power it REALLY puts to the ground and what the curve looks like. But like i said before, it'll most likely have much more power up top than the current VQ due to the new IM (among other things, of course)
Old Sep 8, 2006 | 12:05 PM
SPiG's Avatar
SomePsychoGuy
The HR equipped cars probably come with shorter gearing to utilize the higher powerband and make up for any low end torque loss the VQ35HR might have.
It also looks like the ports on the head to LIM are the same oval shape as the other VQ35s which makes this swap possible if you use the upper and lower IMs. It is only square inside the upper IM and transitions from square to oval through the Lower IM.
Old Sep 11, 2006 | 07:25 AM
Fred Allen Burge's Avatar
I'm not so sure about that, look at how the head is cast. The intake ports actually extend outwards toward the center of the "V", looks different than regular VQ35DE's to me.
Old Sep 11, 2006 | 08:07 AM
SPiG's Avatar
SomePsychoGuy
I haven't seen the VQ35 up close too much, so of course don't take my word for it. But if the head ports are the same then it is possible.
JRod28
Dec 29, 2023 09:56 PM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
Justin Kroll
Sep 2, 2015 11:06 AM
doobadoo
Aug 15, 2015 06:43 PM
